Old Feb 27, 2006, 03:08 AM
P-51 fan is offline
Find More Posts by P-51 fan
P-51 fan's Avatar
Joined Aug 2003
Miss Stik as AP platform build
I picked up a Miss Stik kit to transform into my next AP plane, being designed by Tom Hunt I expect it to be an excellent airplane to fly. Even though I like the Slow Stick very much I just wanted something that looked more like a real plane. An AXI 2212/26 will be the power.
I am doing a few mods such as building the camera mount (Pentax S6/Prizm will be used) into the fuse and making the wingtips fold. Reinforcment will be mandatory and that will be done with carbon fiber. I also made the rud/ele a bit larger and added a 1/2" to the wing chord. I thought about flaps but haven't decided on that as of yet, I will probably decide after flying the plane whether I'll ad them or not.
Anyway, this is just a few pics to show where I'm at. If anyone looking this over and have ideas or suggestions please feel free to comment.
I added extra crossbracing to the fuse, and 1x3mm carbon flat stock to the insides of the main fuse crutch. The camera mount is mounted directly to an HS-81mg servo-the sevo horn is permantly part of the mount using epoxy and screws. The other end of the aluminum mount is held by a 1/4" nylon wing bolt epoxied (screws will also be used) to the mount. By removing the servo horn screw and pushing the mount toward the front the mount will be removable if needed. The original fuse formers were used and will not be per plans locations.
The camera will tilt completely from one side to the other in any position along the way using the flap knob on the tx...some pics will be upside-down but that will be fixed on the computer.
I'll ad more to this thread as I go, nothing else real interesting at this time.
-Bob
P-51 fan is offline Find More Posts by P-51 fan
Old Feb 27, 2006, 04:20 AM
Hermitt is offline
Find More Posts by Hermitt
Git-R-Done
Hermitt's Avatar
Rich Hill, Missouri_USA
Joined Aug 2004
If this is the plane you are building... http://www.hobby-lobby.com/miss-stik.htm
it sure looks fragile. The price is right too.
Good luck on the build and mods,
Hermitt
Hermitt is offline Find More Posts by Hermitt
Old Feb 27, 2006, 04:38 AM
P-51 fan is offline
P-51 fan's Avatar
Joined Aug 2003
Yeah it is on the fragile side, but it's stronger than it looks. Plus with cf reinforcment I think it will be fine.
Old Feb 27, 2006, 08:01 AM
Hermitt is offline
Git-R-Done
Hermitt's Avatar
Joined Aug 2004
Yeah, it's amazing how something as light as CF can be so strong.
What gauge aluminum did you use for your camera mount?
Hermitt
Old Mar 11, 2006, 07:07 AM
P-51 fan is offline
P-51 fan's Avatar
Joined Aug 2003
Well, I figured I'd add to the thread evn though there isn't much interest...but that's how I like it.
I think I explained everything in the first post, the aluminum for the camera mount is farm supply store stock...1/8"x3/4" (no metric here)
Pictures show folding wing, using left-over clevises and mounts from an old Estarter and carbon rod, hinges are covering material added to the inside of the joint then the outside full length of chord...makes a very strong hinge. Wing has been tested hard on a SS doing continuous loops with no signs of folding. .007"x1/4" flat carbon can be seen on both sides of wing spar, the latter was also built out of spruce completely. Plane is very solid, not nearly as fragile as it was.
Wing folds down to 25" and becomes a solid unit with a rubber band. Need to add rud/ele, steering tailwheel and it should be close to done. Maybe some stripes.
I think that's all.
-Bob
Old Mar 11, 2006, 08:22 AM
Hermitt is offline
Git-R-Done
Hermitt's Avatar
Joined Aug 2004
That's a real nice looking plane Bob.
What do you estimate the AUW to be?
Hermitt
Old Mar 11, 2006, 09:51 AM
P-51 fan is offline
P-51 fan's Avatar
Joined Aug 2003
As it sits in the pictures it weighs 16.5oz with motor and two servos
Total should be around 25 RTF I'd guess...HL says 22 for stock version, so not too bad.
Old Mar 12, 2006, 04:23 AM
P-51 fan is offline
P-51 fan's Avatar
Joined Aug 2003
Had an extra Glowire system so I installed it, everything but the actual wire is removable...looks cool
RTF weight is 23.5 oz w/o camera mount
25 with Glowire system installed
26.5 with camera mounted
Discussion Miss Stik as AP platform P-51 fan Aerial Photography 3 Feb 09, 2006 03:34 PM
ap1 - dedicated AP platform build thread nihil Aerial Photography 178 Mar 15, 2005 10:27 PM
Alert Easystar as AP platform Alex Talsma Aerial Photography 3 Nov 14, 2004 12:28 PM
GP J-3 Electricub as AP platform??? Jim Poor Aerial Photography 3 Nov 13, 2003 11:57 AM
Teddy as AP platform? byen00 Aerial Photography 5 Aug 18, 2003 05:11 PM
