DIY conversion to infra red
Still looking for wagon tracks, so:
It is possible that IR reflectivity is different for the compacted ground of trackways than it is for surrounding soil. This may be especially true after a rain (if it ever rains again). Lacking BIG bucks for a serious IR camera I chose to modify one of my handhelds. I have standardized on the Olympus C50 5mpx. No particular reason for that camera, but I find that extreme familiarity with one camera lessens problems. I by the broken ones on eBay. Suddenly there is a ton of info on the web about IR conversions. A few seconds on Google yields a lot. But the simple facts are: Digital cameras are very sensitive to IR wavelengths To prevent problems the mfg includes an internal IR blocking filter Remove the blocking filter and voila - IR camera Use an IR pass filter in front of the lens to keep out visible light What you get is a very high contrast false color image that 'sees' things differently than visible light. Probably not useful for Real Estate - but who knows? The photos show the process. The only tricky part is that you have to cut a replacement for the filter that you remove. I used pieces of the UV filter that was smashed when the Creosote Cruiser pronged into the ground. Just scribed and snapped until I had a piece that fit. I tried to get away without the replacement and the focus was really bad. No AP yet - the winds have been 40 to 60 mph. But the two ground images show the results. Trees are white. Sky and water are black. Ice on the pond reflects white. I'm using an IR pass filter in front of the lens. Has some advantages. But I want to cut one to use internal to the camera. Since IR focuses at a different point than visible the thickness of the filter can compensate for the difference. Can one of you experts tell me which way to go. Does thicker glass or thinner glass focus the IR better?
Rich,
We've found about 3 miles of big frieght wagon trails. They are probably 1800-1850. There is lots of evidence of the earlier trails but we have some learning to do before making any claims. I've posted some stuff here: http://www.sdc.org/~crane Tom |
| Thread Tools | |
| Help! DIY Infra-red ? | steve lewin | Indoor and Micro Models | 3067 | Nov 08, 2009 01:59 AM |
| airwars "infra-red combat system for planes" | Tree_Magnet | Power Systems | 15 | Jan 08, 2008 09:41 PM |
| Infra-Red Thermometer for Helis | rscamp | Electric Heli Talk | 7 | Jan 08, 2002 06:11 AM |
| airwars "infra-red combat system for planes" | Tree_Magnet | Foamies (Kits) | 4 | Aug 02, 2001 12:15 AM |
| Infra red transmitter and receiver for micro size aircraft | Ron MIller | Power Systems | 2 | May 28, 2001 09:51 AM |
