Old Mar 09, 2006, 09:02 PM
jfrickmann is offline
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
The case for a single phase brushless
Hi y'all,
This may be a little theoretical, but I hope that some of you fellow nerds can either tell me that I am right or why I am wrong.
A Wye-wired brushless motor only uses 2/3 of its stators at any time. This means that inner resistance is 2/3 of what it would be using all stators, and Kv is 3/2 times as high.
Moreover, since the two active phases are 120 degrees apart, the induced current is only Sqrt(3)/2 times what it would be if all active stators were on the same phase. Hence, Kv goes up further by a factor of 2/Sqrt(3). So Kv of a 3-phase motor is 3/2 * 2/Sqrt(3) = Sqrt(3) times, and inner resistance is 2/3 times what it would be in a single-phase motor with the same number of turns.
If we want the same Kv for the two motors, we need Sqrt(3) times more turns on the 3-phase motor, and if we are only allowed to use the same amount of copper, then the cross section area needs to be decreased by the same factor. Therefore, the inner resistance is 2/3 * 3 = 2 times as high in the 3-phase brushless, compared to a single phase motor with the same Kv.
The single phase motor is therefore able to eat Sqrt(2) = 1.4 times as much current as the three phase motor with the same Kv. Or a single phase motor with the same Imax can have a Kv of only 0.7 times the Kv of a three phase motor.
The catch? The single phase motor can spin both ways. I think it would need a sensor system and a smart ESC, to make sure it starts off in the right direction.
So can anyone tell me if I am right, or why I am wrong?
Jesper
jfrickmann is offline Find More Posts by jfrickmann
single phase brushless motor? stumax Power Systems 26 Oct 10, 2006 07:30 AM
Question ESC for a single phase sensored BL motor jfrickmann Power Systems 8 Mar 09, 2006 07:18 PM
What brushless for single motor heli Cautrell05 Power Systems 14 Oct 09, 2005 03:32 PM
Fuse(s) for 3-phase Brushless Motors JDCochran Power Systems 20 Jun 03, 2004 07:41 AM
Jet for single 700W brushless? Reima Electric Ducted Fan Jet Talk 17 Mar 01, 2004 02:09 AM
