Old Mar 12, 2006, 11:56 PM
volksdad is offline
Find More Posts by volksdad
Paint fixes everything.
Raleigh, NC
Joined Feb 2006
Question
How do you change radio transmitters?
I have a Futaba sky sport four radio that I would like to use for my CX, but switching th crystals did not work. Why is this? Does it have to do with the four in one reciever?
volksdad is offline Find More Posts by volksdad
Old Mar 13, 2006, 12:09 AM
copperclad is offline
Find More Posts by copperclad
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
hi
i think you just need a single conversion crystal for the RX ( 4 in 1 ) that matches your TX channel , i could be all wet , but i am guessing your sky sport X-tal was a dual conversion RX , dana
PS: did you try putting the BCX TX X-tal in the sky sport TX , or did you try to put the sky sport RX X-tall in the 4 in 1
copperclad is offline Find More Posts by copperclad
Old Mar 13, 2006, 12:43 AM
volksdad is offline
Raleigh, NC
Joined Feb 2006
I took the x-tal out of the radio that came with the bcx and put it in the other (sky sport four) radio transmitter. The 4 in one would not go green, it stayed red.
Are you saying that i should switch the crystals on the recievers? or thaat i need a new set of xtals to do this?
Whats a dual vs single conversion crystal?
FYI the sky sport is a fairly old radio... At least 5 years, maybe 8! but it was a nice one when it was bought.
Old Mar 13, 2006, 07:07 AM
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
hi volksdad
i think you will need to switch X-tals in both the RX and the TX , they both have to be on the same channel
and just for your information
there are a mess of things that can be different
positive or negative shift
single or dual conversion
AM or FM
72mhz or 49 mhz
and there are others like SPCM vs PPM
first is shift JR and airtronics are positive shift and won't work with futaba , futaba is negative shift
and as i understand a single conversion RX needs a single conversion X-tal , so a single conversion X-tal on channel 39 is a slightly different frequency than a dual conversion X-tal on channel 39
some older radios were AM and most new stuff is FM
and there are ground VS air frequencies
i could be wrong but i think the BCX TX is negative shift like your futaba sky sport so the sky sport should work , remember both the TX and the RX need to be the same channel so you will have to switch X-tals in both TX and RX
hope i haven't made this more confussing than it already is , dana
Old Mar 26, 2006, 05:28 AM
volksdad is offline
Raleigh, NC
Joined Feb 2006
hope i haven't made this more confusing than it already is , dana
Hey dana:
I've read this more than a couple of times, but I'm confused. If the recieving crystal in the stock transmitter is the the same as the one in the four in 1 (a matched set) then wouldn't i just have to switch the crystal out from the stock transmitter into the new transmitter (sky sport) that I want to use?
OR do I need to get a new set of crystals and install them one in the transmitter and one in the 4 in 1?
OH and thanks for explaining this. I appreciate it.
Old Mar 26, 2006, 07:46 AM
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
hi
the RX crystal in the skysport could be dual conversion , the RX in the BCX needs to be single conversion
on the TX side it dosen't matter so leave the TX crystal the way it is and get a new single conversion crystal for the BCX RX that is the same frequency as the skysport TX
if you have a local hobby shop they should be able to help , don't feel bad this single , dual , positive , negative , fm , pcm , stuff is confusing at first , dana
or order a FM crystal set that is the same frequency as your skysport from here
http://www.horizonhobby.com/Products...arts%20Listing
and then just use the RX crystal in your BCX , so the skysport TX crystal would be the stock skysport crystal
but the BCX RX would have the new crystal installed
Old Mar 26, 2006, 06:17 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
all you need is a short single conversion crystal for the RX, that matches the channel of your TX. I personaly use a berg single conversion, I have heard of others using futaba and JR crystals with sucess, here is what you need http://www2.towerhobbies.com/cgi-bin...I=LXBFL1**&P=7 for channels 11-35 or http://www2.towerhobbies.com/cgi-bin...I=LXBFL2**&P=7 for channels 36-60
Technicaly, it is against fcc rules to change out the cystal in your TX....
dacaur is offline Find More Posts by dacaur
Old Mar 27, 2006, 12:20 PM
FlyH2O is offline
Find More Posts by FlyH2O
FlyH2O's Avatar
Laceys Spring, AL
Joined Sep 2005
Futaba 9CAP Super
Here is how I setup my 9C. I have a synthesized module on my TX and set it to 52 to match my BCX. Parameters: ACRO (no need for a heli mode program) and PPM, Channels: 1 NORM, 2 NORM, 3 REV, and 4 REV, Trims: Throttle centered (if you trim it up to get hover the motors continue to run with throttle off) the rest minor adjustments to suit. It flies great hands off with no Issues. If you wanted you could add a little EXPO to flatten out the middle of the sticks when you’re first learning to hover it for a little finer control.
Larry O
FlyH2O is offline Find More Posts by FlyH2O
Old Mar 27, 2006, 03:18 PM
Rooney7783 is offline
Find More Posts by Rooney7783
All Thumbs
Rooney7783's Avatar
College Station Texas, Home of the Fightin Texas Aggies
Joined Dec 2005
Technicaly, it is against fcc rules to change out the cystal in your TX....[/QUOTE]
It's not against the rules to change the crystals, it's against the rules to alter it for anything other than it's intended purpose. Otherwise no one in a legit hobby shop would sell tx crystals.
Rooney7783 is offline Find More Posts by Rooney7783
Old Mar 27, 2006, 06:48 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Originally Posted by volksdad
Hey dana:
Get a single conversion crystal from GWS or JR that matches the existing frequency of your Skysport TX. It should work then. It worked for my Futaba conversion.
Your skysport rx crystal is a dual conversion crystal and will not work in the single conversion Esky 4 in 1.
The Esky radio is single conversion FM.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Mar 27, 2006, 08:37 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
gws crystals are mini, physically smaller, so wont work
Old Mar 27, 2006, 08:46 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Guess again.
Some GWS crystals are mini....but some are standard sized.
Check out the STANDARD SIZED GWS crystals at the bottom of this AeroMicro page:
http://www.aeromicro.com/Catalog/cry...2_products.htm
Old Mar 27, 2006, 08:53 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
just because you can buy it and put it in, doesn't make it ok... for example most states have lift laws that say you cannot lift your truck more than a certain amount, yet you can buy lift kits there designed for more than the legal limit...
The "official" reason hobby shops can sell TX crystals is that they are fragile and can break, so you need to be able to replace it... with the same channel
From futaba's website:
How do I change the frequency of my transmitter?
For a unit with crystals: We CANNOT recommend changing crystals to a different frequency. Changing the crystal on your transmitter is illegal unless you have the proper license. The FCC has established guidelines for the modeler's safety and for the safety of spectators. For safety and FCC reasons we must request that both TX and RX be sent to the service center to ensure proper crystal change and retuning to the new frequency.
From one of hitecs user manuals:
e. Changing Crystals
Changing crystal to avoid conflicts with other aircraft is possible where permitted. (You must check your local rules before doing so. For example in the US the FCC prohibits the changing of transmitter crystals on 72 and 27MHz).
from JR's website:
Can I change the crystal on my transmitter or module?
No, it must be returned to the authorized JR Service Center per FCC regulations.
From airtronics website:
Q. Can I change channels on my transmitter and receiver without re-tuning?
A. Radios equipped with frequency modules can be changed to another channel by replacing the tuned module with another tuned module. Radios not equipped with frequency modules can not legally be changed without re-tuning the radio to the specific channel. Not only is it against FCC regulations but more important it may shorten your range and/or cause interference with someone else's radio that could therefore cause personal injury.
Old Mar 27, 2006, 09:40 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Originally Posted by Thomas B
Guess again.
i did not know that..
Old Apr 01, 2006, 08:12 AM
volksdad is offline
Raleigh, NC
Joined Feb 2006
First, thanks to all who've chimed in and offered their experience.
I went to my lhs and showed them this thread and the radio guru there quoted me like $50.00, and also said that it might not work. He explained that i had to buy a new Xtal for my reciever, AND a new Xtal for my transmitter.
he explained that the skysport 4 is a good radio that works with dual conversion xtals and that the bcx system is single conversion, therefore id need to buy two.
If i undrstand you correctly it is possible to use single conversion xtals in a dual conversion tx, but dual conversion xtals wont work in a single conversion tx.
SO i just have to buy one xtal thay matches both the channel and frequency of my bcx rx, and make sure that its single conversion, right? I'm gonna try that link you posted with standard sized GWS xtals....
Discussion How do you test radio range before you fly? BowerR64 Radios 3 Aug 14, 2007 07:47 PM
Discussion How do you change hole on servo arm?? mcf34 Coaxial Helicopters 1 Feb 14, 2007 02:05 PM
Suggestion How do you change your name? J.E. Johnson Site Suggestions / Complaints 1 Apr 12, 2006 07:28 AM
Pinion Gears- how do you change them? Dadzilla-5 Power Systems 1 Jan 24, 2005 03:31 PM
How do you change under your user name ?? Mopar92 Life, The Universe, and Politics 2 Dec 09, 2003 01:43 PM
