Old Jun 26, 2001, 03:18 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
Mf 480 ducting
Hi
I´m planing to build a fast EDF with the MF480, and need some help with inlet and outlet area for the MF480.
Thera are probably many posts with this info...but I could´t find any of them...
/Henke
henke is online now Find More Posts by henke
Old Jun 26, 2001, 10:58 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Fast with a Minifan means 450watts input power.. suggest researching the Lehner Bl motors.. they can do this reliably..
With that power using the Minifan instruction/recomendations will do the job.
Bare is offline Find More Posts by Bare
Old Jun 26, 2001, 01:48 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Well there are many parameters to consider (wing area, weight & wing loading, wing profile & ducting etc) but as far as the ducting is concerned I would keep the intake diam close to the fan diam (=69 mm), for fast jets you can reduce it a slight bit. As far as the outlet is concerned for the MF480 you don't want to go below 53 mm diam.
Have a look at the short discussion on
http://www.wemotec.com/englisch/basics/index.html
or buy like I did a copy of D. Juras' book.
Herb is offline Find More Posts by Herb
Old Jun 27, 2001, 01:25 AM
henke is online now
henke's Avatar
Joined Jan 2001
Thanks for your replies!
I was thinking fo a Plenum like plane, using my new Hacker B40L (600W). (the starfighter project is resting fot the moment)
/Henke
MF/480 Balancing LJH Electric Ducted Fan Jet Talk 9 Nov 06, 2003 11:59 AM
Mf 480 Cutlass rogwinger Electric Ducted Fan Jet Talk 16 Oct 29, 2003 09:18 AM
MF 480 Fan Blades Diameter X Pitch chrisc Electric Ducted Fan Jet Talk 4 Mar 04, 2002 01:31 AM
MF-480/Cobalt trouble marauder Electric Ducted Fan Jet Talk 16 Dec 24, 2001 08:44 PM
MF 480 and Speed 480 question Sabrejock Electric Ducted Fan Jet Talk 12 Dec 11, 2001 12:18 PM
