Go Back   RC Groups > Aircraft - Electric - Airplanes > 3D Flying
Old Mar 19, 2006, 07:36 PM   #1
Foam Flyer
rc4metoo's Avatar
Perfexion Build Along Thread
Hello fellow foam 3D-ers,
I would like to do a build along thread for my new design www.RippinFoamies.com full-fuselage indoor 3D bipe that I call the Perfexion. I have pioneered some novel construction techniques that I would like to share. Enjoy!
I'm not a kit builder of foamies. I would rather buy $60 of foam and make a dozen foamies. This winter I have completed 8 foamies and this will be nine.
The Perfexion is my newest design and is built from plans. I get the full size prints done at Kinkos. I then transfer the prints to posterboard to make templates. The best way to do this is to use acetone. I get my acetone at Home Depot. I get my posterboard at Staples. Both are very inexpensive.
Lay the plans face down on the posterboard and wipe the back of the paper with acetone. Like magic it transfers the print to the posterboard! Check out the photos.
Once the plans are transferred, cut out the posterboard. The posterboard I get has the thickness of a poker card. Cut out all the parts. See photos.
I also use the posterboard for painting templates. See photos!
More to come.
JC
  • Name: plans_transfer.jpg
Description: Lay plans over posterboard face (ink side) down and wipe with acetone. Lay plans over posterboard face (ink side) down and wipe with acetone. 22.8 KB · Views: 268
  • Name: plans_transferred_complete.jpg
Description: Like magic the plans are transferred to the posterboard. Like magic the plans are transferred to the posterboard. 26.8 KB · Views: 228
  • Name: templates.jpg
Description: Easy to cut out posterboard templates. Easy to cut out posterboard templates. 44.0 KB · Views: 259
  • Name: stencils.jpg
Description: I also do paint stencils out of posterboard.  See above. I also do paint stencils out of posterboard. See above. 45.5 KB · Views: 298
rc4metoo is offline Find More Posts by rc4metoo   Reply With Quote
Old Mar 19, 2006, 07:45 PM   #2
Bob G
rmgmag's Avatar
Looks good so far. Keep 'em comming.
rmgmag is offline Find More Posts by rmgmag   Reply With Quote
Old Mar 19, 2006, 07:49 PM   #3
Foam Flyer
rc4metoo's Avatar
Full Fuse
My full fuse concept is build using two symmetrical sides and a top and bottom former. Why full fuse? It is a lot stiffer and stronger than the typical X-type fuse that most shockies use. Also, I find that the full-fuse bipes I build roll better - more axial. I think they look cooler as well!
My fuse concept starts with the two sides being stacked directly on top of each other (see photo). I hot glue the front and back. You have to use hot glue for the flexibility. I just deposit a small blob and then smear it out flat.
This makes the fuse an envelope where you can insert the top and bottom formers.
Now that I have all the foam parts cut out it is time to paint. Better to paint while everything is flat! I use posterboard stencils and Krylon Fusion paint. Fusion dries almost instantly so the painting step is very quick. Just position the stencils and spritz on some color. See photos.
More to come!
JC
  • Name: foam_parts.jpg
Description: Full fuse is make from two halves joined at the ends with hot glue.  Forms an envelope. Full fuse is make from two halves joined at the ends with hot glue. Forms an envelope. 43.0 KB · Views: 255
  • Name: stab_elevator.jpg
Description: I like elevators with a thin connection instead of the large one-piece elevator usually seen on foamies.  I hot glue a piece of 1.5-2.0 mm carbon fiber rod between the halves.  It works very well! I like elevators with a thin connection instead of the large one-piece elevator usually seen on foamies. I hot glue a piece of 1.5-2.0 mm carbon fiber rod between the halves. It works very well! 37.6 KB · Views: 302
  • Name: painted_parts.jpg
Description: Parts all painted with Krylon Fusion.  A little goes a long way.  I always use too much and this is true here.  Just a mist is all you need for very nice color. Parts all painted with Krylon Fusion. A little goes a long way. I always use too much and this is true here. Just a mist is all you need for very nice color. 56.8 KB · Views: 320
Old Mar 20, 2006, 07:12 PM   #4
Foam Flyer
rc4metoo's Avatar
Taping it together
I got another hour in on the project today.
The first thing I did was to add the formers to the fuselage. Looks like the CAD program worked since everything fit!
Next I added a .8mm x 3mm carbon fiber leading edge to the wings to keep them straight. I hot glue them using dabs of glue every inch or so and then tape. After taping I go over it with a warm iron to "set" the tape so that it never pulls up.
Next I beveled and taped on the ailerons and then joined the elevators and stab with tape.
I glued in the stab/elevators to the fuse and then taped on the rudder. Now she is starting to look like an airplane! I then did a trial assembly to see if everything fit. It did! I then mounted the motor mount and calle it a night. See photos below.
JC
  • Name: fuselage_a.jpg
Description: Fitting in bottom fuse former and gluing in with hot glue. Fitting in bottom fuse former and gluing in with hot glue. 45.6 KB · Views: 232
  • Name: fuselage_B.jpg
Description: Fuselage with top and bottom formers in place. Fuselage with top and bottom formers in place. 39.9 KB · Views: 285
  • Name: wing_cf_attach.jpg
Description: Gluing carbon strip to front of wing with small dabs of hot glue. Gluing carbon strip to front of wing with small dabs of hot glue. 51.2 KB · Views: 233
  • Name: wing_iron_tape.jpg
Description: Wrap LE with thin clear tape and then "set" tape with iron set on "1".  Tape will not pull up over time! Wrap LE with thin clear tape and then "set" tape with iron set on "1". Tape will not pull up over time! 56.7 KB · Views: 268
  • Name: aileron_hinge_tape.jpg
Description: Taping in ailerons.  Be sure to leave a 1mm gap.  Set tape afterwards with warm iron. Taping in ailerons. Be sure to leave a 1mm gap. Set tape afterwards with warm iron. 50.8 KB · Views: 241
Old Mar 20, 2006, 07:17 PM   #5
Foam Flyer
rc4metoo's Avatar
Trial assembly
Pre-assembly or what I call the "pay-off" moments when she is coming together!
JC
  • Name: elevator_tape.jpg
Description: Joining elevator to stap with 3/4" thin clear tape and then setting with warm iron. Joining elevator to stap with 3/4" thin clear tape and then setting with warm iron. 46.0 KB · Views: 204
  • Name: tail_feathers.jpg
Description: Elevators glued to fuse and rudder taped on! Elevators glued to fuse and rudder taped on! 55.7 KB · Views: 236
  • Name: motor_mount.jpg
Description: Motor mount glued to fuse.  This X mount is "self-aligning" and about the strongest way that I have found to mount a small outrunner. Motor mount glued to fuse. This X mount is "self-aligning" and about the strongest way that I have found to mount a small outrunner. 45.6 KB · Views: 242
  • Name: trial_assembly.jpg
Description: Trial assembly to see how she is going to look.  Starting to look like an airplane! Trial assembly to see how she is going to look. Starting to look like an airplane! 48.6 KB · Views: 274
Old Mar 20, 2006, 07:25 PM   #6
GIMMIE FOAM!!!
AirNerd's Avatar
Awsome!
you gonna post plans?
AirNerd is offline Find More Posts by AirNerd   Reply With Quote
Old Mar 20, 2006, 07:49 PM   #7
Foam Flyer
rc4metoo's Avatar
No plans yet...but if you are interested...read on!
Originally Posted by AirNerd
Awsome!
The plans for the Perfexion are not ready for release yet. I need to clean them up a little. I may let some go free in exchange for a beta build and test on Ezone if you are interested.
I also have plans available now for my "Football" design (see photos). I'm trying to sell them on my website: www.rippinfoamies.com, but nobody is buying . I can let Football plans, stencils, and manual go now for buiders/testers interested in doing builds, photos, and videos on Ezone. Just send me an email if you are interested: john@rippinfoamies.com.
JC
  • Name: front_barber_sheet_small.jpg
Description: Football with "Bill Barber" scheme. Football with "Bill Barber" scheme. 32.9 KB · Views: 219
  • Name: side_starsstripes_sheet_small.jpg
Description: Football with patriotic "Stars and Stripes" scheme. Football with patriotic "Stars and Stripes" scheme. 37.8 KB · Views: 312
Old Mar 20, 2006, 08:33 PM   #8
When I can’t fly anymore.
Just ShootMe's Avatar
I have seen John’s planes fly, and Perfection is the word for them! He does not stop designing them until they fly perfectly in all attitudes. The Perfexion is poetry in motion when it is doing rolling circles.
Just ShootMe is offline Find More Posts by Just ShootMe   Reply With Quote
Old Mar 21, 2006, 08:34 AM   #9
Bob G
rmgmag's Avatar
Are there any formers or supports inside the fuselage?
Old Mar 21, 2006, 02:24 PM   #10
Foam Flyer
rc4metoo's Avatar
No.. just the top and bottom.
Hello rmgmag,
No, just formers at the top and bottom are all that is needed. The resulting box structure is stiff and straight.
JC
Old Mar 21, 2006, 06:48 PM   #11
Foam Flyer
rc4metoo's Avatar
Thanks!
Thanks..er...Dick, right? I need to post some video, but don't have a video camera yet.
Tax refund expected soon maybe I'll be able to get with it.
JC
Old Mar 21, 2006, 07:02 PM   #12
Foam Flyer
rc4metoo's Avatar
Some more buildin'
Mostly shocky bits work tonight. A little tedious, but you can use these parts over and over again. The bits on my proto Perfexion are on their...lets see...sixth airplane.
See the photo captions below for my progress notes.
JC
  • Name: pushrod_wires.jpg
Description: I use 1.5 mm CF rod for pushrods.  I use .032 wire for the ends so that I can use Dubro Micro hardware. I use 1.5 mm CF rod for pushrods. I use .032 wire for the ends so that I can use Dubro Micro hardware. 43.7 KB · Views: 249
  • Name: pushrod_complete.jpg
Description: Scuff the wire with sandpaper and wrap to CF rod with thread.  Glue with thin CA and kick-it.  Easy! Scuff the wire with sandpaper and wrap to CF rod with thread. Glue with thin CA and kick-it. Easy! 25.0 KB · Views: 235
  • Name: zip_tie_conx.jpg
Description: To connect ailerons I use strips of large zip tie.  Bore out with 1/16 bit and install Dubro micro hardware. To connect ailerons I use strips of large zip tie. Bore out with 1/16 bit and install Dubro micro hardware. 36.8 KB · Views: 224
  • Name: aileron_conx_glued.jpg
Description: Glue to ailerons with hot glue and mark location for bottom linkage. Glue to ailerons with hot glue and mark location for bottom linkage. 47.7 KB · Views: 219
  • Name: pushrod_supports.jpg
Description: For rudder and elevator, I cut lengths of Dubron antenna tube and slide over pushrods.  These will be supports... For rudder and elevator, I cut lengths of Dubron antenna tube and slide over pushrods. These will be supports... 26.5 KB · Views: 224
Old Mar 21, 2006, 07:07 PM   #13
Foam Flyer
rc4metoo's Avatar
More building...
A little more work and a trial assembly for the "payoff" moment.
JC
  • Name: pushrod_supports_installed.jpg
Description: Elevator and rudder pushrods are supported for best control response. Elevator and rudder pushrods are supported for best control response. 40.5 KB · Views: 234
  • Name: aileron_horns.jpg
Description: Aileron horns hot-glued in. Aileron horns hot-glued in. 33.8 KB · Views: 230
  • Name: aileron_servo_installed.jpg
Description: Aileron servo installed and .032 pushrods installed.  I hot glue in my servos - works great, strips off easily for next project! Aileron servo installed and .032 pushrods installed. I hot glue in my servos - works great, strips off easily for next project! 44.7 KB · Views: 278
  • Name: payoff_2.jpg
Description: Pay-off moment for tonight. Pay-off moment for tonight. 50.9 KB · Views: 255
Old Mar 21, 2006, 08:01 PM   #14
GIMMIE FOAM!!!
AirNerd's Avatar
Very very nice JC.
Old Mar 22, 2006, 06:56 PM   #15
Foam Flyer
rc4metoo's Avatar
Finished 'er up tonight!
I finished the Perfexion up tonight with a small amount of work. I am happy to report that everything fit and only a couple of minor changes to the CAD plans will be made.
I am super jazzed about completely hiding the RX in the fuse for the first time. I am also anxious to see how those new super light BMS-303 servos work from Bluebird. I also developed a way to hang some wheel pants on the gear legs that worked out pretty good.
She looks really nice and came out at about 6 ounces. I'll be test flying this Friday.
See captions on photos for details.
Best regards,
JC
  • Name: motor_and_mount.jpg
Description: I make my motor mounts out of ABS plastic that I have laying around.  This X type mount works the best for Depron foamies.  It is the most rugged method and simple too! I make my motor mounts out of ABS plastic that I have laying around. This X type mount works the best for Depron foamies. It is the most rugged method and simple too! 34.4 KB · Views: 223
  • Name: mounted_AXI.jpg
Description: Mount AXI 2204/54 with screws from behind. Mount AXI 2204/54 with screws from behind. 38.3 KB · Views: 203
  • Name: axle_with_cage.jpg
Description: Thin music wire axle with "cage" bent on outside.  The wheel pant will be hot-glued to cage.  Wheel is Peck-Polymers free flight. Thin music wire axle with "cage" bent on outside. The wheel pant will be hot-glued to cage. Wheel is Peck-Polymers free flight. 29.0 KB · Views: 204
  • Name: axle_with_gear_leg.jpg
Description: Rough up wire with sandpaper and wrap to 1.5mm CF gear leg.  Hit with thin CA and kick.  Easy! and you can use it on your next 10 foamies. Rough up wire with sandpaper and wrap to 1.5mm CF gear leg. Hit with thin CA and kick. Easy! and you can use it on your next 10 foamies. 35.2 KB · Views: 211
Z3D build and fly thread! j_z_123 3D Flying 12 Dec 26, 2003 02:47 PM
Long term build along: Beech 18 at 20% SheldonYoung Scale Electric Planes 53 Jan 31, 2003 01:18 AM
Brisfit and free plan build along Looooeeee! Parkflyers 37 Sep 15, 2002 11:27 AM
AZ Chuck's Hissy build-along. Looooeeee! Parkflyers 21 Feb 11, 2002 11:33 AM
11
