Mar 14, 2006, 08:26 AM
Antwerpen
Joined Jul 2005
Hello Ronmeister,
Nope, that can't be the problem, as this airplane is used with a real old dedicated Sanwa TX, that simply has 4 channels straightforward, so, not even a mixing function, and a range and performance check that even put's new Futaba's in a corner as rubbish. Working on PPM and even AM, it suppresses even TX's in FM, while the other would die on glitches, my rx doesn't even react on any disturbance.
So, I rule out any RC error, heck even any pilot error.
Really, it puzzles me. The airplane was at max. about 400 feet away, on a height of 200 feet, and due to the problem, not able to turn, or pull up.
It even puzzles me more that the model was rolling right by 'up', even combined with full roll left command, one would think that ailerons should have more authority on rolls then on tail ? Again, alle control surfaces were controlled on throw, even under force !
With such an impact, i'm as happy as a child to know that I can repair it, but what's the point as I can not fix the problem ?
The only thing I can add is that this problem occured the first time after a minor repair on the right wing, but this was repaired well, and tested on strenght, angle, etc.
