Old Jun 25, 2002, 06:18 AM
Ripley is offline
Find More Posts by Ripley
Don't provoke my wife!
Fort Worth Texas
Joined May 2002
How hot can my receiver get in my Aspire
After about my third motor run, I land and ck the cp1300 8 cell pack. It is very warm, almost to hot to hold on to for very long. If you are fimiliar with the Aspire you will know that my radio receiver sits directly underneath the battery pack, (two wood rails). After a long flight (3 motor runs) I remove the cp1300 battery pack and I feel the receiver and it is pretty warm! I haven't had any radio problems yet. But could it be a problem. If it is, do any of you use or could you suggest some kind of light weight insulating material that does not reflect radio waves etc.
Ripley is offline Find More Posts by Ripley
Old Jun 25, 2002, 07:10 AM
Neil McGrath is offline
Find More Posts by Neil McGrath
London UK
Joined Sep 2001
Heat
Most pieces of electronics equipment can stand fairly high ambient temperatures. Even quite sophisticated computerised kit can work comfortably at temperatures above 50 degrees Centigrade for short periods of time.
The receiver case should provide reasonable heat protection to the circuitry inside. If you are concerned, you could add a layer of light ply or balsa between the cell pack and the receiver or even use a strip of thin aluminium (which could double as a heat sink for the cell pack). I personally like to keep my receiver well away from the battery pack as I regard it as both a source of electrical interference and an RF screen.
Neil
Neil McGrath is offline Find More Posts by Neil McGrath
Old Jun 25, 2002, 08:00 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Hitec receivers come with a foam wrap that would work fine..
..a
Old Jun 25, 2002, 08:47 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Please do not post the same question in multiple forums.
Moved to Modelling Science to be merged with the other thread of the same title.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Jun 25, 2002, 01:58 PM
potifar is offline
Find More Posts by potifar
san marcos, ca
Joined Jun 2001
hi temp
we design and test our receivers for 140 degrees F (about 60 degrees C) but i would not recommend running them at that temperature for extended periods of time
peter berg
potifar is offline Find More Posts by potifar
Question Why can't I see anything in my "sent PM's" folder? birdlives1955 Site Suggestions / Complaints 3 Aug 08, 2007 03:39 PM
Help! How hot can she get! camxbad Power Systems 9 Sep 03, 2006 02:23 PM
How hot can NiMHs get? simingx Batteries and Chargers 2 Sep 04, 2004 12:37 PM
How hot do your batteries get in your Shogun/Zoom? 14U2NV Mini Helis 7 Jun 01, 2004 09:34 PM
How Hot Can a Phoenix 25 Safely Get?? Talon Driver Castle Creations 1 May 25, 2004 01:40 PM
