Old Mar 12, 2006, 05:39 AM
Team FlightPower AUS
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Das Ugl-E-Stik - Free Plans
In this thread I'll post the build sequence for my version of the Ugly Stik.
This is not my design merely an adaption that I did of the famous Das Ugly Stik designed by Phil Kraft.
Tiled A4 Plans are attached. Tiled Letter plans to follow shortly.
This is a 1metre wingspan model constructed of 6mm Depron and designed for the Hyperion 3007/26.
See the thread Das Ugl-E-Stik for more pics.
pmjass is offline Find More Posts by pmjass
Old Mar 12, 2006, 05:50 AM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Printing and taping together pages.
Use page outlines a guide for overlaps.
Old Mar 12, 2006, 05:55 AM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Tiled Letter plans
Old Mar 12, 2006, 08:42 AM
Model Designer - AMA 667982
starcad's Avatar
Tucson, AZ, USA
Joined Sep 2000
Great job on the plans. Nice job. I'm looking forward to this build with baited breath. I love it when someone else takes an existing design and creates something better. I'm off to clear the work bench!!
starcad is offline Find More Posts by starcad
Old Mar 12, 2006, 10:45 AM
Naturally altered
Joined Feb 2005
It's a beautiful ugly
Maybe you can post the full size PDF?
Cubber is offline Find More Posts by Cubber
Old Mar 12, 2006, 12:18 PM
I used to be all thumbs...
NumbSkull's Avatar
Pittsburg, KS
Joined Mar 2005
I've been watching this one since you first posted it. I have the original ugly stick (never flown) and am excited about building it's "little brother". Maybe if I build this one, it will motivate me to fly the full size one.
NumbSkull is offline Find More Posts by NumbSkull
Old Mar 12, 2006, 05:32 PM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Glad y'all like the plans. We have a holiday here in Melbourne so I'll get building and posting pics.
You may have noticed from the plans that the construction is all tabbed and the top and bottom sheets are oversize. This allows for a complete build
in almost one go (The forward top deck is put on as a separate step).
once its all dry the excess is easily trimmed back with a knife and then sandpaper to finish.
Old Mar 12, 2006, 05:33 PM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
I'll try, what page size would you like?
Old Mar 12, 2006, 06:41 PM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Paper templates rough cut and stuck to cardboard with 3M Super 77.
the cardboard is just thick poster board so it is easy to cut.
My vernier says that the cardboard I am using is 0.025"
I use a hot-wire for cutting. That is why I make cardboard templates first. The pieces are designed so that there aren't too many inside cuts. This is also why the tab slots have leads-ins. If you are not using a hot wire cutter then do not worry about cutting the leadins.
The servo cutouts are the right sixe for Waypoint 84 Servo's. Do not forget to adjust the size for the servos you are using.
Old Mar 12, 2006, 06:44 PM
Naturally altered
Joined Feb 2005
Well I am asking not for myself but for other possible builders. I have no problem re-scaling even tiled pdf's with RastaPrint (about which there are at least 2 users following this thread), but still, it's easier with a full size PDF (not tiled).
Old Mar 12, 2006, 08:34 PM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Will a single letter size pdf full plan (With scale) be OK?
I can also do a .dxf or .dwg.
Old Mar 12, 2006, 08:43 PM
Naturally altered
Joined Feb 2005
Full size if you can (not letter). A single (40x30 inch or thereabout) sheet/page. That's icing on the cake, you plan is fine already, but a full size sheet is easier to rescale, print or work with.
Thanks.
Edit... re-reading your message, yes, a full plan, all on a single letter size page will enlarge just as good. I have many such 8.5x11 pdf plans and they print the same, when enlarged, than already scaled ones.
Old Mar 12, 2006, 08:47 PM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
After cutting out some templates I found a minor mistake in the tailplane piece. I have amended the drawings and reposted them in the zip files.
For those who had already downloaded here are the new pages.
Old Mar 12, 2006, 08:54 PM
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Thanks.
I'm using Acrobat Distiller and AutoCAD Light 2000. After playing around a little it looks like the biggest size I can do is A3. I wasn't able to find a way to set a custom page size.
If anybody knows how to do this I would certainly appreciated the help.
Old Mar 12, 2006, 09:03 PM
Naturally altered
Joined Feb 2005
Am sorry, I did not quite get the meaning of your message reading it the first time (see edit). Yes, the full plan all on a single 8.5x11 sheet (or any size for that matter, but all on a single sheet) would be wonderful. Thanks again.
Sopwith Camel E-SPAD Build Thread ClimaxPilot SPAD - Simple Plastic Airplane Designs 154 Jan 17, 2012 07:36 AM
New "Slick" from www.M-A-E.com (build thread) Foam Crazy 3D Flying 57 Apr 12, 2007 08:37 PM
Discussion Das Ugl-E-Stik pmjass Foamies (Kits) 36 Jun 16, 2006 04:17 AM
Yippee! balsa e-mower build thread Aidan Parkflyers 5 Jan 01, 2005 08:52 PM
SPORT-E-STIK Build Question SchiessCo Sport Planes 2 Apr 14, 2003 10:28 AM
