Old Mar 23, 2006, 11:22 PM
finishman2000 is offline
Find More Posts by finishman2000
nooobama
United States, PA, Stroudsburg
Joined May 2004
Help!
Delta wing CG without the Canards??
I'm building the Firebat foamie that has canards on it. Well everyone says that they break off so I'm planning on just loosing them and setting up the ailerons as elverons. I'm sure though this will screw with the CG. Can I just do the old 1/2 the leading edge, 1/2 traling edge and then the 25%? Thanks, Cas
finishman2000 is offline Find More Posts by finishman2000
Old Mar 23, 2006, 11:30 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
The starting point for deltas is just forward of 1/2 the root chord - 25% of the wing area is forward of that line.
Tom Harper is offline Find More Posts by Tom Harper
Old Mar 23, 2006, 11:39 PM
nooobama
Joined May 2004
What is the root chord? Or how do I get that measurement? Thanks, Cas
Old Mar 24, 2006, 02:31 AM
Art Schmitz is offline
Find More Posts by Art Schmitz
Crossville, TN
Joined Dec 2004
The root chord measurement is from the leading edge to the trailing edge at the half span point.
Another way of stating post#1...
Art Schmitz is offline Find More Posts by Art Schmitz
Old Mar 24, 2006, 08:36 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
finishman,
The root chord is the width of the wing at the fuselage.
Old Mar 24, 2006, 10:09 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Here's a quick MS Excel program that will give you the 25% location for a wing with up to three chord breaks.
It's called Sailplane Calc.
Curtis
Montana
Curtis Suter is online now Find More Posts by Curtis Suter
Old Mar 27, 2006, 02:42 PM
uriah is offline
Find More Posts by uriah
uriah's Avatar
Twisp Washington USA
Joined Sep 2005
i got a better idea!!! the canards are there for stabalization and in some cases, flight control... you want them! just build some canards out of a stronger material... even aluminum if you want...
uriah is offline Find More Posts by uriah
Old Mar 27, 2006, 03:38 PM
nooobama
Joined May 2004
I want speed so I'll try it with them off. I'll find out in about an hour if I got the CG right.
Old Mar 29, 2006, 10:16 AM
uriah is offline
uriah's Avatar
Joined Sep 2005
well did ya?
Old Mar 29, 2006, 10:39 AM
nooobama
Joined May 2004
Sorry, I figured no one cared about the 'ol Firebat now that it is so outdated by all the new sexy foamies out there.
Yes it did fly, the CG is a right on but I set up a little in front of it for the first few flights. This plane is made of easy to damage EPS foam and I don't expect it to live a long life. I replaced the ailerons with balsa and the JustGoFly.com 400DF is a little underpowered for this plane but it does about 5 rolls a second and rolls on its own axis. I don't think it would do this if I lefyt the canards on. I may up the powerplant to the 450DF once I get some 20c lipo's. Overall a good plane, looks good and flies well.
Thanks for the help guys, Cas
Old Mar 29, 2006, 02:45 PM
uriah is offline
uriah's Avatar
Joined Sep 2005
any pictures?
Old Mar 29, 2006, 03:00 PM
nooobama
Joined May 2004
I have no idea how to post'em here. If you want PM your addy and I'll send some over, Cas
Old Jul 16, 2006, 03:59 AM
isvana is offline
Find More Posts by isvana
Random Flier
Oxford (UK) and Mtn View CA (USA)
Joined Nov 2002
Interesting thread - I just had a spectacular in-air break-up of my Firebat-sans-canards. I was struggling to get the CoG correct (was testing at 2cm in front of the theoretical CoG I'd calculated from some spreadsheet, and it was still barely controllable in the pitch axis, wanting to dive or climb but not fly straight - this was with the servos, LiPo and RX all near the nose!).
[To be fair the crash sequence was nowt to do with CoG, but the canopy ejecting as I struggled to control the plane. This lead to the aft fusalage cover to catch the wind and flip up. This was latched into the top of the motor mount, so it levered off the mount and the motor / ESC / battery ejected. Plane glided beautifully with all that gone... ]
isvana is offline Find More Posts by isvana
Old Jul 16, 2006, 11:38 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Originally Posted by isvana
... Plane glided beautifully with all that gone... ]
And THAT'S where the c.g. should be!
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jul 17, 2006, 07:06 AM
isvana is offline
Random Flier
Joined Nov 2002
LOL! Thats what I thought too. Proved I was 1cm too far back and/or had some other problem. I'll mark the CoG and rebuild. Next project is the 3-engine (250 motor) FirebatSC (sans canard)...
Help! Homebuild- Delta wing- CG? flight help ? advice needed.. maiden liljoe Foamies (Kits) 12 Mar 04, 2006 05:57 PM
Delta wing CG question rcnutt Foamies (Kits) 7 Nov 22, 2005 08:01 AM
Delta wing CG - how?? DaleM Flying Wings 7 Aug 14, 2004 12:04 PM
delta wing cg??? tailwind76 Modeling Science 3 Apr 30, 2004 03:23 PM
Question Delta wing CG Whereabouts? Claude G. Vest Fuel Plane Talk 2 Sep 11, 2003 11:41 AM
