This thread is privately moderated by P. Tritle, who may elect to delete unwanted replies.
Old Dec 15, 2011, 06:44 AM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Interesting and Simple Modifications
Originally Posted by mkeveney View Post
Here's one I discovered some time ago; maybe new to some of you. I've had bad luck with my 'Master Airscrew' balsa stripper when cutting anything but the lightest stock. The blade wanders or slips in it's clamp, giving a terribly inaccurate cut. Instead use a 'base' piece of 1/8" ply. The blade should be extended enough to poke into the ply a bit. This keeps it from wandering. Then grip the stripper and the ply in one hand, and feed the stock through with your other. ... -Matt
I can see how this would work pretty well when needing to cut larger/thicker balsa strips. I suppose the only other option would be a table saw like Micro-mart and others sell.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Dec 15, 2011, 07:55 AM
martys is offline
Find More Posts by martys
Check your six
martys's Avatar
New Jersey
Joined Sep 2002
For really tough stock, clamp the stripper to the ply piece as shown. I have a pair of 1" C-clamps that are perfect for the job.
With this setup I can accurately strip stock up to 1/4" thick, even from very dense balsa.
-Matt
Excellent idea Matt! I have 2 of these tools. I found the same thing happening to me. I like your idea very much and I'll be sure to use it next time! Thanks! Marty
martys is offline Find More Posts by martys
Old Dec 15, 2011, 08:03 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
GREAT idea on the MA stripper. I was going to cobble something together using a utility knife blade for this reason, but now I think I'll try this first. Sure will be a lot simpler.
rcav8r2 is offline Find More Posts by rcav8r2
Old Dec 21, 2011, 04:27 PM
Trevorh is offline
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
I want to daub some paint around inside the wheel wells on my DH88 Comet and would really like to find a small brush with the business end cranked through 90 degrees. So far, I haven't found anything so, before I try butchering an existing brush, I wondered whether anybody had a good solution to the problem - and please don't tell me to paint the inside before sheeting the nacelles in
TIA
Trevor
Trevorh is offline Find More Posts by Trevorh
Old Dec 21, 2011, 04:33 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Originally Posted by Trevorh View Post
I I wondered whether anybody had a good solution to the problem - and please don't tell me to paint the inside before sheeting the nacelles in
TIA
Trevor
Before you sheet, paint..... ahhh never mind...
Try and find a paint brush with a plastic handle. Gently heat the handle and bend. I've done this a few times. Works well with the smaller "artist's" brushes they sell for kids.
Old Dec 21, 2011, 04:55 PM
No Step is offline
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
Q-tips. Remove as much cotton as you need if necessary, bendable-even 90 degrees, toss out when done. I'd be lost without Q-tips.
No Step is offline Find More Posts by No Step
Old Dec 21, 2011, 06:40 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I have a 3/8" flat brush that I bent the ferrule about 60 deg. I use it quite a bit for those places I "forgot" about while building. Or, to get glue (water soluble) into a spot for the same reason.
portablevcb is offline Find More Posts by portablevcb
Old Dec 22, 2011, 02:27 AM
Trevorh is offline
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Thanks guys. I had thought of impaling a bit of foam on the end of an Allen key, but the idea of bending Q-tips hadn't occurred to me. I'll have a go at bending a brush or two, too.
Old Dec 22, 2011, 05:00 AM
RadioActive is offline
Find More Posts by RadioActive
Master of the Touch and Tumble
RadioActive's Avatar
On the green side of the Grass
Joined Jan 2005
I cut some foam from a foam paint brush and use forceps to hold it with. You can adjust the grip to reach most any place.
RadioActive is offline Find More Posts by RadioActive
Old Dec 28, 2011, 12:04 PM
mag1 is offline
Find More Posts by mag1
Greenville, Wi
Joined Nov 2004
-Matt
That's a good one Matt. I havn't tried it yet. Here is my solution, just finished it, but havn't set it up yet. I need to get the right diamond wheel yet.
http://www.railroad-line.com/forum/t...TOPIC_ID=20046
I made it to handle 36" long sheets.
- ok, now I had a chance to try it, i didn't buy the right blades, I think it will work better on thinner stock, I was cutting 3/16" thick, took some time, Also need to set up to use my larger shop vac.
- As to Matt's solution, that works really good. On harder balsa, It didn't work the best for me, but may with more practice.
mag1 is offline Find More Posts by mag1
Old Jan 04, 2012, 09:09 AM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
angled brushes
Head over to the plastic display model store and look on their tool supply board. I found that various sizes of bristle-tipped onetime applicators are available, and they're meant to be bent to fit the job. Kinda' like a q-tip if such was made for paint. These are sold in blister packs, and I've used the smallest of them very successfully for display model details
PeterH is offline Find More Posts by PeterH
Old Jan 04, 2012, 10:51 AM
Trevorh is offline
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Thanks for that Peter. Meanwhile I have managed to bend a couple of standard brushes to about 45 degrees so will see how I get on with those first. I'll have a scout around the plastic modellers' counter next time I get the chance - all I turned up on Google was cosmetic brushes and applicators - at fashion-premium prices!
Old Jan 24, 2012, 10:01 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Now where is my right angle drive attachment for my Dremel tool? Comes in handy for drilling or cutting with a cutoff wheel inside a fuselage or wing structure when making crash repairs. A mini Jacobs chuck makes changing drill bits or accessories much quicker and easier. My new Sony ICF-38 AM/FM AC/DC portable radio just came from Amazon . Small size, good sound, good selectivity will keep me company whilst building models etc., and all for $26.47 including shipping. Also available at Target, Fry's when in stock.
E-Challenged is offline Find More Posts by E-Challenged
Old Feb 08, 2012, 11:50 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
There was a ' How to' make your Master Airscrew Stripper work well thread in HPA
The Black base needs squaring as it must come out of a mold. so it has a slight vertical taper : sand it out.
Then snap the very end off the #11 Exacto blade.
It's the tiny tip that causes the wandering apparently
Did both to mine and it works!!... Perfectly.... Try it??
Bare is offline Find More Posts by Bare
Old Feb 08, 2012, 11:58 AM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Yep, I found this out accidentally ...Works very well with smaller stock, but I still would like to make something a little better for larger stock.
Discussion Free Country? Why can't I buy beer on Sunday? lakedude Life, The Universe, and Politics 72 Feb 29, 2016 07:45 AM
Discussion Can't I buy a catapult/launcher??? albireo Electric Ducted Fan Jet Talk 69 Nov 25, 2014 06:38 PM
Please Help...Can't decide which tires to buy!!! mefly2 Life, The Universe, and Politics 3 May 08, 2002 12:53 AM
Tools you can't live without. Jim McPherson Electric Plane Talk 69 Oct 31, 2001 11:20 AM
Best Tx money can buy henke Electric Plane Talk 9 Jul 23, 2001 06:56 AM
