Old Feb 27, 2006, 03:31 PM
cpd32 is offline
Find More Posts by cpd32
Joined Feb 2006
Question
Atalntic harbor tug propellor
I am a new memeber to the group and waiting for ups to deliver my new atlantic tug! I have been reading about the atlantics small prop and its issues. My question is , what is the largest diameter prop one can use without mods, its performance with exisiting factory setup(esc,motor)?
Also i have a brand new two stick futaba not being used, should i go ahead and use this radio for the reverse issues and can one just change out the crystal in the reciever, instead of installing the new radios reciever and servos.I know the aquacraft is a futaba,are they compatiable?
PS. Im a former harbor tug and deepsea tug crewman hoping to enjoy (going back to sea) without leaving home!!!!, i'll see if the little atlantic allows me to doi this!! Thank you for allowing me to join the group, im sure i have many more questions! cpd32
cpd32 is offline Find More Posts by cpd32
Old Feb 27, 2006, 10:32 PM
HorribleHarry is offline
Find More Posts by HorribleHarry
Irregular... need..fiber!
HorribleHarry's Avatar
a snazzy little suburb of L.A. called Encino
Joined Jul 2005
From what I have seen, 35mm will JUST BARELY fit. If you relieve the skeg with a dremel tool using a sanding drum you can fit 40-45mm, or just remove it completely as the rudder can hang by itself just fine.
With the stock radio, the bigger prop will show only a minimal improvement.
Cap'n Harry
HorribleHarry is offline Find More Posts by HorribleHarry
Old Dec 30, 2009, 11:54 PM
ventbell 5110 is offline
Find More Posts by ventbell 5110
Joined Dec 2009
With my atlantic tug i put in a proboat ESC now reverse is great. but now its time for a better stuffing tub and drive bearings.
ventbell 5110 is offline Find More Posts by ventbell 5110
Help! Tug Propellor(Atlantic Tug) cpd32 Dock Talk 3 Jun 08, 2012 04:08 PM
Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay not_in_houston Scale Boats 53 Nov 12, 2007 11:27 AM
Discussion My harbor tug, in the making tugboatken Scale Boats 13 Nov 26, 2006 08:48 PM
Alert Midwest's "The Harbor Tug" ? helifan Scale Boats 17 May 07, 2005 11:11 PM
Midwest "the Harbor Tug" plans for trade helifan Scale Boats 1 May 02, 2005 06:32 AM
