Old Jun 29, 2001, 05:42 AM
Foxtrot is offline
Find More Posts by Foxtrot
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
Can you put a SP 480 in an EJF EDF 400?
Just curious. Would their be a point?
Foxtrot is offline Find More Posts by Foxtrot
Old Jun 29, 2001, 11:32 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
presumably yer talking about the Hiline grey plastic unit...unfortunately the center only accepts s400 diameter motors, however there are several motors that can fit from the Maxx cobalt to Astro, Aveox, Kontronik and Hp brushless units.. these can be fitted with one of Oliver Wemotec's reduced diameter Minifan 480 rotors for serious output in a very light(and very inexpensive) shroud assembly.
But no, there is no way to easily fit yer old 480 in there. You can get up to (maybe) 9oz thrust from a shunted and rebalanced 4.8v (stock type) motor though
Bare is offline Find More Posts by Bare
Old Jun 29, 2001, 03:20 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Nope, it dont fit. Further more the cut down Midi fan rotor do not clear the EDF 400 shroud. It would have to be cut down even more. . I tried to go the same route as you and ended up with 2 EDF 400s and 2 cut down Mini fan 480 rigs with speed 480 bb motors and made shrouds up out of spray paint caps.
JasonJ is offline Find More Posts by JasonJ
Old Jun 29, 2001, 03:31 PM
Foxtrot is offline
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
Looks like I'll have to go with Mini fans then. Thanks for your help.
Discussion Can you put ESC's in parallel. FairlyFaded Power Systems 7 Jan 30, 2007 08:16 PM
Question Can you put a smoke system into an electric bird? _Pattern_Man Sport Planes 8 May 02, 2006 10:15 PM
Can you put a B50S with 6.7 GB in a Bandit noddy High Performance 7 Apr 17, 2005 12:56 PM
Can you put 2000 Mah in a 2100 Lipo? Mac8 Batteries and Chargers 6 Mar 09, 2004 08:21 PM
can you put thrust bearings in an Eco? nullman Electric Heli Talk 5 Mar 05, 2002 11:36 AM
