Old Feb 28, 2006, 12:08 PM
bmaaa is offline
Find More Posts by bmaaa
Bertrand MICHELS
bmaaa's Avatar
Belgium
Joined Nov 2003
JAZZ With "built-in" BEC under 6s LiPos ? 55-10-32 ?
I read on the knotronic site that the 55-10-32 can handle up to 10 LiPos and provide BEC, but in the chatd it is said NO BEC ?
So I am confused ? Do I need to add an external BEC or Rx Battery or not ??
bmaaa is offline Find More Posts by bmaaa
Old Feb 28, 2006, 04:43 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
It must be a typo, the jazz 55-10-32 is NO bec.
ozace is offline Find More Posts by ozace
Old Feb 28, 2006, 06:18 PM
Brian Wa is offline
Find More Posts by Brian Wa
UK
Joined Sep 2002
The Jazz 55-10-32 does Not have BEC.
See data sheet:- http://www.kontronik.com/Datenblattjazz.htm
Brian
Brian Wa is offline Find More Posts by Brian Wa
Old Feb 28, 2006, 06:56 PM
bmaaa is offline
Bertrand MICHELS
bmaaa's Avatar
Belgium
Joined Nov 2003
You are right, so I must use the JAZZ 55-6-18 ou 80-6-18.
I will use them with a Hacker 50L-15, a 6s LiPo and an EDF (electric ducted fan in a JET. 45 Amps estimated MAX draw).
Some people told me that ESC with built-in BEC is not safe under 6s, and they are instead using for exemple a HACKER MAster 77-0 PLUS a separate BEC (or Rx battery).
Is this true, or will the JAZZ 55-6-18 be OK and RELIABLE ?
Old Mar 01, 2006, 11:58 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
There were work done to make a Jazz55-16-32 with a integral BEC but it was not set up for production because most folks would want to use a seperate, external BEC due to less cost and greater flexibility.
The current Jazz55-10-32 got no BEC and support up to 10S (43v input max)
The smaller Jazz XX-6-18 work on 2-6S LiPo and the BEC is just fine on each cellcount.
Haldor is offline Find More Posts by Haldor
Old Mar 01, 2006, 12:37 PM
bmaaa is offline
Bertrand MICHELS
bmaaa's Avatar
Belgium
Joined Nov 2003
thanks, so I will start with the JAZZ 55-6-18 that I already owe, and ... see what happend.
Yippee! Fusion ESC's: A LiPo Ready ESC with Built-In High Voltage BEC MRI Medusa Research 3 Dec 26, 2006 01:28 PM
Fusion ESC's: A LiPo Ready ESC with Built-In High Voltage BEC MRI Product Announcements 0 Jul 02, 2004 05:02 PM
Use of Jazz built in BEC in Logo 10 wcoggins Kontronik 1 Dec 21, 2003 07:36 PM
DSP4-SC Receiver with built-in 10 AMP ESC Plantraco Parkflyers 72 Feb 10, 2003 11:17 AM
Does anyone make a microRx with a built in ESC/BEC? watersharer Power Systems 6 Aug 05, 2001 09:36 PM
