Old Mar 09, 2006, 05:50 PM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
how in the world am i going to solder this??
soldering isnt a big deal for me, been doing it for quite some time. but, i think i've hit a wall.
i got my .3 gram RX from Nick Leichty, and have been getting the rest of the parts together for my 5" proxflyer. Nick also sent me some caps for the motors (i was getting lots of glitches). i guess i dont really know what i was expecting, but when i looked at how incredibly small these things are, i was floored. my Weller soldering iron is a 60W, so i'll be looking for a new iron, and the tip i've been using that i thought was so small now looks monsterous.
how am i going to solder these to the motor wires? any suggestions or ideas? i really have no idea how i'm going to go about this.
thanks,
nick
edit: had an idea: CA the cap to the bell of the motor, strip a tiny portion of each motor wire and solder to the cap. would this work? i know the caps are supposed to be as close to the motor as possible, but is there such thing as too close?
micro_builder is offline Find More Posts by micro_builder
Old Mar 09, 2006, 06:42 PM
caseyjholmes is offline
Find More Posts by caseyjholmes
caseyjholmes's Avatar
riverside, CA
Joined Feb 2003
clamp whatever it is you are soldering it to down and grab it with a tiny tweezer, hold your breath, and hope the solder lands where you want it!
just joking. Try a drop of glue to hold it to the back of the motor while you solder it. Thats how I did it with my micro flier radio rx
caseyjholmes is offline Find More Posts by caseyjholmes
Old Mar 09, 2006, 06:43 PM
riverside, CA
Joined Feb 2003
lol, just saw your edit. You got the right idea =)
just be careful of heat
Old Mar 09, 2006, 07:50 PM
growermn is offline
Find More Posts by growermn
greensboro NC
Saw the dots {LOL} on your finger in the pic.....guess i need a better mag-glass to play with this new micro stuff...getting smaller and lighter all the time....but that is good just hard on old eyes lol Jeff
growermn is offline Find More Posts by growermn
Old Mar 09, 2006, 08:00 PM
The Fonz is offline
Find More Posts by The Fonz
The Fonz's Avatar
Joined Dec 2005
Hey Micro,
Get one of these suction cup dodads. I use it all the time and notice the other size suction cups. It is indispensible for holding small parts.
You squeeze the bulb to hold, then squeeze again to let go............COOL
The Fonz
The Fonz is offline Find More Posts by The Fonz
Old Mar 09, 2006, 08:02 PM
merc-blue is offline
Find More Posts by merc-blue
merc-blue's Avatar
Melbourne, Australia
Joined Jun 2004
when you get this size i would suggest getting a good weller or Goot solder station with adjustable temperature and a few small tips
merc-blue is offline Find More Posts by merc-blue
Old Mar 09, 2006, 09:12 PM
mharms is offline
Find More Posts by mharms
Realtired User
mharms's Avatar
San Jose, California
Nick,
That looks like a 0402 size cap (or is it smaller?). I almost always need to work under a microscope for this size. Definitely you need a small tip that's in good condition, and tiny diameter solder. If you have some super sharp tweezers (basically needle-sharp), you can also hold the body of the cap down while you solder. However, if you don't press straight down on the center of the cap, you may send it flying and you'll never find it.
I find it convenient to cut little bits of solder ("caterpillar poop" size) and place them on the pcb pad next to the cap terminal, then I just quickly hit it with the iron. If you aren't soldering to PCB pads, you could use a bit of flux to hold the tiny bit of solder where it needs to be. Also, since you use only a tiny bit of solder, this helps control the effect of capillary action that will grab the cap and attach it to your tip.
Good Luck!
Mark
mharms is offline Find More Posts by mharms
Old Mar 09, 2006, 09:16 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Might be a case where a good conductive epoxy is the best solution.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 09, 2006, 10:16 PM
dylan roberts is offline
Find More Posts by dylan roberts
why wont it fly
south africa
Joined Jan 2006
have you considderd hot air and solder paste approach?
dylan roberts is offline Find More Posts by dylan roberts
Old Mar 09, 2006, 11:09 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
select a piece of bare copper wire and wrap around your iron tip and one end can be shaped and tinned to form a tiny tip
olmod is offline Find More Posts by olmod
Old Mar 10, 2006, 01:21 AM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
5-8 W soldering gun, microtip - magnifier headset or binocular microscope - microscissors fixed to three hands - calm hands - GO!!!
relaxr is offline Find More Posts by relaxr
Old Mar 10, 2006, 07:59 AM
matwiyj is offline
Find More Posts by matwiyj
Stupid ground....
Winnipeg, Manitoba, Canada
Joined Jun 2005
Why so small??? It is to go from the can motor terminals to ground, isn't it? Just get the appropriate value leaded cap from Radio Shack and use that. Will cost you pennies vs $100.00 for a soldering station you'll rarely need. Parts like that are meant for high density applications where you have very little room and lots of parts to put in there. Be careful about the superglue thing though... Superglue puts off some of the most obnoxious fumes I've ever seen when heated.
Jarod Matwy
Winnipeg, Canada
matwiyj is offline Find More Posts by matwiyj
Old Mar 10, 2006, 09:08 AM
anestho is offline
Find More Posts by anestho
Texas, Plano, USA
Joined Jan 2005
fumes have cyanide in them - not too healthy
anestho is offline Find More Posts by anestho
Old Mar 10, 2006, 09:30 AM
WhiteHot is offline
Find More Posts by WhiteHot
I crash A LOT
Joined Jan 2006
Those ceramic caps are really only meant to be soldered on to a PCB. The way the metal solder points are bonded to the ceramic provides a fairly weak mechanical interface. Be careful wit those things.
Anyway, tweezers are the way to go when you want to place them. The suction deal is most likely too big. When I place 0402 sized components with a vacuum tip I usually do it with a 30 gauge syringe tip.
BTW: 0402's are a pain to solder without a microscope. You never know if you got a good solder joint. 0201's (about half that size) are a real pain.
WhiteHot is offline Find More Posts by WhiteHot
Old Mar 10, 2006, 10:18 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
it looks like 0603, no big deal.
You need good tweezers, spend some cash get pointy non magnetic ones.
Tin both ends of the cap, tin the wires you intend to attach it to. Hold one end to one wire and dap with the iron as soon as it melts its soldered. Then do the other end, be quick, just a dab. You don't need an expensive soldering station you can do this with a hot nail.
These things are VERY cheap so buy a load if you want and you can play till your hearts content.
Graham
p.s.
cyno will burn
suction cups will melt if used during soldering
so small because a leaded one will weigh as much as his RX
Graham Stabler is offline Find More Posts by Graham Stabler
How Many Planes Am I Going To Keep In My Trunk!!! basicman Parkflyers 1 Jun 01, 2003 11:06 AM
How in the world?? do you check amps?? Rip-N-Burn Batteries and Chargers 19 Apr 28, 2003 07:21 AM
How in the world do you choose? darenm Parkflyers 6 Oct 02, 2002 05:38 AM
How in the world do you measure...... HankF Power Systems 18 Apr 08, 2002 10:18 PM
Am I going to burn this up? avdflyer Electric Plane Talk 1 May 12, 2001 08:53 PM
