This thread is privately moderated by P. Tritle, who may elect to delete unwanted replies.
Old Jul 08, 2010, 06:32 AM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
Well I found one photo and that should be enough.
The non-slip screwdriver (boltdriver) needs a metal tube to fit the outside of the wing bolt, a short piece of steel wire that fits in the bolt's slot, and a short piece of silicon tubing or similar as a hand grip. The metal tube is drilled for the steel wire at the correct location, which is glued or soldered. That is all, except for slipping on a silicon tube or similar as a hand grip.
The one I built for my Stinson has a tight fit, so it holds the bolt in it when I screw it in place or remove it. The bolt is not on the outside surface, so that works well for insertion/removal..
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Old Jul 08, 2010, 06:43 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Final idea.
I modified a Dremel tool to slice sections off a wide lamination of purfling for the C bout of the fiddle. This is (for me at least) the most difficult part of the purfling job and I wanted to see if I could simplify it.
The limitation of the balsa stripper is that stuff like bass wood is beyond its capability no matter how hard you try. I plan to use my Dremel tool holder (which was originally made for another fiddle job which has no obvious model use) to strip bass wood and thin ply.
I haven't actually done this yet but as soon as I find all the parts I will make a shelf to guide the wood into the saw, then use it exactly like a normal balsa stripper, except that I will be able to strip much harder woods.
Width is controlled by how deep you set the saw blade into the Dremel chuck. I hope the pictures tell the whole story.
I have other pictures showing the parts of the basic holder if anyone is curious.
Sorry about the lack of clutter in these pictures. I was just getting started and the clutter didn't have time to accumulate.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Jul 08, 2010, 07:52 AM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
No need to build a jig, Sam, Dremel sells a router table that works as you describe: http://www.google.com/products/catal...d=0CDYQ8wIwAg#
Very good application for it, though!
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Jul 08, 2010, 09:25 AM
PeteSchug's Avatar
Joined Apr 2004
Geoff
I'm not sure that the fence has clearance for a saw blade. Other than that it looks like a very handy thing to have.
Pete
Old Jul 08, 2010, 05:36 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
The fence is removable, BUT, yours is ever so much nicer! Dremel = ARF mentality; yours = real craftsman mentality.
Bulent, I like that screwdriver! Cool!
Geoff
Old Jul 08, 2010, 10:20 PM
No Step is online now
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
One of my favorite "tools" is Q-Tips. I go through several boxes of them in a year. They are great for cleaning up excess glues, even as mini paint brushes.
Hi Carl ! I'm flying at Arlington Eagles now. It's a much nicer/bigger field than Erma and less money,... $65/yr.
Fred
https://home.comcast.net/~guilfoyle72/
Edit,... Oh, I guess money >can< buy Q-tips sorry, good tool anyway.
No Step is online now Find More Posts by No Step
Old Jul 09, 2010, 11:57 AM
PeteSchug's Avatar
Joined Apr 2004
First off, here's a picture I took of a sheet of heat bent balsa and some sliced ribs. I posted this on the Dynamics Unlimited site years ago.
Stradivari might have used something like a one-piece clothes peg - which you can still buy. No springs, just a forked stick. They're also handy for holding trailing edge sheets together, since you can vary the tension by simply pushing them on more or less.
Now, where does the motor go on that fiddle?
Geoff
Second, here's my version of the no spring clamps that I used to glue in the bass bar. I don't know if this has any model function, but it does complete the story. Note the little wedges along side. The vee notched clamps are felt lined. Soft leather would have been better, but the felt was handy. You place the clamp and then refine its clamping pressure with the wedges. What I do is place a couple of clamps, clean the glue. (Hide glue cleans up with water) Place a couple more clamps, remove the old ones and clean again. Repeat until no glue is visible.
Sorry, this really is off topic, but I though Geoff might like to see how it was done before supermarket clothes pins.
Pete
Skyshark is offline
Find More Posts by Skyshark
South of Boston, Ma.
Joined Mar 2004
Fascinating thread!
Skyshark is offline Find More Posts by Skyshark
Old Jul 09, 2010, 12:58 PM
bmutlugil's Avatar
Turkey
Joined May 2002
Interesting tools, Pete, thanks - and to others too, who contribute..
I like the small planers shown. I have a friend in Istanbul who also built a violin and plays it occasionally.
Is hide glue the old type glue that was activated by boiling in water? We called that bone glue - I wonder if it is still available, probably it would be difficult to find..
I had built a model canoe utilising bone glue for lamination, using bass strips. That was decades ago, before the invention - or availability here - of white glue. I had to boil glue for every strip and wait for it to cool and dry completely - like a strip or two a day I still have that canoo, and I like it very much. The plan for the full scale canoe was published in Popular Mechanics.
Bulent
Old Jul 09, 2010, 06:07 PM
PeteSchug's Avatar
Joined Apr 2004
Bulent
Hide glue is probably like bone glue, but is made from the skin and maybe the hoofs of animals. Supposedly the finest hide glue is rabbit hide glue which is colorless and used by artists for certain things.
Hide glue should not be heated above 150 f. since overheating weakens it. I have a special thermostatically controlled pot that I use for hide glue.
Hide glue is fairly easy to find. It is also considered one of the strongest glues in the world. One of the things that it is used for is frosting glass. The glue is poured on glass, it dries and adheres to the glass, but it also shrinks and peels away a layer of glass, leaving an intricately patterned frosted surface. The glue is then reheated, the tiny glass fragments settle to the bottom and the glue is re-used.
If this isn't off topic I don't know what is!
Pete
Old Jul 09, 2010, 07:34 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Well, one never knows when we might want frosted glass side windows on a model airliner. You can still buy animal-derived glues in powdered form at most woodworker's stores.
Good stuff, Pete!
Geoff
Old Jul 09, 2010, 07:52 PM
Pat Daily is online now
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Gee, I wonder if thinned hide glue applied over solarfilm and then pulled off would be sufficient to dull the shine to scale like sheen?
Pat Daily is online now Find More Posts by Pat Daily
Old Jul 09, 2010, 08:46 PM
kdahlhaus is online now
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Originally Posted by PeteSchug View Post
Hide glue .. If this isn't off topic I don't know what is!
Pete
Don't know about that but it *is* fascinating. Now to find a rabbit....
kdahlhaus is online now Find More Posts by kdahlhaus
Old Jul 09, 2010, 08:52 PM
PeteSchug's Avatar
Joined Apr 2004
If you don't mind intricate frosted patterns in your dulled, scale like solarfilm.
If you try it, let us know how it worked and if you ever got the glue off the plane.
Pete
Old Jul 09, 2010, 09:25 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I bet not. But, it would mean you could get all those pesky wrinkles out!
charlie
portablevcb is offline Find More Posts by portablevcb
Discussion Free Country? Why can't I buy beer on Sunday? lakedude Life, The Universe, and Politics 72 Feb 29, 2016 07:45 AM
Discussion Can't I buy a catapult/launcher??? albireo Electric Ducted Fan Jet Talk 69 Nov 25, 2014 06:38 PM
Please Help...Can't decide which tires to buy!!! mefly2 Life, The Universe, and Politics 3 May 08, 2002 12:53 AM
Tools you can't live without. Jim McPherson Electric Plane Talk 69 Oct 31, 2001 11:20 AM
Best Tx money can buy henke Electric Plane Talk 9 Jul 23, 2001 06:56 AM
