Old Jun 27, 2002, 12:54 PM
flailing is offline
Find More Posts by flailing
Houston, Texas
Joined Oct 2000
How to tell if you should stay off the road
How to tell if you should stay off the road.
#1 you have never seen the sign that reads "Slower traffic keep right"
#2 Or the sign right after #1 that reads "Left lane for passing only"
#3 You pull into the passing lane until your perfectly aligned with the car next to you and match his speed exactly blocking both lanes as you pass the signs #1 and #2
#4 You drive the same freeway every day but wait until your 100 yards from your exit before trying to get across 5 lanes during rush hour.
#5 Your cell phone is attached to your accelerator pedal, when it rings it's impossible to step on it.
#6 Your more intrested in the fender bender on the other side of the freeway than the gasoline tanker 12" from your bumper.
#7 You have to look around your dog thats in your lap.
#8 12 of you car pool in a 4 passenger car.
#9 You fill up with oil and check the gas.
#10 The cars 4 lanes away brake and so do you.
#11 You need a bigger rear view mirror so you can do a better job on your makeup.
flailing is offline Find More Posts by flailing
Discussion How to tell if you "burned" your brushelss motor eightdayslate Power Systems 4 Nov 17, 2006 06:19 PM
Discussion How to tell if you have a defective tail motor? sebasneumann Micro Helis 4 Jul 20, 2006 03:28 AM
How to tell if you're an electroplaneoholic. Chuck Electric Plane Talk 143 May 18, 2004 05:38 PM
How do you tell if you have damaged windings? Paul Power Systems 1 May 13, 2002 02:37 PM
How do you tell if you have a cold solder? Foxtrot Power Systems 6 Jul 28, 2001 07:56 PM
