| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Always right
RCAP2 autopilot troubleshooting and testing.
Well I have finished assembly of my new project - RCAP2, or RCAP V2 which is basically the same as original RCAP, with some improvements.
Tested it in E-MAXX electric powered monster truck. While not the perfect test bed - it is not able to drive slow enough to walk by it, it had all the radio connections needed, I used gear channel to turn RCAP2 on or off. Last edited by Hovertime; Mar 12, 2006 at 11:39 PM. |
#2 |
Always right
RCAP2 manual says :
"When the RCAP is first powered, it samples the transmitters rudder stick for neutral position. This is important for the autopilot function. It will not work correctly if you power up the RCAP2 before powering your receiver and transmitter. You will see the LED light for the first 6 or so seconds after you apply power to the RCAP. This is normal. With a GPS receiving good data, and plugged into the RCAP2 while autopilot is selected, you should see the LED blink every 2 seconds or so." So I powered TX/Rx , GPS. Then turned RCAP on, and led illuminated for 2-3 seconds. Next I tested it in off mode - and steering servo was controlled by truck's radio. Then I turned RCAP on, and led started blinking. I was driving the truck up and down the street, and it just drove straight line, no GPS steering. Garmin Emap GPS was set on "go to" Then I stopped checked RCAP - its led was on all the time., or blinking at random time... By that time I got so cold I had to get back home. Later on that night I tried to test it using servo, TX and servo tester, and again, all was working as far as it letting TX control the servo while RCAP was off, and servo was sitting still when RCAP was turned on. Prior to inserting chips I have measured voltage at regulator and it was 4.95V I have no idea why it is not working??? Can it be caused by twisted serial cable wires? Help! |
#3 |
Professor of Wood
Good idea to put this here Hovertime. I sent Radiohound an email with the symptoms. He's putting a setup together to further test. Let's wait on his results. The bad news is it's happening. The good news is that it's happening to at least two of us.
I also feel quite strongly that I never got it to work at all with WAAS enabled. It worked better without it. Maybe the code isn't parsing the strings just right all the time. It also seemed to be more prevelent if I was moving East and not as much as when moving West. This might have just been coincidental timing though. Once it did come on solid, I couldn't get it to go out unless I power cleared it. Dan |
#4 | |
were you careful not to allow any Static discharges to come in contact with it when assembleing as in did you make sure you had no static stored on your fingers and inadvertantly touch the Pic 16f876a when assembling?? Walter (Radiohound) is a good guy no doubt he will take care of you.. i have a Rcap that i received from him and it seems to be working great on ground tests..i still have yet to air test it as im still testing the airframe it will be going in... i turn on my receiver and radio on first,i make sure RCAP and Copilot is turned off i then arm RCAP and the rest of the electronics.rcap status LED lights for approx 5 sec then shuts off.upon powerup it centers the rudder nicely everytime.when a route is activated in my GEKO201 and i Flip the switch to turn on RCAP the RCAP status LED will light every 1 sec or so and the rudder will follow the route(this is in TEST mode) i have noticed no instances of when the RCAP unit "Freezes". im going to do some further tests to figure out any flaws.. Hovertime:may i ask what city you are in ?if you are not to far from me mabie we could try my RCAP unit on your Rc Truck ![]() Thanks Walter |
#5 |
Always right
Location - Chicago
![]() North end of it, major roads close by are route 43 (Harlem) and 19 (Irving park road) Could you guys post a few pictures of your boards and cable setups? You bought them built or as kits? |
#6 | |
Professor of Wood
I also set the geko to demo mode and never saw a glitch. But demo mode won't fly the plane back. Only when I put in a valid waypoint and performed a "goto". How are you testing your's Walter? Dan |
#7 | |
#8 |
Hmm I'll order one on Friday and help you guys test it out. Any issues on a cheap Garmin 201? I think I'll end up doing like Hovertime and put it in my RC Truck first.
#9 | |
Professor of Wood
Dan |
#10 |
Always right
OK did some more testing, looks like led is blinking every second, inside the house.
As soon as it gets satellite fix - led goes to fully on, and no guidance. Using simulated GPS mode I was able to get it to work, pointing to the right direction, but not using real live data. What does it mean??? It "semi-worked" a few times using battery save mode on GPS, which updates GPS data less often, while still sending serial data every second... Something is not right somewhere... While looking for some more ideas I have found this old thread (as did some others )Might be worth reading it. http://www.rc-cam.com/forum/index.php?showtopic=666 We need more brain power on this guys!
#11 |
Always right
I was also wondering why does it have both serial in and serial out wires? Seems that only ground and serial IN would be needed?
#12 | |
This will allow you to listen on two devices. For example the RCAP and a wireless serial downlink.. I was actually running without the 2.2k resisitor just fine in half duplex. At that time I had my OSD and a Maxstream in line. |
#13 | |
Professor of Wood
I believe Walter is still making some checks and just got wrapped up. Dan |
#14 |
Always right
I had another idea, while sleeping
My unit "works fine" without GPS fix, and goes to led full on and no guiding as soon as GPS data is good.That means change from "v" to "a" on GPS serial streams. I have noticed that in debug mode it gets simulated (V) data also, and tests OK. Maybe I got debug software on my chip by mistake? Oh just shooting blind here guys... Thanks for 2 way serial explanation, I thought you would need to read it off special debug port though.... |
#15 |
Always right
Another thing I noticed - PIC's used in original RCAP and RCAP2 are different, can this have anything to do with some problems me and others are having?
RCAP : PIC16F876-20/SP RCAP2: PIC16F876A -I/SP |
#16 |
Professor of Wood
I got a message from Walter at Scalerobotics. He got a little wrapped up in other pressing business and hasn't had time to further test very much. He did indicate when he went to standard mode with GPS active instead of in demo mode, he was seeing the LED operate in strange ways. It looks like this issue is going to be accross the board.
He's also aware of the chip differences. He indicated the first version of PIC's was becomming obsolete but shouldn't be an issue. It is still being looked in to. Maybe we should get an original PIC chip from any source we can and program it with the code just to see if that's it. Dan |
#17 |
Generally speaking, if the original code used a 16F876, then it should be backwards compatible with the newer 16F876A PIC. The 'A' has a nice comparator and Vref module in it (affects IC pins 2-7), which defaults Off for backwards compatibility. However, it would be a good idea to recompile the original code before using the 'A' (just to be safe). The F876A burn algorithm is different, so be sure to use a programmer that can handle it.
FWIW, the original non-A part is not obsolete. Microchip still supports it and it is in production. Thousands are in stock at DigiKey. Edit: I looked through my inventory and I have a non-A 16F876-20/SP. I can program it with the RCAP code and send it to someone to try. All I ask is that my out of pocket expenses are covered. Last edited by Mr.RC-CAM; Mar 01, 2006 at 02:16 PM. Reason: I have a non-A PIC |
#18 | |
And Err what RC-Cam said
#19 |
It would be better to check the actual component data sheets. You should find that both releases have 8K words of code space, 368 bytes of RAM, and 256 bytes of E2Prom.
The major difference is in the silicon fab process used to create the die. While they were at it, Microchip added the comparator/Vref module to the 'A' part. The other features stayed the same. There is a couple of errata sheets on these parts that should be looked at too to see if they impact the compiled code. |
#20 |
Always right
Cool, thanks guys for any help with this!
Any advice about in circuit programming?Mr.RC-CAM - thanks for the kind offer, I'll take you up on it Please send a PM with your Paypal and amount.
#21 | |
PM sent about the 16F876 PIC. Cost is strictly what I paid Digi-key, plus a couple dollars to cover PayPal fees and shipping.
#22 |
Always right
HM I'm a little confused - do I leave the new R1 in circuit after programming, or is this change needed just to program it and I should switch it back out after?
I'm also not sure where to solder those 5 wires on RCAP...??? Thank you so much for your help and providing me w a chip, I couldn't find one locally today, and ordering from Digikey can be a pain... |
#23 |
Just permanently change R1 to the higher value. RCAP will not know the difference.
The five wires are: +5V: PIC Pin 20 GND: PIC Pin 19 VPP: PIC Pin 1 RB7 DAT: PIC Pin 28 RB6 CLK: PIC Pin 27 If your programmer can supply enough current you won't have to apply external power to the RCAP. But, I have a feeling you will have to use external power or remove the MAX232 IC during programming to reduce current. The 16F876 will ship in the morning. I hope it helps you solve your problem. |
#24 |
Professor of Wood
I wonder about GPS units in use. I don't think any of us has heard from Mike P yet about his original code, but if anyone does get a chance to ask him, let’s find out what GPS unit he was using. (Just brainstorming here) There are early GPS units with code that do not function with "Smart route finding". The Garmin GPS12 was suggested back in the early days of the PDC-10 as a unit that could be used and the waypoints would be followed in the sequence they were selected as a route. I have a GPS12 but it's been on loan for a long time to a friend of mine. It occurs to me to get it back from him and connect it up to the RCAP and see if it acts differently. I imagine there could easily be pieces of code information in newer GPS software/processor variants that might not be read by the RCAP PIC because of how it might parse the strings. The eTrex and geko are not very different from each other. But the 12 is a lot different from either of them.
I have an e-mail in to my buddy, As soon as I can get my hands on the 12, I'll run it through the tests and report back here. Dan |
#25 |
Blah wait I'm an idiot.. So I'll erase that and start over. I thought that GPS's usually spit out the same NMEA sentence?
#26 |
Always right
I have tried mine with Garmin E-map and Lawrence Ifinder GO .
E-map data stream is not configurable, while Ifinder GO is, so I set it to spit out GPRMC and GPRMB lines only. While I saved E-map streams on my PC to compare battery sav and regular modes, I don't have Lawrence units streams, but they must be the same. I'll try to find some time today to try read / reflash PIC .... |
#27 | |
![]() From my GPS code writing experiences, there is a variation in the NMEA sentences used in different GPS products. The order of the sentences, the handling of null or empty fields, the pacing time between sentences, and more, all act together to really ruin your day. |
#28 |
If you read the source code for the pic main.bas you can see what it is reading in DoB and DoC.. In DoB it is reading field 12 which is bearing to waypoint. In DoC it is reading field 9 which is true course. I'm still reading through the code trying to understand it *scribbles on paper with pen and highlighter*..
DoB = GPRMB DoC = GPRMC --Scott |
#29 |
Professor of Wood
I haven't heard from my friend that has my GPS12 yet. I agree the NMEA output should be standard but I think sometimes things grow or show up in later "standard" packages that might not be backward compatible with older versions of equipment. In this case I just don't know. We assume the original version worked just fine. We don’t know what GPS Mike P used. We do know that the PIC chip and board have been modified or changed slightly. We know we aren’t getting reliable results at the moment. As much as I hate to ask, do we know anyone who ever did use an RCAP in the beginning and can confirm it ever worked as it should? It might have always had this problem. Here’s a note in the documentation about v1.1. Among a few other things it “Fixed problem relating to eTrex GPS non-standard NMEA format.” That’s Mike’s note.
It does look like Scott says. It also doesn't care which string it gets first. The LED comes on at the beginning of that process, it parses the data, performs a checksum and then goes to a sub routine for each one to look at the data and process it. The LED doesn't go back out until it gets both of those strings and performs a checksum on both. Once it gets those items done, it turns back off the LED. The unit then goes and moves the servo and starts the process over. The LED staying on indicates it's not getting a valid checksum or something in that area. But I know the program is still running. While everything is connected, and you are following a waypoint, when the LED comes on and stay’s on, you can disable the unit and you have rudder control back. The LED is still on and will stay that way until it gets the strings and finishes processing them accurately. But the program is going back to the top and checking to see if it’s enabled or bypassed. MrRCCam, What’s the chance we talk to you with your engineer hat on to see if the components look like they’re rated and configured properly? Also, I've been running this with a Futaba PCM receiver with 3.3 vdc pulses. It seems to be OK with that. I mean it enbles and disables accurately as well as passes through the rudder pulses just fine when bypassed. I'm assuming the Futaba 3.3 vdc pulses are OK? Dan Last edited by kd7ost; Mar 04, 2006 at 10:43 PM. |
#30 |
Always right
Well guys I have decided to try and play with the chip out of board, so made a makeshift adapter using few 8 pin sockets... I wasn't getting much luck reading PIC16F876A that was included in the kit... As I was playing with programmers settings I think I selected master clear from hardware testing page, and erased the chip.
I have also received programmed chip form RC-Cam, which i tried right away. With it it did not light the led on as battery was plugged in, and RCAP was completely dead. Checked all voltages and radio link OK. I though maybe he forgot to flash the pic, so attached it to the programmer and verified HEX file OK. Interesting that programmer worked OK with tis chip?? All this is very confusing....?? I thought it must work at least as good as with substitute PIC?? Was board or components modified apart from added possibility for future upgrades? Doesn't look like it. Anyways, I'm back where I started, or even further back LOL... |
#31 | |||
I'm sort of out of touch since I don't have an RCAP or RCAP2. Just to help me understand the details, am I hearing that the RCAP2 works when it is sent test sentences (perhaps from a test function of the GPS?), but goes wacky when actual real time data is used? |
#32 |
Well it's a long shot but I went ahead and ordered an RCAP today. Also Dicks Sporting Goods had the Etrex Legend bundle on sale for $200 so I picked one of those up.
#33 | |||
Professor of Wood
I recall the Futaba pairs are on 1&2, then 7&8, then 3&4 and finally 5&6. My rudder is channel 4 and I'm using channel 6 for enable. So this keeps them from occuring at the same time at the PIC.Quote:
Dan |
#34 | |
#35 | ||
The problem sounds like an oscillator issue. What exactly is being used for CR1? Crystal or Resonator? Is it the exact part shown on Mike's schematic? It could be a bad PIC too. That would be a rare situation, but possible. I'll assume that is the case and send a PayPal refund to you since it was a bust experiment. Just toss the PIC in the chip graveyard. Quote:
#36 |
Professor of Wood
My Buddy Jeff hooked up an eTrex to his PC and looked at the strings with Hyperterminal. I don't have a DB9 comm port or a USB adapter so he got these and e-mailed them to me. I took out all the strings except the two that are parsed by the RCAP. As labeled these show what is there in Demo mode, Normal Mode, Before Lock and with WAAS enabled.
In Demo mode, the V in the RMC string means it's not a valid GPS lock. Dan In Demo Mode: $GPRMC,035050,V,4332.1805,N,11618.3374,W,17.4,89.9 ,050306,15.2,E,S*35 $GPRMB,V,0.00,L,,002,4332.181,N,11617.236,W,0.799, 90.0,17.4,V,S*7B In Normal Mode: $GPRMC,035402,A,4332.1801,N,11618.7986,W,0.0,0.0,0 50306,15.2,E,A*3E $GPRMB,A,0.00,L,,002,4332.181,N,11617.236,W,1.135, 90.0,,V,A*63 Before GPS lock: $GPRMC,,V,,,,,,,050306,15.2,E,N*0E $GPRMB,V,0.00,L,,002,4332.181,N,11617.236,W,0.996, 89.9,,V,N*7A In WAAS mode: $GPRMC,035728,A,4332.1799,N,11618.7943,W,0.0,0.0,0 50306,15.2,E,A*32 $GPRMB,A,0.00,L,,002,4332.181,N,11617.236,W,1.131, 89.9,,V,A*66 |
#37 |
If you are up to some experimentation, have your buddy capture several minutes of GPS locked data and save as a text file. Then use HyperTerminal and feed it to RCAP as a ASCII file. To poke sticks at my theory that it might be a pacing issue, use HyperTerm's line and character delay parameters to slow down the strings (don't go too slow or it definately won't work). If you can get RCAP to work with this data then you have your smoking gun.
#38 |
Professor of Wood
Sounds interesting. I'll get him to read this thread. I'm trying to get him to sign on here.
Dan |
#39 |
Professor of Wood
FYI to all,
If you're digging into this and need a source of what the GPS is sending and what is where in each string, check this link. http://home.mira.net/~gnb/gps/nmea.html#top Look at "26 interpreted sentences" and then the $GPRMB and $GPRMC sentences. Dan |
#40 | |
Professor of Wood
Dan |
#41 | |
Also, before a GPS lock occurs, the sentence parsing cannot be properly executed due to the presence of some NULL fields. So, any symptoms you see before a valid sat lock are probably of little consequence. What does this seem to mean? Well, it's all just one more reason to experiment with the text file method I mentioned earlier. Frankly, if there is a problem, I'm sort of leaning towards this being related to the lack of processing time between sentences (a pacing problem). Last edited by Mr.RC-CAM; Mar 05, 2006 at 01:18 AM. |
#42 |
Scale Robotics Inc.
Here is a jpeg of the schematic. Most traces are very similar to the original RCAP. CR1 is a ceramic resonator, see http://www.ecsxtal.com/pdf2/ZTT.PDF This is the same part that was specified in the original RCAP bill of materials BOM file.
Walter |
#43 | |
Professor of Wood
I just did a little more playing around with it. It doesn't matter if it's a selected Waypoint with a "goto", or a selected route with a "follow". However, you must select a waypoint or route in order to get the LED to go off at all. A GPS powered on by itself will cause the LED to come on if the RCAP is enabled but there is no route selected. So if anyone else experiments with this, you have to collect data while a route or waypoint is being navigated to. (Hmm, is that a clue) Dan |
#44 |
Always right
Well it looks like I was able to flash 876A Pic again, using desktop pc (I normally use laptop) IC-Prog software verifies it OK, compared to "MAIN.HEX" file ... however it is acting same as RC-Cam's chip - no led, no life. Looks like I haven't changed anything else in the board?
Can someone verify - I forgot - when RCAP is disconnected from everything and power is applied to it - led indicates all OK for a few seconds, or does it have to see radio signals for that first? BTW I have managed to erase RC-Cam's chip too, and I am unable to program it even using desktop PC. Walter - could you post a link to the file you use in your kits and your programing method / pic device settings? |
#45 | |
Always right
#46 | |
Always right
Someone asked if original RCAP ever worked OK, yes it did - you can read about it in this old thread, and probably find some info here on RCG too?
#47 | |
Professor of Wood
We have more brain power involved. It's being dug into pretty deep right now. Dan |
#48 |
Professor of Wood
Radiohound,
I have a request for future versions. I modified the picture here. Can you connect the Servo + voltage buss with the input to the regulator? (White line) Also, The holes for the servo wires are a little small. (Violet box) I used the heavy gauge servo wires, twisted and tinned but really struggled to get them inserted. Can those go up a diameter or two? Dan |
#49 | ||
If the above does not help then program the chip again with the Watchdog (WDT) fuse turned off. This is a setting within your programmer. Quote:
#50 |
Ahead Warp Factor 8!
Hi,
I have been helping Dan (kd7ost) with this problem. Dan has convinced me to sign up with this group and participate in the discussions. Since this is my first post I hope I do this right. I apologize if it's a bit long. First, a little about myself. I am not an expert programmer. It's just a hobby for me. Most of my experience is with the BASIC Stamp 2 writing programs for my Near Space Capsule (see www.tvnsp.org ). I have recently purchased PicBasic Compiler but I'm beginning to think I should have spent the money for the PicBasic Pro which is more like the BS2. Oh well. In any case I found a link to the PBPro manual which is what the RCAP program is written in (http://www.melabs.com/resources/pbpmanual/ ). I have been studying the software and added to the description of what the program does. See the bold text below. ---------------------------------------- Init: Get PulsIn value of Neutral for the servo Get Gain Value Get Servo Direction MainLoop: If Autopilot ON then GoTo Autopilot Else GoTo Passthru EndIf PassThru: Pulsin Receiver PulsOut Rudder GoTo MainLoop AutoPilot: Get GPS Data Get RMC or RMB sentence, whichever comes first. Turn on LED Do CheckSum of Data If checksum fails then GPSvalid = 0 else GPSvalid = 1 If GPSvalid = 0 then goto MainLoop (Note: LED does not get turned off in this case.) Fill in Vars (Extracts data from GPS string) Get the other GPS sentence (RMB or RMC) Do CheckSum of Data If checksum fails then GPSvalid = 0 else GPSvalid = 1 If GPSvalid = 0 then goto MainLoop (Note: LED does not get turned off in this case.) Fill in Vars (Extracts data from GPS string) Turn off LED (Note: This only happens after successfully reading and checking both the RMC and RMB sentences.) If Correction needed then DoCorrection GoTo MainLoop DoCorrection: If Direction Normal Turn normal Else if Direction Reverse Turn Reverse GoTo MainLoop -------------------------------------- The thing that I wanted to point out is what the LED means. As you can see the LED comes on after the program gets it's first GPS string. It does not turn off again until after the program has finished collecting data from the GPS, performing checksums, and extracting the data. If it fails the checksum then the program goes back to the Main Loop and the LED is still on. Or, if it takes too long for the GPS sentence to show up it also goes back to Main Loop and the LED is still on. The symptom that seems to be common among us is that the LED stays on for long periods of time. It's possible that it is failing the checksum but I have a different theory. It is my theory that the program is having a difficult time collecting the data from the GPS simply because of timing. Take a look at this program line: HSERIN 100, Main, [WAIT("$GPRM"), STR gpsdata\MAXDATA\13] This line tells the program that if no GPS data is seen for more that 100 milliseconds then goto Main (which is the Main Loop). Now let me describe my GEKO 201. My GEKO puts out GPS sentences every 2 seconds. The first sentence is the $GPRMC sentence and the second one is $GPRMB followed by 10 more sentences. It takes more than 1.5 seconds to transmit all this data. I don't know the exact amount of time. Now let's set up a scenario: Let's suppose the program just started the DoAuto routine. Let's also suppose that it(the program) captured the RMB sentence first since it is allowed to capture whichever comes first. Next it would perform the checksum and finding that RMB sentence is okay it would extract data from it. The next step is to capture the RMC sentence. The program line looks like this: HSERIN 100, Main, [WAIT("$GPRMC"), STR gpsdata[1]\MAXDATA-1\13] Let's further suppose that the program happen to look at the GPS as it was halfway through transmitting the GPS sentences and therefor the RMC sentence already went past. When all the sentences are finished transmitting there is a time gap before the next sentence starts. Let's suppose the time gap is greater than 100 milliseconds. Because it is greater that 100 milliseconds the program is redirected back to the Main Loop and performs some other tasks. It spends time rechecking to see if the user still has the AutoPilot on (APon = 1). That means it takes time to measure the pulse width coming in from the enable pin. After deciding that the AutoPilot is still on the program goes back to the DoAuto routine. Next it is directed to once again look at the GPS and wait for the RMB sentence. Again the RMB sentence has already gone by because it is the first sentence transmitted and the program took too long to get back here. We are stuck in a loop. Only when the timing works out to bring the program back to the GPS just before it starts transmitting the sentences will it capture the RMB sentence. This takes a while and therefore the LED remains on and no corrections are made to the flight path for sometimes long periods of time. Someone who had PicBasic Pro can change the wait time to perhaps 1500 and see what happens. I hope this helps. Jeff |
