Old Feb 27, 2006, 11:25 AM
Cziltang Brone is offline
Find More Posts by Cziltang Brone
Slope elope
Cziltang Brone's Avatar
United States, CA, El Cerrito
Joined Nov 2004
Looks good. I've got some goop-hinges drying as we speak on my DLG's ailerons. How long did you wait for the hinge to cure? 24hrs? 48hrs?
Cziltang Brone is offline Find More Posts by Cziltang Brone
Old Feb 27, 2006, 11:32 AM
THUREN is offline
Find More Posts by THUREN
blah...
THUREN's Avatar
United States, OR, Bend
Joined Jun 2005
Today with the rain Jeret, wait a long time before touching them. If you can put a small fan/heater near them is should help speed it up. Main thing is to not agitate them AT ALL for at least 15 or so hours. After 24 hours you can wipe a tolulene soaked paper towel down the top/bottom of the joint and clean it up..
THUREN is offline Find More Posts by THUREN
Old Feb 27, 2006, 11:49 AM
Slope elope
Joined Nov 2004
Gotcha. I started them last night actually, around 7pm. I'll check on 'em later tonight.
Old Feb 27, 2006, 08:48 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
Well????
More progress...
Wing root gap filler deal glued in, sanded smooth, and middle joiners finished ready for paint.. The wing will have a white stripe down the middle so the colored filler will be covered.
Going to watch some movie with my wife, don't know the name, as all I care about is Jessica Alba is in it...
Fuse prep afterward..
Don
Old Feb 27, 2006, 09:51 PM
Slope elope
Joined Nov 2004
Originally Posted by THUREN
Well????
It's no wonder they call this stuff "Amazing Goop". Goop hinges are go!
It's hard to believe I'll ever want to do taped hinges again.
Old Feb 28, 2006, 10:24 AM
jludwick is offline
Find More Posts by jludwick
iWeasel
jludwick's Avatar
Santa Barbara, CA
Joined Feb 2005
Looking schaweet! Did you not use the little servo grommits and screws that come with them? That should provide a tight fit, right?
jludwick is offline Find More Posts by jludwick
Old Feb 28, 2006, 12:15 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
Thanks Jon..
Well, I didn't use the grommets and screws for two reasons... First, they won't work, as the wood is cleared for the servo where the screw would go. I had to put the screws in at a slight angle and pushed out so I could screw into some "meat"... Second, I wouldn't have used them anyway. I plan to DS this thing and I don't want ANY servo movement AT ALL. The little rubber grommet deals are too loose IMO for this application...
Don
Old Feb 28, 2006, 12:24 PM
hydrogin is offline
Find More Posts by hydrogin
Santa Barbara, CA
Joined Feb 2004
Servo grommets are used in high vibration applications like nitro trucks, gas planes, etc. No need in a glider.
Lance
hydrogin is offline Find More Posts by hydrogin
Old Feb 28, 2006, 12:33 PM
Slope elope
Joined Nov 2004
I've been hot gluing in my servos for quite some time now. After the glue sufficiently cools, its a solid as a rock.
Goop works too! Amazing stuff! (I want an Amazing Goop T-Shirt)
Old Feb 28, 2006, 01:04 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
Jeret, I'd loose the hot glue on builds unless you don't have time for goop to dry(thick bead). Goop is FAR superior and the part won't "pop off" like it can with hot glue. Goop is some gnarly stuff and as far as I can tell the only two REAL drawbacks are weight, and the time it takes for a thick bead to dry. Get it over 1/8" thick and it could take a few days to get totally solid. But it IS STUCK!!
Don
Some paint is drying on th wing as I type...... wooooo hooooo!! Picking up some clear laquer to spray on as a top/sealer/gloss coat...
Old Feb 28, 2006, 01:16 PM
AndreasMergner is offline
Find More Posts by AndreasMergner
fun is the goal
AndreasMergner's Avatar
USA, NY, Albany
Joined Dec 2003
I agree with Don. Hot glue doesn't stick nearly as well as Goop. Goop is tenacious whereas hot glue bonds weakly and is temperature dependent.
AndreasMergner is offline Find More Posts by AndreasMergner
Old Feb 28, 2006, 01:23 PM
KingOfTheHill is offline
Find More Posts by KingOfTheHill
Ninja of the Nasty
KingOfTheHill's Avatar
Joined Jan 2004
i saw one the other day for the first time... pretty cool!.. HEAVY but that shouldnt be a problem around here...
my only gripe on it is the fuse.. the nose is hideous looks like an ancient viking ship hahaha... but it will get the job done, and it feels beefy...
Cant wait to see one fly in person
JOe
KingOfTheHill is offline Find More Posts by KingOfTheHill
Old Feb 28, 2006, 02:20 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
Dang the white is bright!!! No that's not the sun coming through you screen..
4 coats of clear laquer down, another 4 or so more to go... Sand and polish tonite/tomorrow hopefully...
Don
Different Kind of Slow Stick, "Slow-G" build-n-fly Don Sims Parkflyers 49 Dec 20, 2006 01:32 AM
Fold-n-fly mike glass Foamies (Kits) 8 May 02, 2003 09:13 PM
WTB USAirCore fold n'fly F-16 Majortomski Aircraft - Fuel - Airplanes (FS/W) 0 Mar 06, 2002 09:07 PM
Want to scratch build a fun fly plane. Cay you recommend plans? WilliamSettle Sport Planes 4 Oct 04, 2001 11:29 PM
Why solder ESC's instead of plug-n-fly? J Cubed Power Systems 5 Jun 29, 2001 06:06 AM
