Old Mar 05, 2006, 10:11 PM
panzerd18 is offline
Find More Posts by panzerd18
panzerd18's Avatar
Melbourne, Australia
Joined Dec 2005
Question
Connectors Bat - ESC Connectors ESC - Motor?
What connectors do you guys use between the Battery and ESC and between the ESC and the motor? I don't like the idea of soldering the ESC to motor so its a permanant link as I have to use the ESC in another motor.
panzerd18 is offline Find More Posts by panzerd18
Old Mar 05, 2006, 10:40 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Depends on the current load, and whether its Brushed or Brushless.
Some like Dean's Ultras between battery and ESC, then depending on the current load:
From ESC to Motor: For brushed, MicroDeans 2-pin or Deans Ultras; For brushless, MicroDeans polarized 3-pin.
However since many brushless motors now come with Gold Bullet Connectors, you can use those between ESC and motor.
Personally I use Gold Connectors (1.8mm/2.5mm/3.0mm) for EVERYTHING.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 05, 2006, 11:37 PM
panzerd18's Avatar
Joined Dec 2005
I am leaning to the bullet connectors too. Not only are they cheap and easy to solder stuff onto them but they will plug directly into my charger.
For the battery packs is it alright to go with bullet connectors too?
Old Mar 05, 2006, 11:50 PM
jbatch is offline
Find More Posts by jbatch
Lawn darts, anyone?
Long Island, NY U.S.A.
Joined Oct 2003
Better to use polarized connectors on battery leads since it eliminates chance
of accidentally connecting your battery backwards. Bullet connectors are fine between ESC and motor- even if you make a mistake there, the worst case
is that the prop will spin backward- no harm done.
jbatch is offline Find More Posts by jbatch
Old Mar 06, 2006, 07:16 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I put a male and a female on the pack, and the reverse on the battery side of the ESC, so that I can't plug the ESC in backward. In storage I keep plastic "thread protectors" [ACE Hardware] over the Gold Connectors to prevent shorts.
Cheers, Phil
Old Mar 06, 2006, 11:14 AM
jbatch is offline
Lawn darts, anyone?
Joined Oct 2003
Caveat: Stuff a battery pack armed with Kiwi's Kwik Klips into your pocket
and you'll find out the meaning of the term, "bullet connectors." Ouch!
Motor to ESC connectors on micros Orion_V Micro Helis 2 Oct 15, 2004 08:53 PM
Best all-round brushless motor to ESC connectors? (In bulk?) mad mike Power Systems 9 Sep 22, 2004 09:20 AM
Connectors for ESC to BL motor bc-slowflyer Castle Creations 10 Jul 14, 2004 04:27 PM
Kontronic Motor/ESC Connectors IceDancer Power Systems 0 Mar 19, 2004 03:29 PM
BL motor to ESC connectors? JimF Electric Ducted Fan Jet Talk 4 Jul 06, 2003 11:37 AM
