This thread is privately moderated by P. Tritle, who may elect to delete unwanted replies.
Old Feb 09, 2012, 12:42 PM
Won2Race is offline
Find More Posts by Won2Race
Won2Race's Avatar
United States, MA, Boston
Joined Jun 2006
You could make a bigger version of the MA stripper out of wood. The adjustability of the width would be a challenge, though, but now insurmountable.
Won2Race is offline Find More Posts by Won2Race
Old Feb 09, 2012, 01:21 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I've been toying around with using the fence for my band saw, some spacer blocks, and a utility knife blade. Just haven't had a chance to cobble something together yet.
rcav8r2 is offline Find More Posts by rcav8r2
Old Feb 15, 2012, 10:13 AM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
The Tools Money Can't Buy
JIGS are good for building and storeage of RC plane body on the bench or on the road. Note the old Gell-Cell Battery as a weight.
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Feb 15, 2012, 11:14 AM
grubbyjeans is offline
Find More Posts by grubbyjeans
The Low-wing Super Cub
grubbyjeans's Avatar
Houston, TX
Joined Sep 2007
We must be on the same channel! Here are pics of jigs I used in construction of the fuse for my SkyCoupe.
grubbyjeans is offline Find More Posts by grubbyjeans
Old Mar 18, 2012, 05:34 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
This is a tool i have built yesterday, because i needed something to draw a precise line around a round shape (nose cowl) to obtain a reference line for a dremel cut.
I don't know how to call it, maybe someone can suggest a name for this tool eheh.
It can be used for example to draw panel lines, using the drawing as reference and then scale the measure. You set the position of the pen and you draw the line.
The base is a piece of wood i had in the shop. Drilled an hole and put a 10mm diameter x 1 meter lenght aluminium tube. Fixed with PU glue.
The mobile piece is another piece of wood, with one hole for the aluminium tube, one for the pen/pencil, and one for a screw so i can fix the vertical position.
Time to built : 30 minutes
(sorry for my english, pictures are better than words)
Dave
FlyDave is offline Find More Posts by FlyDave
Old Mar 18, 2012, 09:56 AM
turaboy is offline
Find More Posts by turaboy
turaboy's Avatar
USA, VA, Centreville
Joined Jan 2003
How about "surface gage with pen"?
http://www.google.com/search?q=surfa...80&bih=268#p=0
turaboy is offline Find More Posts by turaboy
Old Mar 18, 2012, 11:58 AM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Hem Gauge
Originally Posted by FlyDave View Post
... I don't know how to call it, maybe someone can suggest a name for this tool ... It can be used for example to draw panel lines, using the drawing as reference and then scale the measure. ... Dave
You have a slightly simplified dress hem marker device. The tool for marking a dress hem line uses chalk to mark the cloth while the dress is being worn. They also use a ruler rather than a dowel rod for the upright stay. Some designs used a small jar that contained powdered chalk/baby powder and you would puff chalk dust on the cloth to mark the hem line. Your version can be a very useful spin on the idea and design to mark a cut line on a tube or other shape.
Tsavah is offline Find More Posts by Tsavah
Old Mar 18, 2012, 04:19 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
I get styrofoam coolers that sea foods are shipped in. Use them and throw away. The sea food place is glad for me to take them. Have to wash to get rid of fish smell.
Raften is offline Find More Posts by Raften
Old Mar 19, 2012, 10:57 AM
jaksno is offline
Find More Posts by jaksno
jaksno's Avatar
Norwood, CO
Joined Jul 2009
Dave
Looks good. A really simple idea for use in very simple cases: make some reverence marks, wrap with blue painter's tape, draw along the edge.
jo
jaksno is offline Find More Posts by jaksno
Old Mar 21, 2012, 06:13 PM
kdahlhaus is offline
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
thanks Matt, I will soon be stripping some balsa and will give that a try.
kdahlhaus is offline Find More Posts by kdahlhaus
Old Aug 21, 2012, 06:35 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Looks great bud, much like my old faithful MAS stripper, nice job!
Craig
trumps is offline Find More Posts by trumps
Old Feb 12, 2013, 02:04 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
New Batteries for Cordless Dremel 7700,7.2 volt Rotary Tool
I used my Dremel 7700 mostly for grinding my three dog's toenails. The original NICD batteries didn't hold a charge well and had very short duration. I read about how to open the battery module and install six NiMH cells. I was able to pry the end up enough and use a small screwdriver to release the holding tabs and get the end off the module. There were two sets of three AA nicads connecteed in an "L" configuration. I went to a local battery place and bought 1650mah Nicads, two with long solder tabs and four without. I had to solder tabs to ends of two cells quickly to avoid damaging them. I had to pack some foam rubber under the retention tabs that hold the module into the charger or the tool itself so they would latch securely.The module snapped back together OK. The tool now has plenty of run time for other uses than dog grooming. This may be possible on other Dremel cordless rotary tools.
E-Challenged is offline Find More Posts by E-Challenged
Old May 13, 2013, 03:06 AM
eye4wings is online now
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Well, I've ploughed through this entire thread and failed to find the thing I REALLY need right now...
which is a 90 degree chuck so I can drill a hole in a ply firewall close to the fuselage side where I can't get access any other way.
What I have in mind is using a small chuck for a 3mm drill bit then adding some kind of ratchet with a handle. I can just get in far enough to push the end into the firewall with a thumb while operating the ratchet handle with the other hand. It would be a long job that way - and I'd have to get a friend to make up the tool for me, but I can't think of another way to do it now the nacelle is complete.
It would also come in handy for screws where the screwdriver can't get straight at them.
Has anybody seen anything of this kind on the market?...
PLEASE???
eye4wings is online now Find More Posts by eye4wings
Old May 13, 2013, 04:40 AM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
I suppose you can not use the Dremel 90 degree attachment? maybe that could fit in..
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Discussion Free Country? Why can't I buy beer on Sunday? lakedude Life, The Universe, and Politics 72 Feb 29, 2016 07:45 AM
Discussion Can't I buy a catapult/launcher??? albireo Electric Ducted Fan Jet Talk 69 Nov 25, 2014 06:38 PM
Please Help...Can't decide which tires to buy!!! mefly2 Life, The Universe, and Politics 3 May 08, 2002 12:53 AM
Tools you can't live without. Jim McPherson Electric Plane Talk 69 Oct 31, 2001 11:20 AM
Best Tx money can buy henke Electric Plane Talk 9 Jul 23, 2001 06:56 AM
