Old Feb 24, 2006, 10:31 AM
bnflyn is offline
Find More Posts by bnflyn
Joined Jan 2005
Balancing Question, Yet Another One
I have been following many of the post in this forum trying to understand the ins and outs of cell balancing and the associated lengthy and sometimes confusing discussions. Especially with regards to wire color and pin out of the various manufactures lipoly battery packs. What we would have given for some type of industry standardization.
But to the point and back to basics. Other than the length of time involved to carry out individual cell balancing, what is wrong with discharging a lipoly pack, if fully charged, say ten to twenty percent down, and then using a Apache or similar charger, set it for one cell and around .5 C charge current and then charge up each cell individually.
I realize that this is probably not acceptable time wise for flyer's with a number of high cell count battery packs but it seems an appropriate balancing method for the flyer's who run their packs consertivatly, never approaching a BEC cut out at maximum rated burst current capability. Or incurring any of the other cell stress issues that Everyday Flyer and others have made us aware of.
Does cell balancing really need to be this complicated?
Bernie
bnflyn is offline Find More Posts by bnflyn
Old Feb 24, 2006, 10:58 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Chargin a pack in series to approx. 4.1 volts per cell and then charging each cell tp completions works fine but can be indeed very slow. Based on my experience doing this it will take one hour per cell after the series charge is completed. Depending on the cells and the charger the cells may never be exactly the same but should be within 0.02 votes which is plenty close enough for all practical purposes.
http://www.rcgroups.com/forums/showp...64&postcount=2
Charles
Old Feb 24, 2006, 12:59 PM
bnflyn is offline
Joined Jan 2005
Thanks Every Day Flyer, I was hoping you would comment on this item.
When you suggest cell voltage to be within twenty millivolts I assume that would be between the highest and lowest cells in the pack?
Bernie
Old Feb 24, 2006, 04:09 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Why Don't U Just Spend A Little Extra Time To Check Your Prop Load And Never Let Them Overheat And Get Another Pack To Share The Duty Cycle Of Your Flying Habit
That's What I Do And I Never Have Any Balance Problems, Have'nt Even Check The Voltage Gap Between Cells In A Pack With Center Taps
hall woo is offline Find More Posts by hall woo
Old Feb 24, 2006, 04:56 PM
PerfectStranger is offline
Find More Posts by PerfectStranger
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
That's alot of work to capitalize the first letter in every word! I must ask, what was the purpose?
ma
PerfectStranger is offline Find More Posts by PerfectStranger
Old Feb 24, 2006, 05:23 PM
bnflyn is offline
Joined Jan 2005
"That's What I Do And I Never Have Any Balance Problems, Have'nt Even Check The Voltage Gap Between Cells In A Pack With Center Taps"
Then you don't know what kind of balance condition you have. In or out of balance. And center taps are generally associated more with transformers. It's cell taps we are dealing with here.
Bernie
Old Feb 24, 2006, 06:24 PM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
Bernie
I think it's called the "head in the sand" approach to pack balancing. If you don't see a balance problem, you must not have a balance problem.
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Discussion yet another one of my weird thoughts shock absorbers slo123 Micro Helis 9 Apr 12, 2007 10:58 AM
Help! Yet another balancing question dottney Batteries and Chargers 3 Mar 06, 2006 10:08 PM
CC25 cutoff problem - (yet another one!) bhenry Castle Creations 5 Oct 26, 2005 01:46 PM
Yet another battery question theKAT Parkflyers 5 Jan 31, 2002 08:10 PM
Yet another question about the american taliban logan5 Life, The Universe, and Politics 6 Jan 26, 2002 01:04 AM
