Old Jun 11, 2001, 10:06 PM
sblack is offline
Find More Posts by sblack
Scott Black, Montreal
sblack's Avatar
montreal quebec Canada
Joined Sep 1999
Which hacker motor for HW609 on 16 cells?
I can't seem to find a web site for Hacker motors. I know that for the 609 fan on 16 cells at around 40 amps I want a Kv of about 2000. Hacker has a 50 series motor in either S (short) L (long) or XL with various winds so that I could have this approximate Kv on either of the 3 sizes. However, there is only one size which will be optimum for the cell count and current that I want to draw i.e. 16 cells, 40 amps.
Anyone there have any experience with these motors or know where I can get more data?
sb
sblack is offline Find More Posts by sblack
Old Jun 11, 2001, 10:12 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
www.hacker-motor.com
They have Kv listed but nothing else.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jun 11, 2001, 11:08 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Hacker recommends the D50-12S for the HW 609
fan unit. On 12 cells it's about 40 AMPs and 27,000 RPM. In a Midi fan the D50-18S does 40 AMP's and 26,0000mRPM on 14 cells.
bruff is offline Find More Posts by bruff
Old Jun 12, 2001, 05:54 PM
sblack is offline
sblack's Avatar
Joined Sep 1999
I am looking for about another 100-150 watts. I found the site though and that was helpful. Thanks Greg and Bruff!
sb
Old Jun 12, 2001, 10:18 PM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
The motocalc currently has data on the the hacker motors, although I don't have any hacker motors so I don't know how it matches to the real motors. You don't need motocalc to look at the data it is posted on the motocalc web site. Last I checked the weights where swapped on the B50 S and L motors, so keep that in mind if you are using motocalc's "heat" feature which is based on motor weight.
You can also find hacker motor constants here too.. http://www.gordontarling.co.uk/
I would think the L model would be the safest bet, although the S might work, the XL appears a little heavy for this purpose.
ScottS is offline Find More Posts by ScottS
Old Jun 12, 2001, 10:21 PM
sblack is offline
sblack's Avatar
Joined Sep 1999
Thanks for that. I agree that the L is looking like a safer bet and the XL is overkill. But having the numbers is helpful.
Much appreciated. I will post some numbers if and when I get the goods.
sb
FS: Plett heli motor and Schulze controller for Logo on 16 cells Ben Diss Aircraft - Electric - Airplanes (FS/W) 5 May 28, 2003 09:38 PM
Question Which Hacker motor for FEDA ?? chrisku Micro Helis 1 May 26, 2003 09:39 AM
which hacker motor for the logo 20? don. austin Electric Heli Talk 3 Jan 08, 2003 06:59 PM
Best brushed motor for Eco on 10 cells? All__talk Electric Heli Talk 10 Dec 12, 2002 09:22 PM
Which Hacker motor for 60 size Kaos kenny_dilger Sport Planes 5 Jan 20, 2002 07:40 PM
