Old Mar 17, 2006, 05:15 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Notched leading edges
Anyone have any comments about the notched leading edge article in the April issue of Quiet Flyer? Done by the Seleig team, noted for their wind tunnel work on model airfoils. The tests they ran both in the wind tunnel and in the air indicate a reduced (softer) stall and elimination or reduction of wing rock in harrier.
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Mar 17, 2006, 12:27 PM
TRuss is offline
Find More Posts by TRuss
United States, OR, Salem
Joined Jan 2004
I haven't seen that yet, but it is probably some form of turbulator. There is actually some discussion about this in the indoor/F3P forum.
At really low reynolds numbers it can be best to introduce a turbulent flow, as at these really low speeds a laminar flow may have a seperation bubble form between it and the surface. Since a turbulent flow is actually easy to control and manipulate, and it actually sticks to the surface then this is the best way to handle this. So, people started experimenting probably twenty or thirty years ago with turbulators. Full scale competion glider pilots will sometimes put just a strip or sometimes a zigzag pattern of tape on the top of the wing to turbulate the flow. It takes some trial and error to figure out the ideal placement.
So, I'd guess these notches are somehow related to this.
TRuss is offline Find More Posts by TRuss
Old Mar 17, 2006, 08:15 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
i've used strips of nyrod taped to the top near the LE outer half span.. and it worked,.. but now i just fly planes that dont wing rock
spastic is offline Find More Posts by spastic
Old Mar 19, 2006, 05:34 AM
Mister E man is offline
Find More Posts by Mister E man
The God in God-mantooth.
is
Joined Feb 2005
Sounds like a better mousetrap, I think it may be the only way to go for any serious indoor/outdoor 3d pattern pilot... Plus it looks pretty menacing to see the serrated leading edges, im sure someone will encorperate that fact into a design that looks pretty less strange...
for those of you who havent seen or read it, the leading edge of the wing normally looks like this => ________________ (flat. Normal.) but the leading edge of the new and improved foamy wind looks like this => __/\/\/\/\/\/\/\/\/\/\/\__
Mister E man is offline Find More Posts by Mister E man
Old Mar 19, 2006, 09:05 AM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
I messed around with that "zig-zag" sewing tape on some of my slope gliders many years back. It realy helped on the calm wind days. I used to put it just ahead of the thickest point on the airfoil. Everybody thought I was nuts... But then we could all realy see the difference in how long I could stretch a calm wind glide. Cool idea... Maybe I should cut out some "saw tooth" 3DX wings and see what it does.
Actually, I've been thinking of making some little depron "chuck gliders" to test some of these leading edge configurations. Every time I think about it though, It's blowing at 30kts outside... No good for chuckies...
Tim H.
Tim H. is offline Find More Posts by Tim H.
Old Mar 19, 2006, 10:46 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Tim H.
The 3DX would be a great test bed for this, I may just modify mine. It's basically the same principle and has the same affect as putting a turbulator at or just in front of the high point on a traditional "airfoiled" wing, however it moves the turbulator to the leading edge. Here's a quote from the article:
"Well, small scale turbulence at the very front of the wing causes exactly that. It flattens the lift peak just before the stall and fills in the valley after the stall. This means you don't play the throttle and elevator so much as you move between cruise, stall, and harrier"
Azarr
www.ecubedrc.com
Old Mar 20, 2006, 11:23 AM
TRuss is offline
Joined Jan 2004
I had to go out this weekend just to buy this issue to see the photos firsthand. Cool stuff.
Old Mar 20, 2006, 01:41 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
Hmmm.... Very interesting. I will have to check my collection of QF to see if I have this on or not. I would like to know more about this.
NumbSkull is offline Find More Posts by NumbSkull
Old Mar 20, 2006, 01:54 PM
TRuss is offline
Joined Jan 2004
It's the newest one.
Old Mar 20, 2006, 02:56 PM
NumbSkull's Avatar
Joined Mar 2005
Nope, don't have it yet, the latest one I have is March. Will have to go and pick it up. Maybe tonight...
Old Mar 20, 2006, 06:50 PM
Daniel Z is offline
Find More Posts by Daniel Z
Daniel Z's Avatar
Joined Dec 2004
any pics??
Daniel Z is offline Find More Posts by Daniel Z
Old Mar 20, 2006, 06:56 PM
NumbSkull's Avatar
Joined Mar 2005
Yes, pics please!!
I think I understand what is going on, but not sure of where on the wing. I see that you should place it just before the thickest part of the airfoil, but how far in front, and how much of the length of the wing?.
Old Mar 20, 2006, 09:08 PM
is
Joined Feb 2005
Like this
Old Mar 20, 2006, 09:39 PM
NumbSkull's Avatar
Joined Mar 2005
That I understand, but do you put it on the leading edge of an airfoiled wing too? or just infront of the thickest part of the airfoil?
Old Mar 20, 2006, 09:58 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
You put it on the LE of a flat plate wing.
arx_n_sparx is offline Find More Posts by arx_n_sparx
Aerodynamic question about Leading Edges PDX Slope Pilot Modeling Science 2 Feb 27, 2003 10:41 PM
How to do leading edges on vac bagged wings? chlee Electric Sailplanes 7 Mar 04, 2002 08:37 AM
