Old Mar 18, 2006, 06:16 AM
georgefromvt is offline
Find More Posts by georgefromvt
Joined Jun 2005
Best way to cut and shape styrofoam?
What is the best way to cut and shape Styrofoam? Recently I built pontoons for my GWS Pico Cub with recycled Styrofoam and did it by roughly cutting the Styrofoam with a knife, then covering the cores with a sheet of wax paper. I then used a warm iron to give the cores a pontoon shape. Afterwards, I removed the wax paper and covered them with ultra coat. Plane flies well and the balance came out perfectly. Once the ice is off the lake, I'll try a ROW. Any suggestions to cutting and shaping Styrofoam?
georgefromvt is offline Find More Posts by georgefromvt
Old Mar 18, 2006, 06:32 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I'm afraid I'm not following what you did. You were ironing the styrofoam while it had wax paper on it? Was it melting? How were you shaping it? How hot was the iron? Didn't the wax melt?
hoppy is offline Find More Posts by hoppy
Old Mar 18, 2006, 08:30 AM
Joined Jun 2005
The wax paper kept the styrofoam from sticking to the iron. By having a layer of wax paper between the iron and the styrofoam, I could melt melt the styrofoam enough to give it a smooth surface and shape. After I finished with the iron, I peeled off the wax paper and covered the pontoons with ultracoat. It worked pretty well.
Old Mar 18, 2006, 08:47 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Never heard of that before, but if it works...
I have not done much with foam yet but hot wire is the usual thing for making wings.
There is a thread somewhere here about making a styrofoam plane with knife, balsa plane and sand paper.
perttime is offline Find More Posts by perttime
Old Mar 18, 2006, 08:50 AM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
hot wire
the classic way to cut polystyrene is using a hot wire.
what you do is build a "bow" withe a metal wire wich is heated by a electrical curent.
must say i like the idea of smoothing the surface of foam with wax paper / iron , never thought of that
edit; it apears more then one where replying at the same time
cmulder is offline Find More Posts by cmulder
Old Mar 18, 2006, 07:06 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
One of the better threads on hot wire foam cutters. Lots of info here: http://www.rcgroups.com/forums/showthread.php?t=287621
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Mar 18, 2006, 08:12 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
Sounds like you found a winner in forming styro. Keep practicing and you'll only get better at it..Pilot
62pilot is offline Find More Posts by 62pilot
Old Mar 20, 2006, 12:37 PM
rockin' roller is offline
Find More Posts by rockin' roller
United States, TX, Dallas
An electric fillet knife can be used to cut most types of foam. It works better than a regular knife, but not as well as a hot wire.
rockin' roller is offline Find More Posts by rockin' roller
Old Mar 20, 2006, 12:44 PM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
I've not heard of an electric fillet knife. Is it heated or is it like an electric carving knife that is kind of like an electric hedge trimmer (ooohhh, there's and idea - well maybe to be reasonable, how about a sabre saw with a knife blade)
Walt
Kokopeli is offline Find More Posts by Kokopeli
Old Mar 20, 2006, 12:58 PM
Skonkworkstexas is offline
Find More Posts by Skonkworkstexas
Survival is Attitude!
Skonkworkstexas's Avatar
Hallsville Texas
Joined Aug 2005
Let me get this right-when you pulled the wax paper off the styro was smooth like Blucor? I know whenever I have overheated styro, the balls just get bigger and uglier.
Skonkworkstexas is offline Find More Posts by Skonkworkstexas
Old Mar 20, 2006, 01:22 PM
Figbash is offline
Find More Posts by Figbash
Figbash
Farmington Hills, MI
Joined Jan 2006
Another way to make them would be to build a hollow structure out of Blucor fan fold foam. You could cut out a few formers for the shape and then either wrap the foam around them or glue flat pieces to them. Low temp hot melt glue is my adhesive of choice. By making your pontoons hollow instead of solid foam, you would save a significant amount of weight.
I just built a fuselage last night using this technique and it worked out great. As long as you keep the skinned side of the foam on the outside of the bends, it will fold 180 degrees back on itself without tearing.
Tom
Figbash is offline Find More Posts by Figbash
Old Mar 20, 2006, 01:26 PM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
Band sawa or jig saw custs foam nicely. Simple sanding after is all that is needed. There's a great thread about cutting pontoons somewhere...
rutat is offline Find More Posts by rutat
Old Mar 20, 2006, 03:38 PM
Walt
I'm sorry Walt, I mean an electric carving knife. We just used to use them exclusively for cleaning fish, and making fillets out of them. The sliding blades cut foam much more cleanly than an ordinary blade.
Old Mar 20, 2006, 07:04 PM
Joined Jun 2005
My cub flew great!
I was able to get a couple of ROGs in yesterday before the wind came up. It flew great and doing touch and goes on the snow was flawless. Balance seems fine and I am anxious for spring to come so I can get some ROWs in once the ice is off the lake. Here in Northern Vermont, spring doesn't come till May!
Using a warm iron to shape styrofoam worked well for me. Thanks for all the advice.
Old Dec 14, 2007, 07:20 AM
cesareDH is offline
Find More Posts by cesareDH
Joined Dec 2007
Cutting Strofoam
[QUOTE=georgefromvt]
http://www.thecraftplace.com/store/m...Product_ID=327
cesareDH is offline Find More Posts by cesareDH
best way to cut coroplast? geep Foamies (Kits) 2 Jan 31, 2003 05:07 PM
What is the best way to cut ply formers? flyingace15 Electric Ducted Fan Jet Talk 32 Dec 10, 2002 09:19 AM
Best way to cut lightening holes DNA Power Systems 13 Oct 03, 2001 10:15 PM
Best way to cut larger holes in balsa?????? Dandi6065 Power Systems 3 May 14, 2001 02:13 PM
