Old Mar 24, 2006, 11:48 AM
Dave Lauck is offline
Find More Posts by Dave Lauck
90% of the game is half mental
Dave Lauck's Avatar
Penn Valley California
Joined Jun 2004
New Product
Jet ECU Real-time Data from Eagle Tree Systems, LLC
Eagle Tree Systems is excited to announce the availability of the Seagull Pro Jet Wireless Telemetry systems. The combination of our Pro telemetry system and our new Jet ECU Interface technology gives the Jet Pilot critical turbine and other data in real time.
Imagine, now you no longer need to guess at whether your turbine has flamed out, whether your battery pack is running low, or whether your airspeed is too low for a safe landing.
Our Pro Seagull system with ECU interface cable connects to your turbine's ECU (via your ECU's telemetry/GSU/data terminal port) and provides the following real-time information on the Wireless Dashboard's LCD screen:
* Turbine Temperature
* Turbine RPM
* ECU Pack Voltage
* Airspeed, Altitude
* ECU Pump Voltage
* Throttle Deflection Percentage
* ECU Status messages
* Other critical data you can use
And best of all, you can program alarms to sound if your turbine flames out (RPM or temperature too low), if your Pack Voltage drops below a preset level, if your airspeed is too slow or high, and much more!
The Seagull Pro Wireless Flight Data base system includes: LCD Dashboard/Receiver, Onboard Black Box and Transmitter, Brass Pitot/Static tube, temperature sensor, RPM sensor with magnets, t-fitting for static airspeed and altitude, 4 Y-cables for servo monitoring, battery backup cable, Windows CD with Virtual Instrument Display and Graphing, and instructions. Many optional modules are also available.
Eagle Tree currently provides ECU interface cables for JetCat, AMT Netherlands, and Gaspar/FADEC ECUs, with others coming soon.
For JetCat flyers in the USA, see BVMJets.com for our complete systems for your ECU!
See your dealer, or purchase directly from Eagle Tree if you cannot locate a dealer near you.
Click here for more information.
BVMJets, JetCat, AMT Netherlands and Gaspar/FADEC are trademarks of their respective companies. BVM Jets is the exclusive distributor of our JetCat ECU support in the USA.
Dave Lauck is offline Find More Posts by Dave Lauck
Discussion Google Earth™ GPS Support from Eagle Tree Systems, LLC billpa Product Announcements 2 Nov 29, 2006 12:01 PM
Discussion Google Earth™ GPS Support from Eagle Tree Systems, LLC billpa Slope 0 Nov 26, 2006 01:40 PM
New Product Wireless Jet ECU Real-time Data from Eagle Tree billpa Fuel Jet Talk 0 Mar 26, 2006 01:14 AM
MicroPower E-Logger from Eagle Tree Systems, LLC Dave Lauck Product Announcements 0 Dec 19, 2005 03:15 PM
Multiple RPM Sensor Support from Eagle Tree Systems, LLC Dave Lauck Product Announcements 1 Nov 09, 2005 12:39 AM
