Old Feb 25, 2006, 03:42 PM
mountain view, california
Joined Feb 2006
new project, must be lightweight. i need help in designing an edf
well my last 2 were just too heavy. the edf will be run off of my zagi equipment. it is a speed 400 motor with an 8 cell 9.6 volt battery. all the electrical, including battery motor servos reciever wires and esc, all weighs just around 9 ounces. that is wicked heavy as i understand...
so what is a lightweight building method?
does anyone have plans that might run off of my current electrical? i am willing to add another motor, run time isnt really vital its just got to run and fly. being my first custom built edf i just want it to fly, any experience will help for future designs.
so who wants to rescue me? i might order some carbonfiber cloth, i am experienced with composites, mostly fiberglass but i have done kevlar/aramid twice. i cant vacume bag, dont have the equipment, but i can pressure cure it. similar thing but only works with flat surfaces. will 2 layers of carbonfiber be light and strong enough? pressure curing will make it super flat and strong, but i think i should stick with 2 layers so i can sand it.
Zippiot is offline Find More Posts by Zippiot
Old Feb 25, 2006, 03:46 PM
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
Try Depron.
http://www.rcgroups.com/forums/showthread.php?t=398674
Kenneth
CRAZYPILOT is offline Find More Posts by CRAZYPILOT
Old Feb 25, 2006, 03:50 PM
Joined Feb 2006
can i find it locally? or do i need to buy it over the internet?
any good plans for depron that will run off of my electrical?
i can find many plans, but i dont know which ones work well...you guys have much more experience with these than i do so any advice is useful
Old Feb 25, 2006, 03:59 PM
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
I have send you a pm.
Kenneth
Old Feb 25, 2006, 04:12 PM
Joined Feb 2006
is this a good edf unit?
http://www.dynamoelectrics.com/detail.aspx?ID=891
it says it fits the speed 400, 68 mm is 2.67 inches, or close to that.
Old Feb 25, 2006, 04:14 PM
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
that fan needs a 480 motor. For spped 400 use a Wattage Power Fan.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Feb 25, 2006, 04:15 PM
Designer/Scratch Builder
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
My question is, why keep starting a new thread just to say the same thing? Just curious .
Kevin Cox is offline Find More Posts by Kevin Cox
Old Feb 25, 2006, 04:23 PM
Joined Feb 2006
threads get off topic so fast, or hijacked and such.
if the thread has 5 pages already, no one will attempt to read it all...
i found a wattage powerfan thing, but its got everything with it for 170 bux...
http://www.aeromicro.com/Catalog/wat...sc_1821225.htm
i cannot believe how much trouble im having finding one without the motors and such strapped to it. does anyone have a link to a site that carries just the ductted fan, no motor and such?
Old Feb 25, 2006, 04:29 PM
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
a "new threads per week" record ?
Zippy,
In each of the threads you have started, you have been offered the same ( good ) advice, from various people...
GET A WATTAGE POWERFAN !
I told you in your last thread that a minifan needs a 480BB Race - or a similar sized brushless.
If you choose a larger fan - even only slightly larger - you will require more power, which will incur more wieght...
If you must use the gear you already have, you must use a Powerfan for the best chance of success.
( Or a £7 SF turbofan... )
Keven.
keven64 is offline Find More Posts by keven64
Old Feb 25, 2006, 04:32 PM
Joined Feb 2006
im looking for a wattage powerfan, i cant find the fan unit without 100 bux of stuff strapped to it as a package. and even then i have only seen 1 that was just the edf unit without a plane strapped to it.
ok 2 questions, if i get the 480 motor do i need a new esc? and DOES ANYONE HAVE THE LINK TO THE WATTAGE POWERFAN EDF UNIT WITHOUT ALL THE BRUSHLESS STUFF STRAPPED TO IT? im sorry about the caps but i really cannot find one...
Old Feb 25, 2006, 04:34 PM
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
wops..
Kenneth
Old Feb 25, 2006, 04:40 PM
Joined Feb 2006
well, the second page's order screen...definately not in english. i speak some spanish...
39 euros (that was eruos right?) is approx what in us $'s?
and again, will a 480 motor run off of my esc for my 400? if not this is a lost cause, money is tight...
Old Feb 25, 2006, 04:44 PM
Joined Feb 2006
http://www.hobby-lobby.com/speed480.htm
when it say up to 20 ounces, does that mean motor included (im sure it does but i do have to check...). my battery is an 8 cell 9.6 volt, should work with these correct?
i think my esc is 20 amp, it says 20 on it but isnt labeled clearly...
Old Feb 25, 2006, 04:47 PM
byrocat's Avatar
Aurora, Ontario, Canada
Joined Mar 2002
Please update your profile to show where you live (or at least the country)
I think that you'd get a better response if you updated your profilke to inlcude at least the country you're living in. I was about to suggest talking to Hobby People, but they're in California and you appear (cannot confirm) to be somwhere on the eastern side of the Atlantic.
byrocat is offline Find More Posts by byrocat
Old Feb 25, 2006, 04:50 PM
Model Designer
keven64's Avatar
Joined Apr 2001
thread hijacking !?!
Yeah - I was also wondering what your location was...?
______________________________________________
I have two SF Turbofans here.
Each will put out over 12ounces of static thrust with a 6v speed400 motor running off an 8-cell Kan1050-type battery pack at around only 8A.
Read about them at the bottom of this page...
They are similar to the Powerfan, are the same size, and come with no motor but with a neat inlet ring - for only £7.
What's that ? $11 + shipping ?
They will accept a speed400, a 480BBRace, or even 400-sized brushless.
No I do not have a vested interest - I just know a bargain when I see one !
Keven.
*edit* For someone on a "tight budget" - £7 = US$12.22 at todays prices ! *edit*
i need help in flying my new multiplex easystar jay220 Foamies (Kits) 19 Nov 20, 2008 05:08 PM
Need help in designing a "Removable Canopy Sytem" BING! Electric Plane Talk 6 Sep 28, 2005 06:17 PM
NEED HELP IN FINDING IFO Airfoil for PROJECT! hoverkid87 Electric Plane Talk 44 Mar 12, 2003 11:51 PM
Need HELP Setting up an ECO8 with Futaba 8U in the Bay Area, California ropuri Electric Heli Talk 4 May 14, 2002 01:43 PM
