Old Mar 08, 2006, 05:46 PM
youth must fly is offline
Find More Posts by youth must fly
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
Land And Air Radios
mY QUESTION IS WHAT IS THE DIFFERENCE BEETWEN LAND AND AIR TRANSMITERS AND RECEIVERS Y IS IT THAT U CANT USE AN AIRCRAFT RECEIVER AND OR TRANSMITER FOR GROUND USE PLEASE HELP.
REGARDS TOMMY
youth must fly is offline Find More Posts by youth must fly
Old Mar 08, 2006, 07:02 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
The following applies only if you are operating in the United States. If you are in some other country, let us know and someone else will help you.
The quick answer is that in the US, 72 mHz frequencies are used for aircraft and 75 mHz frequencies are used for surface (land, water) craft. So, in those two bands, you can not use an air transmitter for controlling a surface craft, and vice-versa. The 72 and 75 mHz frequencies are the most commonly used, but there are others - some used for both air and ground. For a complete list, see:
http://www.modelaircraft.org/comp/frequency.htm
Bill
ebill3 is offline Find More Posts by ebill3
Old Mar 09, 2006, 01:27 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
The whole idea behind it is that someone driving an RC car (you don't need a designated place to drive it) won't shoot down planes flying at a nearby model aircraft field. There's a minimum spacing requirement for model airfields. While model airplane operation is to great extent regulated, surface usage is not. Surface RC has less range than aircraft because of the ground and many ground objects (trees, buildings, hills, etc.) Also a surface RC model is less likely to get damaged or cause damage if it loses control compared to a RC model aircraft.
Ivan
ivanc is offline Find More Posts by ivanc
Sold XPV land air vehicle Steve H. Aircraft - Electric - Airplanes (FS/W) 3 Jul 22, 2007 09:37 PM
Question Which land/air/sea vehicle is best? flightsuit Waterplanes 15 May 21, 2007 05:16 PM
Land air cruiser SpadHawk Electric Plane Talk 2 Nov 08, 2003 03:14 AM
Question Does this land+air combo toy violate FCC regulations? J Cubed Electric Plane Talk 4 Oct 22, 2003 10:19 AM
