This thread is privately moderated by P. Tritle, who may elect to delete unwanted replies.
Old Dec 16, 2007, 11:08 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Or just magnetise the screwdriver .
lake flyer is offline Find More Posts by lake flyer
Old Dec 18, 2007, 07:46 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Originally Posted by P. Tritle
When was the last time you burned your wife's thumb trying to solder wires together. Since you only get to do that once, I made this tool to hold the wires together during the soldering process. It only takes 2 wooden cloths pins and a couple scraps of hard balsa or light ply to make, and never complanes when I touch it with a hot iron!
You CAN buy this one:
http://www.readyheli.com/Helping_Hand_p/hhand.htm
Also available at most electronics stores.
Pinecone is offline Find More Posts by Pinecone
Old Dec 18, 2007, 08:39 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
I use one and I have three complaints. It leaves marks on the insulation. It is very difficult to use with fine wires (which I tend to solder often) and it is nearly worthless with small pc boards.
Wooden clothes pins do work better for some of this and when I get home I will post an image of soldering to a tiny video camera using a clothes pin. I absolutely would not stick that into the helping hand device!
Aside from these complaints I do use the helping hand a lot, but only with thick wires for high amperage. My more delicate stuff is done with clothes pins or by hand. The very thin stuff solders almost instantly and the thin wires conduct very little heat to your fingers.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Dec 18, 2007, 10:01 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I also use the clothespins a lot. Sometimes just clamped in a vise. At times I get a block of wood and glue them at a specific angle for a certain job. I have small ones and large ones. Besides soldering helpers they make nice clamps
Oh, and silver soldering (brazing) is not good with wood clothespins. They tend to catch on fire unless a long way from the joint
The 'helping hands' rig is also usable with clothespins. Put one in each of the alligator clamps, then adjust as needed. That way you get the benefits of both.
And, when solldering three (or more) wires together you can glue multiple clothespins together, or to a popsicle stick, then clamp it to something solid.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Dec 18, 2007, 12:43 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I have done that, but once in a while, the allen heads still fall off the magnitized head...and always in an annoying place. I have never lost a screw using the silicone fuel line over the ball driver.
Works well with small Phillips screws and screwdrivers, as well
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Dec 19, 2007, 05:32 PM
PeteSchug's Avatar
Joined Apr 2004
Pete
Sorry, I missed last night.
Here are two pix of stuff I prefer wooden clothes pins for. BTW, I have not yet flown this little camera. I want to put it into a Curtiss Pusher so I have a clear view forward.
Pete
Old Dec 20, 2007, 01:10 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Wow.. This is a pretty good thread..
I do not have any pictures of tools I have made, as I am on the road, but I'll have to post some when I get back..
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jan 05, 2008, 09:51 AM
toni.b-r is offline
Find More Posts by toni.b-r
When I'm not flying......
toni.b-r's Avatar
Emsworth, UK
Joined Jan 2004
Washout check
Ever need to check the washout on a long wing with dihedral? Propping it up and checking the distance from board to LE then board to TE is one way, but my way is to rubber band a dowel to the bottom of the end of each wing, with excess poking out the back. Then you can eyeball the two dowels and see straight off if the angle of the wing ends is the same. It works well on flat-bottomed wings, but as long as there is a portion of flat somewhere on the bottom of the wing to set the dowels against, it should work.
The pics are of my 72" Fournier wing - it kept turning right on the first flight after an 18 month layup, with disastrous results! After warming and twisting, I now know the two wings have the same washout.
toni.b-r is offline Find More Posts by toni.b-r
Old Jan 24, 2008, 07:00 AM
nickchud is offline
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Originally Posted by JMBRAD
Pat,
Thank you for sharing your secrets. You may make a plane builder out of me yet, instead of just a poor pilot.
Jody
Me too!
I'm so glad I found this thread!
Nick
nickchud is offline Find More Posts by nickchud
Old Jan 24, 2008, 07:24 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
The Basic Anti Lock Soldering Accessory.
Protecst the wheel from melting and sets the end float exactly..
Old Jan 24, 2008, 12:53 PM
planeman is offline
Find More Posts by planeman
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
Vintage, that looks like a piece of balsa. I do the same thing using a piece of paper. I just poke a hole in the paper the same size as the wire with a tapered needle and slip the paper onto the landing gear between the wheel and the washer to be soldered onto the wire landing gear, being sure to get a tight fit of the hole in the paper and the wire. I use rosin soldering paste. The paper (1) acts as a gasket to keep the heated soldering paste from running into the wheel and wire bearing surface (the hole in the wheel) and (2) the paper acts as a spacer to give just the right amount of clearance between the spinning wheel and the soldered washer. When finished, just tear the paper away from the axle. Works great!
Planeman
planeman is offline Find More Posts by planeman
Old Feb 24, 2008, 11:52 AM
Carl is offline
Find More Posts by Carl
Carl's Avatar
Everett, WA, USA
Joined Dec 1996
I posted this in another thread but I thought it should be posted here also. To cut sticks to to the proper lenght and angle I first used a razor blade to roughly cut to length. I then use the a bench dog and a Perma-grit sanding block to fine tune it to length and angle. If I have a lot to cut to the same angle, the cross pieces on a tapered fuse, I will cut one piece and then put a wedge next to the fence and use it so that I can get constant angles and only have to worry about the length.
Carl
Carl is offline Find More Posts by Carl
Old Feb 14, 2010, 10:16 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
4" table saw with diamond blade
Here's one of the best tools you can have for scratch building or repairs. Well worth the money. Marty
http://www.harborfreight.com/cpi/cta...emnumber=93211
martys is offline Find More Posts by martys
Old Jul 05, 2010, 08:10 AM
rpd is offline
rpd
Find More Posts by rpd
rpd
Indiana
Joined Sep 2003
I learned this one from Ray at Skybench aerotech. Ziplock bags filled with sand make great weights for holding down wing sheeting and other uses. They conform to whatever shape they are over and don't gouge balsa or foam like hard weights. You can make all different sizes and weights.
rpd is offline Find More Posts by rpd
Old Jul 05, 2010, 08:44 AM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
Reusable ice packs such as what you toss in your picnic cooler also work as flexible weights. They're surprisingly heavy - and you probably already have several!
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Discussion Free Country? Why can't I buy beer on Sunday? lakedude Life, The Universe, and Politics 72 Feb 29, 2016 07:45 AM
Discussion Can't I buy a catapult/launcher??? albireo Electric Ducted Fan Jet Talk 69 Nov 25, 2014 06:38 PM
Please Help...Can't decide which tires to buy!!! mefly2 Life, The Universe, and Politics 3 May 08, 2002 12:53 AM
Tools you can't live without. Jim McPherson Electric Plane Talk 69 Oct 31, 2001 11:20 AM
Best Tx money can buy henke Electric Plane Talk 9 Jul 23, 2001 06:56 AM
