Old Mar 19, 2006, 03:46 PM
arukum17 is offline
Find More Posts by arukum17
London, UK
Joined Aug 2005
How to clamp fuel tubes to a Cox .049 engine
I have a Cox black widow .049 engine that is "hidden" inside the shroud of a GP power pod. I have two silicon fuel lines (one for adding fuel and the other for overflow). I have test flown the engine on my Spirit (a blast!)
Problem:
How to I "clamp" the silicon tubes to the the inlet and outlet - it keeps slipping off when I dismantle the shroud. I have tried clamping down with wire twists but works only partially and slips out, especially when fuel is all over the place
Any ideas?
arukum17 is offline Find More Posts by arukum17
Old Mar 19, 2006, 04:33 PM
Wufnu is offline
Find More Posts by Wufnu
Pickin' an a Flyin'
Wufnu's Avatar
United States, TN, Knoxville
Joined Apr 2004
I had that problem with a small brass tube once, what I did was use a file to make a groove that the wire twist ties would get into to prevent them from slipping off. Don't know if that's possible where the engine is, but there you go!
Wufnu is offline Find More Posts by Wufnu
Old Mar 20, 2006, 05:28 AM
arukum17 is offline
London, UK
Joined Aug 2005
Good suggestion - let me see if I can do it without damaging the poor little guys mouth and arsehole
Old Mar 20, 2006, 09:32 PM
sb17joker is offline
Find More Posts by sb17joker
ProBro #2375
sb17joker's Avatar
Joined Dec 2005
take a small screw driver or awl, place in brass tube & work in a circular motion, pressing against the wall, it will "flange" the tube, or in other words make it a bit bigger, then wire tie clamp, or what I prefer, a small piece of fuel line around the end of the fuel line, about a 1/4" piece, just put it around a set of needle nose pliers, & expand it, slip the fuel line into it & release.
sb17joker is offline Find More Posts by sb17joker
Rave Rebuilding a Cox .049 Engine? Hobiestoke 1/2A Planes 23 Jul 07, 2009 06:24 AM
Discussion How to start a Cox .049 engine? arukum17 Beginner Training Area (Fuel) 2 Mar 15, 2006 01:38 PM
FS--Cox .049 Babe Bee Engine putt_13 Aircraft - Fuel - Airplanes (FS/W) 1 Sep 25, 2002 09:04 PM
