Old Sep 20, 2012, 03:59 PM
Slope P is online now
Find More Posts by Slope P
Slope P's Avatar
Santa Fe NM
Joined Jul 2009
wolfv,
Well, before you move come flying with us up in Santa Fe at La Bajada. Wind shoud start to blow again anyday now.
Slope P is online now Find More Posts by Slope P
Old Sep 20, 2012, 05:48 PM
jjonas is offline
Find More Posts by jjonas
jjonas's Avatar
United States, Mt, Anaconda
Joined Sep 2006
I miss Zion
I sure do miss flying with you guys. Cody, good to hear you've moved closer to Zion. Montana has been okay for sloping, just hard to find as good of a spot as Zion. In the meantime, I've been flying some full scale out of Driggs, ID (over the Tetons) and out of Minden, NV (east of Lake Tahoe). I thought I'd share some pics.
jjonas is offline Find More Posts by jjonas
Old Sep 21, 2012, 08:50 AM
stevo75 is offline
Find More Posts by stevo75
United States, CO, Superior
Joined Jun 2011
I posted this a while back and didn't hear anything. But it was the last post on the page so maybe no one saw it. Anyway, if you have any ideas to share about fuse covering, I'm all ears.
Originally Posted by stevo75 View Post
Hey all, I'm about to put ultracote on the fuse of my Eaton Air Element, but I don't know how to do this. Should I try to use one big piece and wrap it around? Or maybe long strips from the tail to the nose about 1 inch wide? How do you do this?
Steve
stevo75 is offline Find More Posts by stevo75
Old Sep 21, 2012, 09:11 AM
A10FLYR is online now
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
I did one piece of covering on each side.
A10FLYR is online now Find More Posts by A10FLYR
Old Sep 21, 2012, 09:15 AM
flyswithumb is offline
Find More Posts by flyswithumb
flyswithumb's Avatar
Littleton, Colorado
Joined Oct 2002
It will be much easier with Solartex and you should be able to do it with two pieces, one on the bottom wrapped as much as possible then one on the top.
Ultracoat will work too but I dont recommend it especially if you haven't done a few.
Tack down one edge first. As you pull the Solartex around a curve, you can see where the wrinkles will be.
Lift the Solartex off of the foam and heat it. Now, stretch it around the curve as you pull/stretch outwards.
Basically, heating the Solartex before you tack it down is the key. At first, you will feel like you need 3 hands.
After a while you’ll be holding the part down with your elbow, stretching the covering with one hand and heating with the other.
Jeff
flyswithumb is offline Find More Posts by flyswithumb
Old Sep 21, 2012, 03:05 PM
MiguelC is offline
Find More Posts by MiguelC
Springs soarer
Colorado springs
Joined Apr 2005
Slope P I am from ABQ and love to see someone down in NM slopin. I used to fly at the Damm down the street from the golf courses in Bernalillo but never knew people flew la Bajada hill. When is the best time to fly down there in Santa Fe/ABQ area?
Miguel
MiguelC is offline Find More Posts by MiguelC
Old Sep 21, 2012, 03:16 PM
stevo75 is offline
Joined Jun 2011
This is the part that's confusing me. The lip that the front of the wing fits under. I was thinking I'd have to use one piece in front of that lip and another piece, or multiple pieces behind it. Does that sound right? Even if I did a piece for each side, I don't see how a side piece could wrap up over that lip and also fit below it. But maybe this stuff shrinks more than I think. I already bought the ultracote so I don't want to buy solartex as well.
Old Sep 21, 2012, 03:19 PM
Slope P's Avatar
Santa Fe NM
Joined Jul 2009
Miguel,
Spring time typically is the best but fall is pretty good.
Get in touch with me if you ever decide to head down.
LP
Old Sep 26, 2012, 01:13 PM
MiguelC is offline
Springs soarer
Colorado springs
Joined Apr 2005
LP I will get in touch with you. I usually come down in late fall. Thanks for the info..
Miguel
Old Sep 26, 2012, 09:28 PM
pyranha7 is offline
Find More Posts by pyranha7
DS carnivore!
pyranha7's Avatar
United States, CO, Longmont
Joined Mar 2006
You just have to "wing it"
With practice you will get better. The more you experiment and the more advanced your wrapping skillz get! Just go for it! If it does not look good enough, heat it up, remove it and start over. Most of all... HAVE FUN!
pyranha7 is offline Find More Posts by pyranha7
Old Sep 29, 2012, 01:28 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
BMS is looking good for Zion. Forecast for the next few hours, even better.
Headed up in a few. Longboard racing on the upper part of Lookout so hopefully
it won't be too nutty.
ian
Daemon is online now Find More Posts by Daemon
Old Sep 29, 2012, 06:02 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Flew my Moth alone for 2 hours in great lift before anyone else showed up, and another hour
after that before it finally petered out.
ian
Old Sep 30, 2012, 08:03 PM
stevo75 is offline
Joined Jun 2011
Thanks, that what I ended up doing (winging it ). I used three different pieces on the fuse, plus a fourth small piece to go directly over the nose. I think I really need to see someone else do this. I'm sure there are a ton of tricks that would make sense if I saw someone do it, but that couldn't really be explained in a post. Anyway, it's covered and doesn't look too bad!
Old Sep 30, 2012, 10:29 PM
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
I'll bet it looks good!
Old Oct 01, 2012, 09:45 PM
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Has anyone looked at the Jones Pass forecast for wednesday? I'm thinking about going up.
Discussion Colorado Front Range Slopers - we take good care of friends guyg Slope 3 Nov 17, 2006 05:12 PM
Question Any Colorado Front Range flyers been to OK Doke Sod Farm? SeaBass Fuel Plane Talk 2 Oct 16, 2005 10:03 AM
Colorado Front Range Flyers! KonstantKrash Parkflyers 0 May 14, 2004 01:02 PM
Colorado Front Range Flyers KonstantKrash Parkflyers 15 Mar 26, 2004 08:34 PM
Any Colorado Front Range Sloping??? MTNHISLOPER Slope 4 Dec 17, 2002 12:18 PM
