Go Back   RC Groups > Aircraft - Electric - Helis > Micro Helis
Old Feb 24, 2006, 09:24 PM   #1
Fuses saved my rx today
Whelp, the fuses I installed last week sure paid off today! caught a bit of wind today that pushed the heli up into my roof eves and down she went.
Damage done: 1 fuse!
Soldered in a new one and back up she went!
I wish I could remember who's post I got this idea from - I want to say SSG Scott but I'm not sure.
Whoever it was - THANK YOU!
neilswolf is offline Find More Posts by neilswolf   Reply With Quote
Old Feb 24, 2006, 09:33 PM   #2
Fly-Bar? What Fly-Bar?
blade strike's Avatar
I do think it was SSG Scott..
blade strike is offline Find More Posts by blade strike   Reply With Quote
Old Feb 25, 2006, 05:02 AM   #3
Sponsered By My Wallet!
Minimole's Avatar
Send a message via MSN to Minimole
Sorry, care to elaborate on the fuse?
Do you put it between the main motor and ESC, so if the blades are stopped suddenly but the motor is still (trying to) turn, the fuse pops instead of the ESC?
Cheers, Duane.
Minimole is offline Find More Posts by Minimole   Reply With Quote
Old Feb 25, 2006, 03:12 PM   #4
Newbie
Look here for the directions with pics thanks to Scott.
http://www.rcgroups.com/forums/showthread.php?t=472793
Mike abcd is offline Find More Posts by Mike abcd   Reply With Quote
Old May 24, 2006, 02:07 AM   #5
Is it worth trying to use something like this?
http://www.radioshack.com/sm-30-amp-...i-2102783.html
I like these ideas and I thought perhaps it could get tiresome using a solder iron to replace the fuses each time. I know weight is a factor and 12AWG wire may be an issue. I am curious what you guys think.
stockcp2 is offline Find More Posts by stockcp2   Reply With Quote
Old May 24, 2006, 02:26 AM   #6
Have blown the fuse on my Kyosho m-24 only once. But glad the factory put it in there. Can use the Female connectors like this to save some weight or soldering.
  • Name: Kyosho m-24 fuse.JPG
Roto Rob is offline Find More Posts by Roto Rob   Reply With Quote
Old May 24, 2006, 07:22 AM   #7
Stock...that's exactly what I've been thinking about, but haven't spent much time looking. Thanks for the link! I have the fuses, but would really rather have a holder like this.
scratchee is offline Find More Posts by scratchee   Reply With Quote
Old May 24, 2006, 01:42 PM   #8
Just call me crash.
I have been through 3 main motor fuses and 4 tail motor fuses, this is one of the great ideas that works really well.
rocknbil is offline Find More Posts by rocknbil   Reply With Quote
Old May 25, 2006, 12:41 AM   #9
StockCP2...
Well, I stopped by Radio Shack to check out those fuse holders, and they were way too bulky for my tastes. I'm not very picky about weight, but these were bigger than they looked in the picture, and they just looked like they would take up a bunch of space. So I'll just hard-wire my fuses, I suppose. But thanks for the idea!
Old May 27, 2006, 12:50 AM   #10
I wouldn't give up that easily =P. Get some heat shrink tubing and 22-18 gauge (small) female disconnects. You have to open up one of the folds a bit on the disconnect so the fuse post will slide in easier and then squash the other one a little bit to get it out of the way. You can even bend that towards the other fold to make things smaller. Use the heat shrink tubing to cover the metal body of the disconnects. I do it while the fuse is connected so the tubing wont wrap all the way around the end of the disconnect. It works good, keeps things covered and doesn't require permanently soldering the fuse. I did add solder at connection of the wire and disconnect to further secure that connection. Ill post a pic later (if I can), its nearly 1am right now.
Old Jun 09, 2006, 06:29 AM   #11
Smaller replaceable fuses
For this useful mod much smaller fuses are available that do not need you to drag out the soldering iron when it comes time to change them (often in my case....). Manufactured by LittleFuse, available through Farnell (www.farnell.com) and many others. Fuse holder is 9.9mmx5mmx3.7mm and weighs 0.3g with the fuse fitted. Many options for mounting, either soldered direct to motor terminals or glued somewhere with flying leads works equally well. Farnell part numbers:
Holder with 3A fuse fitted - 994-3650 (£1.13ea)
3A quick blow fuse - 416-1592 (£0.29ea)
7A quick blow fuse - 416-1622 (£0.29ea)
Very fast acting fuses are also available but not in the 7A rating. Haven't tried it but suspect a 10A very fast (992-2202) and a 3A very fast (992-2180) will do just as well. (Strictly the 10A fuse is beyond the fuse holder rating but unlikely to cause a problem).
If you don't want the no-solder swap capability MUCH smaller fuses are also available in the tail motor rating but frankly I wouldn't bother. Being able to change them quickly is well worth the 0.3g!
Farnell accept credit card orders but there is a 10-off minimum order quantity and postage charge. In the scale of things insignificant but if you really can't bring yourself to spend the few pounds if enough people contact me I will buy and supply avoiding you the MOQ.
CP2Hopper is offline Find More Posts by CP2Hopper   Reply With Quote
Old Jun 09, 2006, 07:58 AM   #12
This space for rent!
Ken448's Avatar
Send a message via AIM to Ken448
Those in the states, RadioShack sells this mini-Blade fuse holder
http://www.radioshack.com/product/in...entPage=search
Ken448 is offline Find More Posts by Ken448   Reply With Quote
Old Jun 09, 2006, 02:33 PM   #13
RC Bum
Eric_N57105's Avatar
That's what I use. They are female 0.110" spade connectors. I think you are using the wider ones. The 0.110" slide right on...a little tight, but both folds engage the fuse the way they should. No bending required.
Eric
www.ke6us.com
Eric_N57105 is offline Find More Posts by Eric_N57105   Reply With Quote
Old Jun 10, 2006, 01:22 AM   #14
Eric
www.ke6us.com
Do you remember where you got them at? I was at NAPA and grab the smallest of connectors I could find and made them work. Seems to be ok for now until I run out of them.
Old Jun 10, 2006, 01:51 AM   #15
RC Bum
I got a big bag of them from the local surplus electronics store, but I've seen them branded by Philmore/Datak. I checked their website, but they don't show them.
Action Electronics is selling a 50-pack for $8, P/N NB-50LH
http://www.action-electronics.com/terminal.htm
I bet a search would bring up many more sources.
Eric
www.ke6us.com
FMA Copilot Review - It already saved my helicopter today... Patrick Plawner Electric Plane Talk 5 Jan 28, 2004 04:08 PM
I got my Stinger Today! Ryan Nau High Performance 7 Sep 17, 2001 07:12 PM
Charging my Rx battery tenover Electric Sailplanes 2 Sep 07, 2001 01:53 AM
VERY lucky with my Zagi today slowflyer Foamies (Kits) 7 Jul 29, 2001 03:25 PM
lost my plane today bronco Electric Plane Talk 17 Jun 28, 2001 01:56 AM
Congratulations SimpleM!
