Old Mar 23, 2006, 06:30 PM
xray328 is offline
Find More Posts by xray328
Joined Apr 2005
Engine wont shut off
I can't get my Enya .15 to shut off on approach. The resulting landing are a little faster than I'd like. I'm belly landing so I'm also breaking props. I don't get it, if the carb is closed why does it still run??? Any ideas what I can do?
xray328 is offline Find More Posts by xray328
Old Mar 23, 2006, 06:45 PM
Mikes Machines is offline
Find More Posts by Mikes Machines
Mikes Machines's Avatar
Medina, Ohio
Joined Oct 2002
If the carb is closed and it is still running it is sucking air from somewhere else. The carb may not be seated all the way or the o ring may be damaged. I suppose its possible that the fit between the throttle barrel and the carb housing may be letting air in also. There has to be some clearance so the parts can move but it may be excessive.
Mikes Machines is offline Find More Posts by Mikes Machines
Hummingbird wont lift off. Charlieharry Micro Helis 16 Mar 22, 2003 07:29 PM
Motor won't shut off JamesD Parkflyers 9 Mar 09, 2003 01:19 PM
Hitec CG340 Auto Shut Off konaboy Batteries and Chargers 2 Nov 30, 2002 02:30 PM
Schematics for discharger with auto-shut-off? Peter Khor Batteries and Chargers 2 Jul 31, 2002 09:58 PM
