Old Jun 27, 2002, 11:05 PM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
worlds smallest 4 cell battery pack?
Does anyone have a recommendation for the lightest weight 4 cell battery pack available? I need around 5V to power a small wireless video camera. It only pulls around 50mA.
Tower doesnt seem to sell anything under 250mAh. I was thinking of a 50mAh pack if possible.
downeym is offline Find More Posts by downeym
Old Jun 28, 2002, 12:04 AM
easy2fly is offline
Find More Posts by easy2fly
nw ohio
Joined Jan 2002
i have two four cell 50 mah packs fo small gliders . i got them from radical rc, it think their website is www.radicalrc.com , at the toledo show.
easy2fly is offline Find More Posts by easy2fly
Old Jun 28, 2002, 01:23 AM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
The 50mah nicads will be pretty light and cheep. If you want the ultimate, then get 2 of the new 140mah polys and use the a gws speed controll with a bec to limit the voltage to 5v, I know this works as I have done it with a small xmiter and camera that took about 250ma, using bigger li ions. You will get almost 3 hrs out of these cells and be a little lighter than the 4 cell 50 mah pack.
lupy is offline Find More Posts by lupy
Old Jun 28, 2002, 02:51 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Or you could use a simple voltage regulator chip rather than a speed controller although the GWS esc is so small and cheap its a really good solution.
The 140mAh LiPoly cells are 3.6g each so the total pack weight is about the same as a two cell 50mAh nicad but with ~ three times the capacity. There are several thread on them.
I am going to do the same thing as I have a blackwidowav.com transmitter and ccd camera. I may also use a DC-DC of about 1g weight to produce the 5v, this means only one cell and no regulator is needed giving a 4.6g total pack weight. I may be selling these in the future but not at the moment.
To buy these cells:
www.indoor.flyer.co.uk - (this is me)
www.smallrc.com
www.ruijsink.nl
And for cells and an economic charger :
http://users.joplin.com/~bselman/
best of luck
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jun 28, 2002, 07:54 AM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
I heard if you open up the 9 to 12 volt alkaline cylinder cells sold for keyless remotes, you would find a number of very small button cells. These might deliver the current. If not, at Allelectronics.com you can buy a 6 cell 40 mah Nimh button cell packs for $2. These should do it for sure, and you won't need a special charger.
But Graham is right the Polymers will give you the most duration.
Philip
fill is offline Find More Posts by fill
Old Jun 29, 2002, 02:22 PM
rays89 is offline
Find More Posts by rays89
Tree Trimmer
rays89's Avatar
Warren TWP NJ
Joined May 2001
How would the CR2032 lithium coin cell work I beleive they are 230 mah and 3 volts apeice they are not rechargable but if you shop around they can be had at a very cheap price.
I myself have tried the single cell 12 volt alkaline cells but there rated at about 30 mah. and only seem to give juice for about 3-4 then they are shot.
rays89 is offline Find More Posts by rays89
Old Jun 30, 2002, 01:03 AM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
hearing aid batteries ... .. also the 120 nimh cells are lighter then the 50n sanyo's but i have seen 70 nimh cells and there tiny lil suckers.. keep looking its out there...
AIR MOVER is offline Find More Posts by AIR MOVER
Old Jun 30, 2002, 01:35 AM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
70ma nimh's are pretty pesky buggers... they provide VERY little current (500ma or less, a lot less preferably) and they are 2.5g each or so... 7.5g for a 3-cell, li-poly wins. cr2032 will work, I have pulled 60ma for el lights from them fine.
opualuan is offline Find More Posts by opualuan
HE 5/4 AA 8 cell battery pack w/jst connector machine Aircraft - Electric - Airplanes (FS/W) 3 Nov 20, 2003 03:55 PM
FS: Sanyo RC2400 Zapped 10 cell battery pack Balin Aircraft - Electric - Airplanes (FS/W) 0 Jan 29, 2003 07:24 PM
FS New CP-2400 10 cell battery pack mickydee Aircraft - Electric - Airplanes (FS/W) 1 Oct 11, 2002 12:47 PM
WTB: 7/8 cell battery pack for zagi seanpr123 Aircraft - Electric - Airplanes (FS/W) 3 Sep 28, 2002 09:58 AM
Sanyo 600 AE 6 cell battery pack spy0o7 Power Systems 4 May 31, 2001 01:01 AM
