Old Jul 11, 2006, 03:59 AM
John Anderson is offline
Find More Posts by John Anderson
Joined Jun 2006
My own is going to use a modified recompressive ballast system. Thrust vectoring for yaw, blended stern planes for pitch and roll control ( the batwings on the cabin induce a rather large roll moment in a turn and need to be canceled out to keep control otherwise when she rolls the yaw input turns ibto a pitch moment and down it goes out of control)and the midships planes for depth keeping. I used a ten inch Lee models as a test mule and once you get the static trim dialed in it tracks straight line very nicely due to the batwings on cabin. However they are to far above the CG and meta center to use as control surfaces. I tested them as both pitch and yaw surfaces and they induced a porpising moment when in pitch and a high speed roll when used as yaw surfaces. The sternplane tips are to far out and to small to be effective yaw rudders.
John Anderson is offline Find More Posts by John Anderson
Old Aug 07, 2013, 08:25 AM
Timbrewster is offline
Find More Posts by Timbrewster
Joined Aug 2013
Hi Stingray 3
I have been searching around for some plans for stingray and was wondering if you were able to share or help with locating some
Many thanks
Tim Brewster
Timbrewster is offline Find More Posts by Timbrewster
Old Apr 19, 2014, 09:07 PM
tutoolea is offline
Find More Posts by tutoolea
Joined Mar 2008
Stingray.
Esto lo encontré en Devianart. suerte con tu proyecto.
tutoolea is offline Find More Posts by tutoolea
Discussion Stingray drawings. 785boats Dock Talk 6 Jul 21, 2007 12:53 PM
Help! I.A.R. 822 - Drawings wanted! gardemin Scale Kit/Scratch Built 0 May 30, 2007 01:36 AM
3 dimension drawings wanted. MarkChinery High Performance 4 Aug 06, 2004 05:58 PM
MB-339 Drawings wanted Doug Cronkhite Electric Ducted Fan Jet Talk 12 Aug 26, 2003 11:14 PM
