Old Mar 12, 2006, 12:42 AM
SteveCH is offline
Find More Posts by SteveCH
SteveCH's Avatar
United States, FL, Fort Lauderdale
Joined Jun 2004
Landing skids keep falling off my blade cp, how do you keep them on?
No problems with the heli besides my landing skids keep falling off almost ever time i fly it. I will just be hovering it around and the skids will fall off is there something im doing wrong how can i fix this?
SteveCH is offline Find More Posts by SteveCH
Old Mar 12, 2006, 01:22 AM
uabass is offline
Find More Posts by uabass
Joined Mar 2004
I put Shoe Goo on my CP2 landing skids joints. Works great.
uabass is offline Find More Posts by uabass
Old Mar 12, 2006, 01:56 AM
Eddiemoth is offline
Find More Posts by Eddiemoth
HeliTown
Eddiemoth's Avatar
The Bay Area, California
Joined Aug 2005
You can also use tuping tupe or loctite. Just don't use CA.
Eddiemoth is offline Find More Posts by Eddiemoth
Old Mar 12, 2006, 02:51 AM
bikenboatn is offline
Find More Posts by bikenboatn
Get back here, you!!
bikenboatn's Avatar
Santa Ana, California
Joined May 2005
There are little pieces of fuel tubing that comes on the landing skids. When you install the skids, remove the tubing first, then put the skids through the battery tray, then the fuel tubing, then plug everything into the frame. Once all the skids are all the way into the frame mounting holes, slide the tubing down so that they're jammed up against the tops of the battery tray. It's the fuel tubing jammed against the tops of the battery tray that keeps the skids from sliding out.
I went to my LHS and got fuel tubing of the same ID, but with slightly thicker walls. The thicker-walled tubing holds onto the CF rod tighter. I replaced all the oem thin-walled fuel tubing on my BCP with thicker-walled tubing. It holds everything much tighter, especially holding the geared tail prop on.
Brent.
bikenboatn is offline Find More Posts by bikenboatn
Old Mar 12, 2006, 03:10 AM
4RCHELICOPTERSPA is offline
Find More Posts by 4RCHELICOPTERSPA
Joined Sep 2005
Use super flue
4RCHELICOPTERSPA is offline Find More Posts by 4RCHELICOPTERSPA
Old Mar 12, 2006, 03:16 AM
callaisd is offline
Find More Posts by callaisd
What Tree????
callaisd's Avatar
United States, MS, Carriere
Joined Jan 2006
replace with super skids, they really look good.
callaisd is offline Find More Posts by callaisd
Old Mar 12, 2006, 08:30 AM
rrensi is offline
Find More Posts by rrensi
PA
Joined Mar 2003
Buy a glue stick in the stationary department at your local store. Apply it to the ends of the landing gear before attaching them to the frame. Then put it together sliding the tubing tight against the battery tray. This it what we use to keep the stabs from sliding loose on TD sailplanes. I also like 1/2A fuel tubing better than the stock.
rrensi is offline Find More Posts by rrensi
Old Mar 12, 2006, 01:42 PM
HeliTown
Eddiemoth's Avatar
Joined Aug 2005
If you use something permanent like CA or Super glue when your skids broken - you may have to replace the battery tray and the frame. The CA debonder never works for me.
Old Mar 12, 2006, 06:53 PM
SSG Scott is offline
Find More Posts by SSG Scott
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Just use a small drop of loctite (blue) on the end of each of your skids. This will keep them in and still allow you to change your landing gear if you should happen to break one after landing too hard.
-Scott
SSG Scott is offline Find More Posts by SSG Scott
Old Mar 12, 2006, 08:26 PM
swatson144 is offline
Find More Posts by swatson144
That'll hold until ...
swatson144's Avatar
Hampton Roads Va.
Wrap a small rubber band around 1 skid. when you put the other through it should be a slight struggle to get it in place. The tension does a fine job of holding skids of this type in.
Here's a pic of one of mine you should get the idea, even though it's the wrong heli.
swatson144 is offline Find More Posts by swatson144
Old Mar 13, 2006, 01:15 PM
Ah Clem is offline
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
Mine are installed in the way Bikeboatn described (which is stock). They have never come out, even during rolls.
Ah Clem is offline Find More Posts by Ah Clem
Discussion My Blade CP will not lift off Please Help maraskyr Electric Heli Talk 3 May 27, 2007 10:38 PM
Discussion Dragonflys keep attacking my Blade CP LuckyDuc Micro Helis 13 Jun 07, 2006 11:24 AM
Question Blade CP: How Do I Remove The Tail Boom? Rare Bear Micro Helis 12 May 03, 2006 03:24 AM
Discussion Tail motor leads keep burning off on blade CP? TommyB Micro Helis 11 Mar 02, 2006 11:01 PM
I melted some foam under my sheeted wing how do I fix it? RandyK1 Electric Sailplanes 6 May 03, 2004 03:29 PM
