Old Feb 27, 2006, 06:14 PM
SteveCH is offline
Find More Posts by SteveCH
SteveCH's Avatar
United States, FL, Fort Lauderdale
Joined Jun 2004
Anyone use the E-Power 11.1V 1300mAH 3S Li-Po Battery?
The battery is so cheap ($20) anyone use it how about size, any problems i should know about this battery before I order it?
It can be found at:http://www.helidirect.com/product_in...roducts_id=635
SteveCH is offline Find More Posts by SteveCH
Old Feb 27, 2006, 06:21 PM
Bonzer is offline
Find More Posts by Bonzer
Washington, the state
Joined Nov 2005
Its a bit longer, thinner and heavier then the stock 1000mah but flies well.
Bonzer is offline Find More Posts by Bonzer
Old Feb 27, 2006, 06:24 PM
SteveCH is offline
SteveCH's Avatar
Joined Jun 2004
Will it still fit in the canopy without modifiing it? Also your saying it is heavier than the big stock blue battery?
Old Feb 27, 2006, 06:29 PM
Bonzer is offline
Joined Nov 2005
Yah it will fit but more batt will extend behind the canopy, also need to secure better to prevent a tail heavy condition. I was referring to the stock 1000 11.1v lipo from esky, mine is lime green in color.
Old Feb 27, 2006, 06:38 PM
SteveCH is offline
SteveCH's Avatar
Joined Jun 2004
Ya thats right the esky comes with one alright thanks. I think om going to order considering i can get 2 cheaper online then one at my lhs
Old Feb 27, 2006, 06:42 PM
neilswolf is offline
Find More Posts by neilswolf
California
Joined Nov 2005
I've got two and love them! awesome price and they work great in my align balance charger.
Neil
neilswolf is offline Find More Posts by neilswolf
Old Feb 27, 2006, 06:45 PM
TommyB is offline
Find More Posts by TommyB
Central PA
Joined Dec 2005
I just got one of these. As compared to a tp 1320 3s it is heavier, longer and thinner.
Run time appears about the same. It fits under my canopy fine (blade cp). I just put on the landing gear kit they sell, but I think it would fit under the stock.
For $20 you can't go too wrong I think, but I do have a few nits about it. The wires are of and inferior quality as compared to the TP packs. They are very stiff making it hard to tuck them in. The balance connector is not compatible with the TP balancer I have. I think you need an adapter or put the appropriate connector on. Its wrapped in what appears to be opaque tape. I prefer the clear shrink wrap of the tp packs as you wouldn't really be able to observe the condition of the cells.
Given the weight/size differential and these other factors, I'd say its a good deal IF it lasts as long as the TP. I don't rate it a great deal at this point.
TommyB is offline Find More Posts by TommyB
Old Feb 27, 2006, 07:45 PM
Motions is offline
Find More Posts by Motions
Motions's Avatar
Tallahassee, FL
Joined Nov 2005
I had 2 and loved them. I flew about 3 months on them and they were still going strong when I sold my heli.
Motions is offline Find More Posts by Motions
Old Feb 27, 2006, 07:53 PM
SteveCH is offline
SteveCH's Avatar
Joined Jun 2004
you live in talli too, you dont go to fsu do u
Old Feb 27, 2006, 10:22 PM
SSG Scott is offline
Find More Posts by SSG Scott
SSG Scott's Avatar
Rapid City, SD
Joined Jan 2006
Yep they are great! I have and fly 6 of them. I like the longer run time. They weigh in at 99 grams (the normal Esky 1000mah batterys that I got with my helis weighed 72g). From our tests The 1300 mah batteries give about 17-18 minutes flying in ground effect, landing and taking off. In forward aggressive continious nonstop flying I get about 12-13 minutes). More tests with a low battery voltage lipo alarm- I still get about 13 minutes of continious flight time flying slow, up high and all around out of ground effect (this requires more power than any other manuver). These batteries temp in at about 110 degrees after a continous flight where my esky batteries would be at about 130-140 degrees after flying.
These results were all with canopy installed, flying 3 different CP2s, two standard motor and one brushless, two have the dual tail motors and the other has a direct drive tail motor, all flying symmetrical blades. Helicoptor flying weights were 330g, 335g, 343g with batteries installed.
Other things I noticed is that heli seems to be a little bit more stable flying with these batteries- probably due to the lower center of gravity and slightly heavier weight. With the standard 1100mah batterys that I have that weigh 68 grams- the helicoptor can climb faster and accellerate faster.
Bottom line- I have a buddy that has bought two batteries from the local hobby store (1320 mah batteries by Kokam and Electrify that weigh the same amount) and paid 120 bucks. I have 6 of these 20 dollar battery packs for the same price and when we go to fly- I can fly continiouly for almost two hours and he is done in about 35 minutes.
-Scott
SSG Scott is offline Find More Posts by SSG Scott
Old Feb 28, 2006, 05:52 AM
Bonzer is offline
Joined Nov 2005
I picked up 2 with my CP2 and IMO, a good bang for your buck(s).
Old Feb 28, 2006, 11:01 AM
Flyin Brick is offline
Find More Posts by Flyin Brick
Flyin Brick's Avatar
Santa Clarita, CA
Joined Jan 2005
I have 2 of them that i use for my helis and my GWS warbirds... i cant believe how much technology has advanced... Could you imagine getting these batteries for $19.99 a couple years ago...
Flyin Brick is offline Find More Posts by Flyin Brick
Old Apr 14, 2006, 10:31 AM
jboehle is offline
Find More Posts by jboehle
Lawrence, KS, USA
Joined Mar 2006
Bumping an old thread, does anyone have any feedback on how these batteries are holding up a couple months later?
jboehle is offline Find More Posts by jboehle
Old Apr 14, 2006, 10:54 AM
jmdombr is offline
Find More Posts by jmdombr
Chicago, IL
Joined Feb 2006
I have 2 for my CP2 that i bought it february and im probably through over 100+ charges. They are starting to fade a little sooner now, I think i got about 30-40 charges left before i junk em. I use a KS digital Pro charger, thats not a balance so maybe they'd last longer on a balance charger.
worth the $$ anyday!
jmdombr is offline Find More Posts by jmdombr
Old Apr 14, 2006, 11:36 AM
darthdrk is offline
Find More Posts by darthdrk
My hobby is why Im broke
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
Just picked up a couple from Helidirect and at 20.00 a pop, well worth it and the HoneyBeeCP2 and Blade CP hauls the battery great. the added weight is a plus for the micro heli.
darthdrk is offline Find More Posts by darthdrk
Sold E-Flite (Thunder Power) 11.1V, 2100mah 3S LIPO AlienQuads Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 12, 2006 08:36 AM
For Sale 2000 mha 11.1v 3-cell li-po totalywicked Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 06, 2006 01:49 PM
Discussion How do I charge my 11.1v 1300mAH 3S Li-Po KavanElwood Batteries and Chargers 10 Jun 19, 2006 11:38 AM
Sold Great Planes 640 11.1V three cell Li PO pro bro steve Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 18, 2006 12:01 PM
Discussion new 11.1V 1200mAh 10C Li-Po doesnt charge shows 8 Volt seismic Batteries and Chargers 4 Jan 01, 2006 11:34 AM
