Old Mar 12, 2006, 05:49 AM
Tug Nut
meechingman's Avatar
Newhaven, England
Joined Feb 2005
Lighting a tug
Now that the warranty's run out on my 'Southampton' it's time to make some mods. First up is installing lights.
Plan is for P & S navigation lights, all three towing lights [maybe independently switched] and some deck lights. What I want to do is have them at different brightness levels. I have in mind to power them via a small, lightweight9v battery, dropping the 9v to around 5v with a transistor, then creating a few 'voltage rails' with various resistors or even small potentiometers.
1) Am I on the right lines?
2) Can anyone give me suggestions for the transistor and resistor values?
3) Will the fact that the deck light group and the three towing lights group will be connected in parallel [separate groups] make any difference?
Andy G
meechingman is offline Find More Posts by meechingman
Old Mar 12, 2006, 08:09 AM
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
For the International NavRules, your tug (without a tow) would show at either 4 or 5 nav lights. NavRule 23 is a power driven vessel underway and states:
"a) A power-driven vessel underway shall exhibit:
i. a masthead light forward;
ii. a second masthead light abaft of and higher than the forward one; except that a vessel of less than 50 meters in length shall not be obliged to exhibit such a light but may do so;
iii. sidelights: and
iv. a sternlight. "
NavRule 24 covers towing requirements.
"(a) A power-driven vessel when towing astern [Inld] shall exhibit:
i. Instead of the light prescribed in Rule 23(a)(i) or 23(a)(ii), two masthead lights in a vertical line. When the length of the tow, measuring from the stern of the towing vessel to the after end of the tow exceeds 200 meters, three such lights in a vertical line;
ii. sidelights;
iii. a sternlight;
iv. a towing light in a vertical line above the sternlight; and
v. when the length of the tow exceeds 200 meters, a diamond shape where it can best be seen. "
To answer your questions.
1) Yes, you are on the right lines.
2) I can't help you with the transistor/resistor values. I would recommend some 12v light bulbs running off a 9v battery.
3) No, but i would connect them differently, with one lead from the battery going to a small switchboard. Switch #1 = yellow deck lights; with the lights connected is a series-parallel fashion. Switch #2 = masthead light, side lights & stern light. Switch #3 = for towing, second masthead light and yellow stern slight. Switch #4 = for towing, third masthead light.
CG Bob is offline Find More Posts by CG Bob
Old Mar 12, 2006, 10:48 AM
Tug Nut
Newhaven, England
Joined Feb 2005
Thanks for the info CGBob. Remember learning the lighting rules many moons ago - helps when your dad is a tug skipper!
Your suggestions about the switching make great sense, that's the way to go. If no-one comes up with suggested values, I think I'll have an experiment with some resistors, making sure not to cook the LED's on the way.
Andy G
Old Mar 12, 2006, 02:01 PM
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
LED's & Lighting...
There was a good discussion about lighting with LED's over in the aircraft side of things. Planes don't do so well at night without lights!
Here's a link to the discussion and it has the relevant electronics formula's to work with LED's (and small lamps if you know their settings, they just burn more juice than high power LED's).
Lighting Aircraft
A good source for super bright LED's is:
www.batteryspace.com
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Mar 13, 2006, 12:11 AM
sensitive artsy type
Treetop's Avatar
Tucker, Georgia, United States
Joined Feb 2004
FlightLites, which is a company started by RCGroups member (JSwayze)has some interesting products, I bought some leds from him a while back, and some 30 gauge wire, he has grown and invented since then, Worth taking a look, there is a thread about these also:
http://www.flightlites.com/index.shtml
http://www.rcgroups.com/forums/showt...ht=flightlites
Treetop is offline Find More Posts by Treetop
Old Jun 07, 2006, 03:19 PM
R/C Electro-Gadgeteer
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
yet another option for LED controls.... "MINIFLASH" Programmable LED controller w/ R/C control...
Click here to see a video of LEDS on a Traxxas Revo... Full R/C controlled and programmable via your PC.
More can be read about it here...
Tomapowa is offline Find More Posts by Tomapowa
Old Jun 07, 2006, 07:39 PM
Joined Apr 2006
http://www.ramrcandramtrack.com/rclights.html
charge1(ds) is offline Find More Posts by charge1(ds)
Old Nov 27, 2006, 11:36 AM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
CGbob, or anyone,
What are the red and clear marking lights used for on the Yardarms of this mast?
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Nov 27, 2006, 11:59 AM
One apostrophe may be too many
patmat2350's Avatar
Motor City
Joined Dec 2004
Means "stay out of my way, I can't change my course!"
See rule 27 (links above):
(b) A vessel restricted in her ability to maneuver, ..., shall exhibit:
three all-round lights in a vertical line where they can best be seen. The highest and lowest of these lights shall be red and the middle light shall be white;
"Restricted" includes: A power-driven vessel engaged in a towing operation such as severely restricts the towing vessel and her tow in their ability to deviate from their course
And the example has double lamps... the double just being a spare, iiuc.
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Nov 27, 2006, 12:03 PM
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
meech, replace the models lights with grain of rice bulbs ya cant go far wrong then
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Nov 27, 2006, 12:31 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
The red lights on the upper yard could also be used as aircraft warning lights. Aircraft warning lights are energized (turned on) at night in port, usually two red lights at or near the highest point of the vessel.
Old Nov 27, 2006, 04:38 PM
Ghost 2501's Avatar
stoke on trent
CG would such a light be used at sea in open ocean?
Old Nov 27, 2006, 06:38 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
As aircraft warning lights, not likely. However a vessel not under command or restricted in her ability to manuever is possible in the open ocean. A cable vessel working a cable in the open ocean has restricted manueverability. A buoy tender servicing a NOAA weather buoy would also have restircted manueverability.
Old Nov 27, 2006, 10:23 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Excellent answers Gentlemen.
Thankyou
Old Dec 02, 2006, 07:09 AM
Tug Nut
Newhaven, England
Joined Feb 2005
Ghost - the LED's are working fine for now, but on the next overhaul, things way well change!
Andy
