| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Halloechen aus Texas !
Careful with that spoileron switch
My Liftoff XXS just kept going downwards.
After it finally hit, at 45 degrees & far away, I saw it: I had accidentally activated the spoilerons. Wings fine, serious cracks in the fuselage.- what one calls "Pilot Error" Knut |
#2 |
I know how you feel.
I have my spoilers interlocked with the flaps as well, so can't normally hit them by mistake, Problem is, on one of my gliders, i put the ailerons down a bit as flaps for thermalling, so if you hit the spolier sw by mistake then, down she comes. did that in a 7x7 comp a couple of weeks ago. didn't realise it until had lost lots of height & was able to see the ailerons were sticking up in the air !!!! |
#3 |
??? Even with the spoilerons up you still have full elevator authority! There is no need to descend at a 45° angle. Why didn't you pull up?
Jürgen
#4 |
Electric Airplane Junkie
Your spoileron should NOT be activiate with a switch. I have mine on the throttle(flap) stick so I can modulate the amount as needed. Also, as Jurgen pointed out, the elevator should has enough authority to over come the spoileron effect. This is how you slow down, full spoileron and up elevator to slow down to land.
One more point, spoileron needed to be up at least 70 deg to be effectiver as spoiler. Any less just give you lots of wash out, not drag. Learn to control the plane, not just flipping switches and watch it crash. Brian
#5 | |
Turbines suck ;-)
#6 | |
Fot example, you are coming in and short, you can close a little bit of the spoileron to extent the glide. If you have them on a switch, you can only turn it off; the plane will speed up, missed the landing. |
#7 |
That sickening crunch..
The only argument against using throttle-activated spoilers is that sometimes you do want to add a little power, but not full power. Of couse, as a full-scale sailplane pilot, I'm already fully aware of how important it is to depend on altitude, not power, as your energy reserve!
So, I am in the process of converting my models over to throttle-stick spoilers, starting with my LMR gliders, and moving over on my hotliners, then F5B, in stages - as I get more comfortable with it.So, I can see this from both sides of the fence, but I agree with Brian, even though I still use a switch for spoilers on my F5B ships.. ..a |
#8 |
I use a three position switch for the motor.
Jürgen
#9 |
For hotliners and F5B planes, I use a push button for motor, it Normally OPEN and push to close. When you let go the button, motor off. On my planes (glider type) there is only two speeds, Motor on, brake on.
| Thread Tools | |
| What is wrong with that picture? | Jurgen Heilig | Electric Plane Talk | 44 | Jul 07, 2002 01:03 AM |
| Prop speed, what's up with that. | tekochip | Power Systems | 2 | Jun 22, 2002 08:44 PM |
| u can get with this or u can get with that | neverenuff | Parkflyers | 0 | May 17, 2002 05:14 PM |
| My s400 7.2v and 6v both have RS380-PH stamped under the sticker. Whats up with that? | Barrett | Electric Plane Talk | 8 | Mar 18, 2002 12:56 AM |
| Added memory - Got Windows Protection Error, whats's up with that? | mrebman | Life, The Universe, and Politics | 6 | Oct 11, 2001 03:38 PM |
