Old Mar 12, 2006, 09:05 PM
pmjass is offline
Find More Posts by pmjass
Team FlightPower AUS
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Here are the required templates for the first stage of the build.
Next step is to harden the edges with cyano.
When cutting out the sides; make the servo opening in one side only.
Don't forget to make two identical bulkheads.
pmjass is offline Find More Posts by pmjass
Old Mar 12, 2006, 10:37 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Here ya go.
Old Mar 12, 2006, 10:40 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
I usually run cyano around all the edges of the cardboard template to make them hard after this they can even be sanded smooth.
This is usually quite a messy job. In the past I just applied thin cyano with the fine tip on my cyano bottle. Brushing also works if you have cyano with a brush.
More recently I have a spare tip that I have cut a step into which makes it easy to follow the edge of the cardboard.
Old Mar 13, 2006, 06:17 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Found another minor fault. The cutouts for the bulkhead in the bottom template needed to be 6mm deeper. I have amended the plans and re-posted.
This is one of the reasons why I am doing the build thread so that the plans can be verified. I'll continue to post updates as i come across them.
At the end the posted plans should be error free.
Old Mar 13, 2006, 06:59 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
And we APPRECIATE it !!!!
gpw is offline Find More Posts by gpw
Old Mar 13, 2006, 07:26 AM
gorge windsurfer is offline
Find More Posts by gorge windsurfer
USA, OR, The Dalles
Joined Jul 2004
is the wing flat plate or is it builtup like the mid west DAS Little Stick?
gorge windsurfer is offline Find More Posts by gorge windsurfer
Old Mar 13, 2006, 07:39 AM
Phlygaren is offline
Find More Posts by Phlygaren
Joined Dec 2004
I am now building a "Cubish" thing, and this Ugly looks nice to start with when itīs finished. You said, pmjass, that you could do .dxf-file. Yes, that would be nice. I like CAD-works. The Cub ( presented in the Foamies thread ) will be floppypowered.
Phlygaren is offline Find More Posts by Phlygaren
Old Mar 13, 2006, 07:48 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Ahhh an oldie but a goldie im interested in what the specs are as to weight and power ect' when you have time just keep building and snapping pix cheers Lez.
olmod is offline Find More Posts by olmod
Old Mar 13, 2006, 02:43 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Here are a couple of pics of my cutting table.
Old Mar 13, 2006, 02:44 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
One of the templates held down with map pins and ready to cut.
Old Mar 13, 2006, 02:46 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Dry fit of parts to show how it goes together.
Old Mar 13, 2006, 04:26 PM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Nice clean looking cuts. That's going to be a rugged fuse. I see your nice wire rig there, that's how you get such presision cuts. I just finishes your indoor Baron yesterday, nice rugged interlocking design on the frame, I have a 20T cd motor on it, Hope I can do it justice. I built it out of skinned FF, ans just a hint of uncercamber and sanded the LE & TE edges.
Keep up the good work, I love these show as you go builds!!
Paul
praymond is offline Find More Posts by praymond
Old Mar 13, 2006, 07:38 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Its a flat plate with two 5mm carbon rods to keep it that way.
While I personally don't like the look of flate plate wings that much; they perform very well. In the air it is diffcult to spot. They also seem to be able to slow up very well with forgiving stall characteristics.
With this design it should be easy to modify the side templates to allow for a full section wing. The fuselage in the wing seat section is constant width.
I had thought about doing a full section wing however I decided that a flat wing would be quicker and easier and after flying one for a bit I'm quite happy with the performance.
Old Mar 14, 2006, 02:31 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Here ya go.
Old Mar 14, 2006, 02:56 AM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Next step some hardpoints for the servos, I use around 1/16" (1.5 mm) ply.
MAKE CERTAIN YOU DO A LEFT AND A RIGHT SIDE
Its a lot easier while everything is flat and avoids a lot of hangar rash later
on.
Cut around the perimeter of the hardpoint area with a sharp knife to the depth required.
I then use my dremel to router out the area. Because of the knife cuts you can get a nice sharp corner.
I've also attached a pic of the dremel attachment I use.
Sopwith Camel E-SPAD Build Thread ClimaxPilot SPAD - Simple Plastic Airplane Designs 154 Jan 17, 2012 07:36 AM
New "Slick" from www.M-A-E.com (build thread) Foam Crazy 3D Flying 57 Apr 12, 2007 08:37 PM
Discussion Das Ugl-E-Stik pmjass Foamies (Kits) 36 Jun 16, 2006 04:17 AM
Yippee! balsa e-mower build thread Aidan Parkflyers 5 Jan 01, 2005 08:52 PM
SPORT-E-STIK Build Question SchiessCo Sport Planes 2 Apr 14, 2003 10:28 AM
