Old Mar 06, 2006, 07:29 AM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Zener diode as rudimentary Li-Ion protection?
Just wondering if a Zener diode would work as a rudimentary Li-Ion "under-volt" protection device?
I have an older Kodak Pro digital camera for which I've cobbled together a few 2S Li-Ion packs. (stock pack is 6-cell 4/5A NiMh or NICd, and FYI, I've flown with Li-Ion and Li-Po for about 4 years now, and know the drill...)
The problem is that the camera will slowly drain a pack down to zero, even if it's turned off! I think it's to do with having a CF card in the slot...
With NiMh's this is not too big a deal (my first "re-pack" used KAN 950's!), but with Li-Ion this will kill the cells!
Can a Zener diode be used as a low-voltage "cut-off", or will there always be some residual drain? (anything over a few millamps is bad...)
Thanks.
meteor is offline Find More Posts by meteor
Old Mar 06, 2006, 09:25 AM
stu78 is offline
Find More Posts by stu78
Milton Keynes UK
Joined May 2003
Can't you just unplug the battery when you are finished?
The only way I can think to do it with zero current after cutoff is to use a relay, but this will increase current drain during the ON time.
Maybe others with more electronic knowledge can think of a better way.
Stuart
stu78 is offline Find More Posts by stu78
Old Mar 06, 2006, 12:20 PM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
Problem is more complex... voltage drop and so on. Look at this page, it is very nice design, resulting in microampere pack load and acceptable current passed by, hysteresis.. However, it looks quite complex on first touch? It is not in english, but circuit scheme and dps is international.
http://www.zajic.cz/odpojovac/odpojovac.htm
coro is offline Find More Posts by coro
Old Mar 06, 2006, 01:59 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Meteor,
Look at...
http://pdfserv.maxim-ic.com/en/ds/MAX1665S-MAX1665X.pdf
This is the simplest LI-ion/poly protector device available, you could try scrounging some samples from Maxim if you can look like a bona-fide electronics business.
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Mar 09, 2006, 09:32 PM
Minn.Man is offline
Find More Posts by Minn.Man
I'm a builder, not a flighter.
United States, MN, Alexandria
Joined Mar 2006
Look at the Smart BEC product and see if you could put your cam on the output of this device.
http://www.dimensionengineering.com/SmartBEC.htm
Minn.Man is offline Find More Posts by Minn.Man
Idea DIY Li-ion Battery Pack Protection/Management Circuit? TurbineLP DIY Electronics 1 Jul 24, 2004 11:30 AM
New Li-ion Cells Same As Duralite Or Powerflite awschucks Aircraft - Fuel - Airplanes (FS/W) 0 May 29, 2004 10:04 AM
Li-Ion and protection circuit Wings Batteries and Chargers 22 Mar 02, 2003 02:39 AM
Li-Ion three cell protection board Capt. Electron Parkflyers 4 Mar 12, 2002 05:34 PM
Zener Diode to Drop 3xQ830 li-Ion Voltage for Tiger Moth AndrewsJr Power Systems 2 Feb 24, 2002 10:04 PM
