Old Mar 21, 2006, 06:31 PM
scottypotty is offline
Find More Posts by scottypotty
scottypotty's Avatar
Akron, Ohio
Joined Jan 2006
Help!
Help whats up with my motor?
I posted this in a difference section, but I bet you guys might be able to help me better. My motor is a E-flite Park 480 1020KV outrunner. I have a problem......the other day when I was flying.....I ran down my first battery, landed changed batterys.......took off then about 2 min. in flight my motor started making a weird noise......i turned to land and then it quit....when I picked it up I tryed spinning the prop.....everthing seemed OK so I throttled up and it started beeping and pulsing then my esc started smoking. the Esc wasnt even hot. about 110F.....turns out my speed control is shot.... but some one told me it sounds like your motor is shorted or has a bad wire and is missing a phase? and thats what took out my esc.........does anyone know anything about this? I tested the motor on a differnt esc. and seemed ok, but now im affraid that I will burn up another esc if I start flying again.........is there any tests that i could do?.....any help/information would be great.
scottypotty is offline Find More Posts by scottypotty
Old Mar 22, 2006, 06:47 AM
Chippie is offline
Find More Posts by Chippie
North East England UK
Joined Jan 2003
Check the soldered connections at the wires of the motor, check that the windings are not shorting to each other or to the stator bearing tube
Chippie is offline Find More Posts by Chippie
Old Mar 23, 2006, 11:44 AM
Akron, Ohio
Joined Jan 2006
I checked over everthing last night. seems ok, I guess I will try it out. thanks for the info.
Discussion Whats up with my old school packs?? JONBOYLEMON Batteries and Chargers 10 May 27, 2007 02:03 PM
Question whats wrong with my motor? Call Me Jack Electric Plane Talk 2 May 13, 2007 12:30 PM
any idea whats up with my charger?` kraker89 Batteries and Chargers 26 Aug 25, 2005 03:15 PM
Help! wacked up esc/motor... WHATS UP WITH MY MOTOR? lift off Power Systems 2 Apr 21, 2005 06:01 AM
Whats up with my new 1200 HP pack???? Speedfreak Batteries and Chargers 1 Jan 24, 2005 08:46 PM
