Old Mar 23, 2006, 01:24 PM
VTX is offline
VTX
Find More Posts by VTX
VTX
Joined Mar 2006
Picture of servo-activated camera
I am just curious how you have setup your camera with servo triggering.
VTX is offline Find More Posts by VTX
Old Mar 23, 2006, 02:12 PM
Gray is offline
Find More Posts by Gray
Smile & wave
Gray's Avatar
Lancing West Sussex
Joined Jun 2005
VYX,
I have looked out a few of my servo operated mounts.
Gray.
Gray is offline Find More Posts by Gray
Old Mar 23, 2006, 02:16 PM
Tail Spin1 is offline
Find More Posts by Tail Spin1
Zach
Illinois
Joined Feb 2004
My camera mount is made form a plastic switch box and is suspended under my Slow Stick on a wooden frame made from a paint stick. The cameras shutter button is pressed down by the arm of a HS-55 servo mounted to the top of the box. There is a hole cut in the top of the box to expose the button. The servo arm was slowly sanded to the right shape using a dremel with a sanding drum. Itís somewhat trial and error to get the servo arm just the right shape. You canít tell it in the picture but I glued a piece of 1/32Ē ply to the back of the servo arm to make it thicker. A thicker servo arm gives me better contact with the shutter button and ensures that it wonít miss its intended target. The cameras servo is operated my aileron channel since the Slow Stick is a stick and rudder only plane. If you wonder what the sticker is on the back of the camera mount I used my scanner to get a picture of the back of the camera and glued the picture to the back of the mount so I would know where to cut the holes for access to the buttons and LCD plus it has the added advantage of serving as a label for the buttons.
Hope this helps
Zach
Tail Spin1 is offline Find More Posts by Tail Spin1
Old Mar 23, 2006, 02:33 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
"I used my scanner to get a picture of the back of the camera and glued the picture to the back of the mount so I would know where to cut the holes for access to the buttons and LCD plus it has the added advantage of serving as a label for the buttons."
Great idea!
It's easier than eyeballing and cutting..
Keeping those buttons on the back free from inflight pressures helps the camera actually work!
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 23, 2006, 03:59 PM
VTX is offline
VTX
VTX
Joined Mar 2006
Is the camera itself cut/drilled/glued or otherwise damaged in the process of being mounted to the frame? I would hate to see that. Tripod mount is the only "natural" anchor point but I wonder if it provides enough support.
Old Mar 23, 2006, 11:10 PM
TStokes is offline
Find More Posts by TStokes
TStokes's Avatar
Phoenix
Joined Mar 2003
http://www.rcgroups.com/forums/showp...&postcount=120
Easily removable. No alteration to the camera.
I use a nylon 1/4-20 screw in the tripod mount.
Tom
TStokes is offline Find More Posts by TStokes
Old Mar 23, 2006, 11:12 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
in worst case, you can hot glue a servo on. it does not damage the camera that way. I also use 1/4-20 nylon screw and include them in my kits. works well.
askman is offline Find More Posts by askman
Old Mar 24, 2006, 07:29 AM
Ginger Adam is offline
Find More Posts by Ginger Adam
I'm Ginger & called Adam
Ginger Adam's Avatar
Hereford, UK
Joined Oct 2002
I built a plane specifically for 'lookdown' AP for a chap who's an archeologist - we couldn't work out why the pictures didn't seem to be working as well as we thought (we'd modified another plane to have a crude 'lookdown' mount before and it worked fine).
You've probably already guessed - the foam mount was pressing against the 'T' zoom button as the plane moved around and so the photos were quickly all maximum zoom (almost utterly useless for AP when you're looking straight down )
Adam
Originally Posted by Sparky Paul
Great idea!
Ginger Adam is offline Find More Posts by Ginger Adam
Old Mar 24, 2006, 02:41 PM
booma is offline
Find More Posts by booma
Flying Kiwi
booma's Avatar
Wellington, NZ
Joined Apr 2005
If you dont want to use the tripod thread find a little plastic box that fits.....a mount can be quickly and cunningly crafted with a knife and hot glue.
booma is offline Find More Posts by booma
FS: Mega Sized Servo for Camera Pan/Tilt Mr.RC-CAM Aircraft - General - Radio Equipment (FS/W) 5 Nov 03, 2004 11:32 AM
GWS 'Naro' servo for camera switch Andyfree Aerial Photography 1 Mar 22, 2004 09:40 PM
servo to USB camera control trust Aerial Photography 7 Feb 02, 2004 09:51 AM
Servo-->Camera setups DaveRCPilot Fuel Plane Talk 2 Sep 27, 2002 04:58 AM
Servo-->Camera GForceStress Aerial Photography 2 Sep 26, 2002 11:21 AM
