Old Jun 26, 2002, 11:33 PM
JStory is offline
Find More Posts by JStory
United States, TX, Dallas
Joined Jun 2001
My New 8 cell 500 mah Zagi nicad pack took a charge or 1258 Mah!!!!
Last night i charged my Zagi pack at a 1c rate, accually on the lowest setting my Supernova would charge at. It read 1258 final charge. How can this happen? Normally my packs go like 50-80 mah over the rated limit.
JStory is offline Find More Posts by JStory
Old Jun 26, 2002, 11:44 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The charger missed the peak, and overcharged the pack.
..a
Old Jun 26, 2002, 11:46 PM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
Ive had lots of new packs do this on their first charge, its pretty normal. Also you should be able,if needed, to set your supernova to 100ma minimum charge rate.
Adam
Foxy is offline Find More Posts by Foxy
Old Jun 27, 2002, 05:10 PM
JStory is offline
Joined Jun 2001
Do you think it could have damage the pack? I havent used it yet casue my Zagi needs to be fixed.
Old Jun 27, 2002, 08:59 PM
electroman is offline
Find More Posts by electroman
Gaithersburg, MD, USA
Joined Jun 2000
At the low rate you were charging, the pack never went into overcharge. Since the pack could not peak, SN just keeps charging it at 100 ma and keps recording the info. Remember, the C for a pack is nominal and your pack might take 100 ma without peaking. If, for example, you use EINSTEIN or other C/10 charger, you can leave the pack on charge indefinitely without ever having it go into the overcharge condition where temp rises, vlltage peaks, and pressure builds. Your pack is OK. If in doubt, simply do a discharge and see what it's capacity is. That is why Supernova is so great; you can check about anything having to do with a pack.
electroman is offline Find More Posts by electroman
Off Site 8 cell 1500 MAH Trinity Nicad Battery packs daygoVR6 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Dec 06, 2006 11:35 AM
FS - Near new 8 Cell Kan 1100 2/3A Pack Nimh Wolfman Aircraft - Electric - Airplanes (FS/W) 3 May 05, 2005 09:16 PM
can I use my Hitec CG-340 charger w/ my new 8 cell gp3000's Nammer1 Batteries and Chargers 5 Mar 01, 2005 10:21 AM
FS:New 8 cell 870ma ni/mh battery pack Matthew Cotten Aircraft - Electric - Airplanes (FS/W) 0 Nov 18, 2003 11:02 PM
speed 400/jeti110.8 cell 500 mah combo problem efurche Power Systems 4 Dec 01, 2002 10:54 AM
