Peachtree City, GA
Joined Nov 2001
Thanks guys,
I kind of thought you were going to say that. Carlo, Just so you know, when using my motor/esc setup, I have not experienced any problems with the BEC. The BEC doesn't cut out until the heli doesn't have enough juice to fly. Chachin, You should have seen Gary Wright fly his logo20 at SEFF. That is an impressive ship. He preformed an auto at the end that was quite impressive. Wish I would have made a video of the demo. Thanks again, Eric |
Gainesville, FL, US
Joined Jun 2001
Eric
It really depends on the flying situation; if your just hovering you BEC is fine. Here is a situation: You have to bail out and you nail the collective. Note you are about you have have already been flying for about half of your pack. The load of the motor makes the voltage drop momentaraly to the cutoff and your ESC shuts off. This actually happened to me, but I was using my Kontronik in airplane mode when it happened. Lucally I had the auto gear installed and I wasnt too high and I got my heli level. Carlo |
Gainesville, FL, US
Joined Jun 2001
Hello
I have a B50-11L comming and it looks like it is going to be a hell of a motor for the Eco 8. I am really going to let it rip with this motor installed. I know from other sites that the B50-14L is a good all around(basic flight and acro) motor. Im pretty sure that the B50-11L to 15L are all very good motors for the Eco 8(which one depends on pack used and pinion). Also, the B50-18S is a good motor for the Eco 8 according to Kontronik and other who use the motor. I have read that the B50-14S-19S are good motors for the Eco 8(which one depends on pack used and pinion). Personally I think the B40-xx are too small for the Eco 8. Here is a lot of motor test data in various helicopters including the Eco 8. It is definitally worth looking over. http://www.dokidoki.ne.jp/home2/tohrus/motorindexE.html Carlo |
Peachtree City, GA
Joined Nov 2001
Yeah, I can see that happening. It seems like the voltage has to get pretty low before the BEC cutout with the Phasor and Jeti. For example, when I was learning to hover, you could nail the collective (when the battery was getting low) and it would not cut out. The heli is virtually unflyable when the BEC does finally cutout. What kind of battery do you use for your RX? I wonder if anyone else is using the Phasor/Jeti combo and not using a battery for the RX?
. I've seen gas helis flying before, but I was more into airplanes back then.. and they were gas.I was planning on putting a Hacker B50-18S on my Eco 8, but they're too expensive. Instead, I'm going to invest the money on a B50-13L for my Logo 10 and shift over the FUN600-15 (from my Logo) into my Eco 8. I'm hoping that my FUN600-15 motor will be able to turn my Eco 8 into a 3-D flyer on 10-cells. Hey Carlo, where did you order your B50-11L from, Icare?? How long does it take to ship?? Chachin.. |
Gainesville, FL, US
Joined Jun 2001
Hello
I got the B50-11L on the Ezone. All I know is I'll have a little monster; hopefully it is not to much for me to handle. Carlos, I think the Fun will be a very nice motor in your Eco 8 with a 21 tooth pinion and 10 cells Oh, I found that the pitch control links bind(flybar tilt is very limited) badly on the flybar bearing barrel(on metal head) at the extremes and also bind at about 8 degrees when the flybar is tilted. The flybar just doesnt get the same travel as it did with the mixing arms, on the grips, in its normal orientation. I switched back to the normal setup, but I definitally notice the loss in pitch range so my range, but my heli is still very powerful. Carlo |
Peachtree City, GA
Joined Nov 2001
O.K.
After my three consecutive flights yesterday, I think I fried my ESC. I will probably get it fixed, but am now planning on buying another ESC less the BEC. Carlo/Chachin what ESC do you guys reccomend. I might be looking for a new motor too. I'll probably stick my Jeti/Phasor in one of my planes. Thanks, Eric |
Gainesville, FL, US
Joined Jun 2001
Hello Eric
If you never want to have to buy another motor and controller again get the B50-14L(good all around motor--please read the comments about it in this link http://www.dokidoki.ne.jp/home2/tohrus/motorindexE.html ) and a Kontronik Beat 55-6-18 or a Schulze 45Ho from http://www.icare-rc.com/ Note the Kontronik and the Schulze are both about the same price and dont have BEC's. Personally I prefer the Kontroniks because of the ease in programmming which is program it once and you are in that mode until you change it, but the Schulze are still easy to use. I do like the heat sink on the Schulze controllers. Carlo |
Gainesville, FL, US
Joined Jun 2001
Hello
I use Sermo connectors, but I think I like deans connectors better because they are easier to install and are smaller. I have a Schulze isl 330d charger. This is an awsome charger and it can charge your heli pack and your Rx pack at the same time. It is one of the best chargers out and I highly recommend it. You can find these chargers at Icare and at www.eflightpacks.com You can also find the deans and sermo connectors at eflight packs. Carlo |
Hello Eric,
I love the Kontronik Beat ESC's! I'd go with either a Beat 40-6-18 or a Beat 55-6-18 for the Eco 8. The latter one being the better choice since it can withstand higher currents. I've also heard good things about the 45Ho.. I'm just not familiar with it. I'm also planning on putting my Jeti/Phasor combo back into one of my e-planes where it works best, not that it's bad for the Eco but I want more. As far as motor is concerned, I'd definitely go with a HACKER. Snoop around Tohru's website and choose the one that suits your needs. Quote:
As far as the charger, I'm using an AstroFlight 112D to charger my stuff. It's a really good charger, but I'm sure that there are better ones out there. It can charge from 2 to 40 cells which is great. But it doesn't discharge.. . It's also DC/DC so I had to purchase a 12V converter (is that the name?) to be able to charge from a regular house outlet.Let us know which motor you are looking at. Chachin..
| Thread Tools | |
| Fresh Back From Rex Maiden Flights!!!!! | McDanger | Mini Helis | 12 | Nov 25, 2005 08:08 PM |
