Old Mar 16, 2006, 09:08 PM
tomi is offline
Find More Posts by tomi
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
Help!
Train smoke unit
I have never seen a smoke unit in a train before and cannot find anything about these smoke units.
Instead of using smoke bombs, I thought it would be a neat idea if we can stick a train type smoke unit into a Electric plane.
Any thoughts?
-Tomi
tomi is offline Find More Posts by tomi
Old Mar 16, 2006, 10:02 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
In a full scale aerobatic plane, the smoke comes from a smoke generator in or around the exhaust. A fluid(usually some type of light oil) is pumped into the generator, and is burned by the exhaust heat. The smoke units for electric trains are similar, a light oil is burned by a nichrome heater wire. I don't think trains usually have a pump for the fluid. I would think you would need a lot more smoke for an electric plane than you would for a train. Don't know how much power you would need for a nichrome heater.
This article describes smoke systems for fuel powered models. http://www.mdw-aviation.com/MDW_smok...m_a_primer.htm For an electric model, you would need to substitute a nichrome heater for the hot exhaust.
Here is an electric smoker for model paddle wheel boats, and it says it takes 2.5 to 3 amps at 12 volts. http://www.paddlewheels.co.uk/smoke.html
jeffs555 is offline Find More Posts by jeffs555
Old Mar 16, 2006, 10:59 PM
tomi is offline
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
i already know about the engine smoke. That's simple. Just don't know how electric smoke units work.
thanks for the links. I'll take a look..
-Tomi
Old Mar 16, 2006, 11:34 PM
Aethertek is offline
Find More Posts by Aethertek
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
http://www.micromark.com/
Part #82602 Smoke Generator
#82603 Smoke Fluid
Aethertek is offline Find More Posts by Aethertek
Old Mar 17, 2006, 03:59 AM
Johan B is offline
Find More Posts by Johan B
Johan Beyers Eflight101
Stellenbosch, South Africa
Joined Feb 2005
I'm not sure a train unit will generate enough smoke to be visible on a plane. You need a LOT of heat to generate enough smoke. Since the glow engines are so inefficient, their exhaust generates all the heat you need, but I guess you'll probably have to put at least 100 watts (say, 10 amps from a 3S lipo) into a smoke generator to make enough smoke to be useful.
If I look at the pictures on the paddle boat generator, it makes about the same amount of smoke as a just-blown-out candle for 25-35 watts of input.
Johan - Eflight101.com
Johan B is offline Find More Posts by Johan B
Old Mar 17, 2006, 01:58 PM
tomi is offline
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
I forgot to mention about what type and where the plane would be flying.
I would put it on a small foamy plane that flies at a resonable speed. Not fast, but not too slow. So the smoke trail can still be seen. Also, the place of flying would be indoor. It should make a great indoor show. I'm sure it will work pretty well indoor, but outdoors, you'd probably wouldn't even see a poof of smoke
Old Mar 17, 2006, 04:45 PM
Mikael Pedersen is offline
Find More Posts by Mikael Pedersen
Certified Propellerhead
Copenhagen, Denmark
Joined Mar 2001
Here is a list of smoke units, that we normally use in model trains. Voltages and currents are listed:
http://www.mgsharp.com/Seuthe.htm
And here is a video of one of my trains. That will give you an idea of the amount of smoke, you'll be able to get from one of these:
http://www2.ejberg.dk/external/marklinusers/39103-2.mpg
The smoke unit used in this lok is a Seuthe number 10, driven at the high end of its voltage span (if I rememer correctly).
Mikael Pedersen is offline Find More Posts by Mikael Pedersen
