Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old Jun 25, 2002, 01:53 PM   #1
Thats NOT indestructible
j8m8l's Avatar
Qualcomm Battery and charger combination
Will this work??
I am ordering 5 qualcomm Q-Fone battery packs to my gmothers house (i am going in 2 weeks), from All Electronics
Will this combination work, with some modification
(If you know how to do it please tell me :-))
http://batterybase.com/cellular/qual.../q_phone_c.htm (qualcomm in car charger)
http://www.allelectronics.com/cgi-bi...401&type=store (packs)
How can i mod this charger to work??
Thanx
Josh
j8m8l is offline Find More Posts by j8m8l   Reply With Quote
Old Jun 25, 2002, 04:49 PM   #2
j8m8l's Avatar
PLEASE HELP
I wanna order tomorow, but need to know
Also, how can i get this charger to work
Please help SOOOON
Josh L
Old Jun 25, 2002, 05:14 PM   #3
"Simplify, then add lightness"
Josh,
This charger won't work on the 830mah packs from Allelectronics. The packs from Allelectronics (txbat401) are 7.2volt 830mah and are for the Qualcomm PDQ phones. The Qphone is entirely different, and uses a 3.6 volt battery.
Jeff
jeffs555 is offline Find More Posts by jeffs555   Reply With Quote
Old Jun 25, 2002, 07:22 PM   #4
Send a message via AIM to Dick Northcraft
Jeff:
I picked some of these up, but now can't find a charger that will work that I can afford. Any suggestions?? Thanks
Dick Northcraft is offline Find More Posts by Dick Northcraft   Reply With Quote
Old Jun 25, 2002, 07:46 PM   #5
Send a message via AIM to Greg Covey
You can charge a two cell pack of Qualcomm Lithium Ion 830mAh cells (CGR17500) using this charger from www.flyifo.com for $27.
Greg Covey is offline Find More Posts by Greg Covey   Reply With Quote
Old Jun 25, 2002, 08:25 PM   #6
E6
Greg,
The lithium ion polymer cells they sell at IFO do they have different characteristics than the quallcomms? Like a better discharge rate?
Al
E6 is offline Find More Posts by E6   Reply With Quote
Old Jun 26, 2002, 10:11 AM   #7
Al,
I'm not sure if the discharge rate is different or not. The Lithium-Ion Polymer (LiPoly) 2-cell pack is lighter and has greater duration than the Qualcomms but is much more expensive. The discharge rate is about 4amps.
Assuming the discharge rate is similar, the expense difference outweighs the weight and capacity difference.
I'm trying both since they will work on the same charger so i'll report back in a few weeks.
Regards.
Old Jun 27, 2002, 09:00 AM   #8
After reading Allan Wright's article on the E-Zone called Converting Qualcomm cell phone batteries..., it appears that the Qualcomms have a lower discharge rate of about 2amps.
Old Jun 27, 2002, 09:23 AM   #9
LOVTOHOV's Avatar
The biggest plus about the poly's is, as I understand it, they want explode, they just puff up.
LOVTOHOV is offline Find More Posts by LOVTOHOV   Reply With Quote
Old Jun 27, 2002, 09:56 AM   #10
Another advantage of the LiPoly cells over Lithium Ion is the current delivering capability. The 4amp delivery from the cells at flyifo.com can be used on Speed 280 applications also.
The Qualcomm cells are limited to GWS IPS (or similar) applications.
All electronics and Qualcomm battery charger wwang Batteries and Chargers 2 Nov 24, 2004 05:23 AM
WTB: Qualcomm battery charger... ljfaraci Aircraft - Electric - Airplanes (FS/W) 15 Apr 24, 2004 02:33 PM
Qualcomm phone battery charger TeddyTyler Batteries and Chargers 1 Nov 11, 2002 02:30 AM
Qualcomm Battery charger ewstap Aircraft - Electric - Airplanes (FS/W) 2 Sep 21, 2002 07:44 PM
Idea Once Again -- Qualcomm Battery / Charger How-To! bsumpter Parkflyers 13 Feb 04, 2002 02:22 PM
Congratulations SimpleM!
