Old Mar 05, 2006, 07:26 PM
Evan Byrne is offline
Find More Posts by Evan Byrne
Hangin.
Ojai California
Joined Feb 2006
First wing cut with Feather/Cut.
Yesterday my feather/cut and epp came, and today I cut my first wing! Wow is it easy!, the instructions can look scary at first but after you get to see how the thing works, then its a walk in the park.
Heres the wing i cut, its a NACA 0012 airfoil, its for a straight, no sweep, no taper, flying wing.
the span is 24"
Evan Byrne is offline Find More Posts by Evan Byrne
Old Mar 05, 2006, 07:27 PM
Mr. Innocent is offline
Find More Posts by Mr. Innocent
Mr. Innocent's Avatar
Oceanside CA
Joined Dec 2004
Thats a thick airfoil.
Mr. Innocent is offline Find More Posts by Mr. Innocent
Old Mar 05, 2006, 07:29 PM
Hangin.
Ojai California
Joined Feb 2006
Kinda, Yeah.
Old Mar 05, 2006, 07:31 PM
KingOfTheHill is offline
Find More Posts by KingOfTheHill
Ninja of the Nasty
KingOfTheHill's Avatar
Joined Jan 2004
NICE! wait till it flys... its a totally different feeling knowing you built it from scratch.
cut another one and make it a 48"
JOe
KingOfTheHill is offline Find More Posts by KingOfTheHill
Old Mar 05, 2006, 07:36 PM
Hangin.
Ojai California
Joined Feb 2006
The finnished thing should look along these lines...
Old Mar 05, 2006, 07:38 PM
Ninja of the Nasty
Joined Jan 2004
gonne need a lot of lead to balance that thing... might suggest a small pod/fuse of some sort to get that noseweight out in front
JOe
Old Mar 05, 2006, 07:47 PM
Hangin.
Ojai California
Joined Feb 2006
i think i can ballance it.
Old Mar 07, 2006, 01:05 AM
Hangin.
Ojai California
Joined Feb 2006
Well tomarow is the big test flight.
I freeflight tested it in the front yeard just to see if I had balanced it well, and it looks like it, and i didnt even have to add the additional 4-cell battery pack I thought I would have to, which would basically double the weight. All the electronics (Servos, Reciver, Battery) are 1/4" back from the leading edge.
I used 2 Hs-18MG's, A 4-cell flat AA pack, A Hitec feather reciver and some No-name elevon mixer.
Think it will fly?
Old Mar 07, 2006, 01:09 AM
Ninja of the Nasty
Joined Jan 2004
hope it does.... whats the weight on it?
JOe
Old Mar 07, 2006, 01:10 AM
Oceanside CA
Joined Dec 2004
What transmitter are you using??? You will need to dial down the elevator rates a ton.
Old Mar 07, 2006, 01:14 AM
Ninja of the Nasty
Joined Jan 2004
Devilcries?
J/k
JOe
Old Mar 07, 2006, 01:17 AM
Oceanside CA
Joined Dec 2004
Nah he wouldn't finish the plane.... I was testing a wing just like that for slofly, had some seriously interesting habits. It could discus launch very well, but had very strange pitch problems. Sorta like a flying slug.
Old Mar 07, 2006, 01:18 AM
Hangin.
Ojai California
Joined Feb 2006
i dont have a scale, but its pretty light...Im using a semi-old futaba.
Old Mar 07, 2006, 10:07 AM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
Originally Posted by KingOfTheHill
Devilcries?
J/k
JOe
You're reading my mind...
InTheLift is offline Find More Posts by InTheLift
Old Mar 07, 2006, 10:14 AM
minifly is offline
Find More Posts by minifly
Robots... robots everywhere
minifly's Avatar
Cape Town, South Africa
Joined Jan 2003
I've found that the no sweep/no taper wings need the CG further forward than you would think...maybe 8% - 12%.
minifly is offline Find More Posts by minifly
Rant 68 inch, hot wire cut Wing with Laser cut motor mount dougmontgomery Flying Wings 8 May 21, 2006 02:34 AM
Help with Feather-cut like machine Dedé Hand Launch 1 Nov 25, 2005 08:01 PM
WTB - Feather/Cut Wing Machine mdennis Aircraft - Sailplanes (FS/W) 2 May 17, 2005 02:21 PM
How to discharge Li-ion on Orbit with right cut-off? juantrinidad Batteries and Chargers 2 Nov 14, 2002 09:54 PM
epp foam glue to cut with hot wire? inedesca Scale Kit/Scratch Built 4 Jun 08, 2001 08:08 AM
