| Thread Tools |
| This thread is privately moderated by Doug Sipprell, who may elect to delete unwanted replies. |
Kip:
From what I understand, Elfi II was to be marketed direct from the distributor in Germany, the plane itself probably being built in the Czech Republic. I would have to check my notes on that. Ostensibly, a few have made it over the pond. I have yet to get one, might do it just to add to the collection and see the improvements. I have the three Elfi's shown above flying. Two more in the box, one a non-aileron and one an aileron version. I wanted to keep Elfi 3 as retro, but flying a speed 280 plane on a 2S1P LiPoly leaves alot to be desired in the power department. A 3S1P will smoke the motor for sure. Also, never realized how inefficient the original 3-bladed prop is. However, I do manage to get flights in on #3. The PJS B/L motors on Elfi's #1 & #2 do a real fine job, especially on 3S1P 1500 packs. thanks for your note. Keep in touch. Nice to know you are still flying your Elfi. RD |
Latest blog entry: Big Red Cadillac
Elfi B
For those of you who are Elfi enthusiasts, here again is the information on the latest Elfi, known as Elfi B. If anyone out there has this version of the Elfi, please let me know.
"Elfi B The Elfi B is fun sized Park flyer styled on an Ultra-light aircraft. The low flying weight and slow flying speed ensure a realistic flight performance. The less experienced pilot will appreciate the well balanced easy handling of the model whilst the more experienced plot will want to explore the extraordinary agility of the model by performing the tightest of manoeuvres in the smallest of spaces, making the Elfi B a fantastic all-round fun machine. The one-piece built up wing is covered in transparent Oracover. The GRP and Carbon fibre fuselage has the motor mount fitted and the wing retaining holes drilled and tapped. The tailplane and fin are covered and the control surfaces cut and hinged. An Accessory pack and full instructions are included in the kit ensuring quick and easy completion of the model. The model is delivered without motor and prop. Optional Aileron " Homepage: www.fvk.de Technical questions should be addressed to:- Brian Anderson Tel: **44 191 3887649 e-mail: Technical questions RD |
Brushless Elfi's
Bob, Kip:
I continue to have good luck with PJS Brushless Motors, from Hobby Lobby, as installed now on all three (3 !) of my Elfies. Elfi #1: PJS 3D 500 Elfi #2: PJS 3D 550R Elfi #3: PJS 3D 550 I was concerned about how I would mount the motor on the 10mm carbon fiber tube of the Elfi. Hobby Lobby has an aluminum sleeve fitting that allows a PJS or other brushless motor that has a shaft mount to be installed directly on the carbon tube of the model. So, I used that mounting method, routing the three wires parallel to the tube and then into the fuselage thru a slot cut into the fuselage. Performance has been good, using either 8x6 or 9x6 APC props. I use a Kokam 1500 3S1P on Elfi #1, a TP 2000 ProLite 3S1P on Elfi #2, and a TP 1320 3S1P ProLite on Elfi 3#. Yes, I can use the 1320 pack on all three planes if I so choose. 15-18 minute flights the norm, and I do NOT pull the packs down to low voltage cutoff. Elfi Power!! RD
Well, I guess I will have to contact the Elfi factory and get an Elfi B on order, just to fill out Elfi fleet. Had Elfi #3 up today, it flys very well on the PJS 3D 550 motor, with 3S1P TP 1320 ProLite pack.
Elfi's forever!! RD |
Elfi B Order Info
Here is as synopsis of the information I have on hand concerning the status of and the ordering procedure for the Elfi B. This information was supplied to me by Brian Anderson, the UK tech service and sale rep for FVK. I thank him for the information, hopefully it will be of interest and help to those interested in the latest version of the Elfi. Apparently, you can get the aileron version of the plane with a single servo linkage, as was the case with the original "Elfi with ailerons", or you can get the plane with a dual servo arrangement for the aileron version of the plane. The dual aileron servo arrangement IMHO is the better way to go.
Info as follows: 1.) The Elfi didn't go out of production, FVK stopped dealing with NES. 2.) The Elfi is available direct from FVK in Germany. Contact FVK via their website. http://www.fvk.de/Englisch/Elfi%20B.html Pricing is in Euros - not US $. 3.) The "B" version of the Elfi was introduced to take the modern breed of brushless outer runners. The Aileron version is available in two different (configurations): a.) Single, centrally mounted servo with ailerons actuated via bowden wires. b.) Two servos, one for each aileron. The Elfi - B has the single central servo, same as the original (aileron version) Elfi. The Elfi - Q has a separate servo which is directly linked to each of the ailerons. The model will not be supplied with a motor drive. This (allows) the customer to (use) their choice of drive unit. 4.) At the moment FVK do not have any agents in the USA, It is probably cheaper to purchase directly from FVK in Germany than from a USA agent. The website price would be reduced by approximately 15% or 16%, as the German Tax would be removed for Non European residents 5.) The OLD Colors could be specially ordered, delivery would take a little longer. |
| Thread Tools | |
| Calling all Zagi's near Metro Detroit | Mihelich | Foamies (Kits) | 0 | Jun 26, 2005 01:16 PM |
| Calling all electronic gurus that use RC rx's! That means you! | cadconversions | DIY Electronics | 20 | Mar 30, 2005 10:08 PM |
| Calling all electric BOT's | ThePitchedLink | Electric Sailplanes | 13 | Feb 20, 2005 10:15 PM |
| Discussion Poll: Calling all those who own Hitec's Optic 6 TX | LexTalionis | Radios | 45 | Nov 27, 2004 08:04 PM |
| Calling all cars... Calling all Cars - There's an Omega 1.8E on the loose! | Joedy | Electric Sailplanes | 3 | Mar 12, 2003 06:28 AM |
