Old Jun 27, 2002, 04:39 PM
Kyle is offline
Find More Posts by Kyle
Joined Jun 2002
Help with battery choice for MINI IFO
I have been looking at batteries for my mini ifo. I don't really want the expensive Li-Ion batts. I plan to use the GWS A drive and the stock prop (i think it's 10X7). Would a 600Mill 9.6 Volt NIMH pack be too heavy (it's 3.5 oz; 102grams)? I am most interested in the extreme vertical style aerobatics and hovering. Would a 9.6volt at 270 Milliamp NICD pack be better? It is 3.5 ounces; 102 grams, too. I also am looking at a 9.6Volt 280milliamp NIMH pack (2.7 oz; 66 grams)....Though it is lighter, it has less capacity and can't be fast charged.
Thanks for the help....
Kyle
Kyle is offline Find More Posts by Kyle
Old Jun 27, 2002, 05:00 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Kyle,
I can hover with 8-300ma NiMH pack.. weighs 2.2oz but it is hard on the motor. Anything with more weight will decrease your performance. Prop is a 10 X 4.7.
boomer
boomerace is offline Find More Posts by boomerace
Old Jun 27, 2002, 05:34 PM
Kyle is offline
Joined Jun 2002
Boomer,
Thanks for the quick response...I appreciate the help!
Old Jun 27, 2002, 05:41 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Same setup over here as boomer that we've been using for indoor, plus a heat sink on the motor.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Jun 27, 2002, 05:48 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Re: Help with battery choice for MINI IFO
The AUW of my Mini IFO with 9.6V pack, ready to fly, is 108 grams! That's with a 1524 motor and 50 mAh cells though.
Incidentally, you'll need to fit a rudder if you really want to hover ...
Bill Glover is offline Find More Posts by Bill Glover
Old Jun 27, 2002, 07:06 PM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
If you are going to build up a Mini Ifo, you really owe it to yourself to get a set of the qualcom li ion's, They arn't that pricy compared to most of the packs you are talking about. Especially when you will need so many of them to match the 30 -40 min flight times. With a 10/8 you should get vertical. Then when you want to spend the $$, get a set of li poly 900's and you should be at about 4.4oz all up.
None of the small nimh cells can really put out enough juce without weighing too much, then you overload the motor and burn it out. Two qualcoms are really easy on the GWS A, even with a 10/8 prop, I have 6 months of heavy use on mine.
I have flown a mini at over 5 oz, and it's just not the same as one near 4 oz
Ken
lupy is offline Find More Posts by lupy
Old Jun 27, 2002, 08:49 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
I like the lithium polys that Dan sells, but yes, they are pricey. It has good vertical, but that's not really what I care about, and the IFO is too much fun to toss around, to waste time in long straight climbs. BTW, a 2 cell lionpoly 930mah pack, GWS rx, 2 Pico servos, P7 esc, GWS-A drive, GWS prop, and Azarr antennae weighs a total of 3.5 ounces. Add your airframe and covering to that, and it doesn't take much thrust to go straight up. I'm going to try Lupy's 10x8 suggestion, to compare with the 10x4.7.
Marcus
MKH is offline Find More Posts by MKH
Old Jun 27, 2002, 09:11 PM
BigBadWolf_TX is offline
Find More Posts by BigBadWolf_TX
BigBadWolf_TX's Avatar
Mineral Wells TX
Joined Jan 2001
I just finished my Mini IFO. I am using a GWS A drive with a 10X4.7 prop. My batteries of choice are currently 8 cell 280mah NIMH's, and I run with a heatsink. They will pull the mini vertical, and I have some extra weight to lug around. I am using three servos (controllable rudder), built up carbon landing gear, and ripstop covering. Hope this helps.
I want to use lithiums, but am going to wait till I can find some a little cheaper. Any suggestions?
BigBadWolf_TX is offline Find More Posts by BigBadWolf_TX
Old Jun 28, 2002, 10:01 AM
Kyle is offline
Joined Jun 2002
Everybody,
Thanks for the help with my problem...
Kyle
Need help with motor choice for my Herr AT-6 Texan nakman8 Glow to Electric Conversions 7 Dec 18, 2005 11:07 AM
Need help with motor choice for my Herr AT-6 Texan nakman8 Beginner Training Area (Aircraft-Electric) 3 Dec 06, 2005 07:26 PM
Help with servo choice for Herr lil extra zhadley 1/2A Planes 13 Apr 07, 2005 09:17 AM
Need help with motor choice for GIANT Slow Stick Turbo442 Power Systems 0 Apr 30, 2004 12:58 PM
Help with ESC choice for GWS planes GreatGazoo Parkflyers 2 Sep 14, 2003 03:08 PM
